You'll need to purchase music from an online site such as Itunes. You will also need a blank CDR. Once your music is loaded into Itunes it is as simple as clicking the burn to cd icon.
You cant delete anything once files are burnt to a disk. you will have to copy the music to a folder then delete the music files that you don't want then you can add more music files then burn them to another cd/dvd
Click
start click on computer to open you should see your drives C: and your other
drives cd dvd and your phone E: or F:
Right click on the the music disk to open
you should see your music
from
there you select the music files right
click on the music file/s select copy navigate back to the drive right click
select paste or hold the mouse cursor the music file/s drag them to your
computer
and paste them in usually in my
documents my music.
All or any music formats? What format is the music file? Use you Real Player Converter to convert the format. Is it DRM music that does not allow copying?
are you burning the music cd's in the music format to be converted over and finalize the disk? you cant burn them as mp3s. if your able to fit more then 18 or so songs then you are burning it as an mp3/data disk instead of a music disk. if your computer is getting really slow i recommend you download an anti virus if you haven't already (such as avg FREE) and a spy ware malwayre removal called malwarye bites.
You need a burning software to burn your picture files, music, or video. You can use NERO Burning ROM. Download it from HERE. You can use the "Data Burning" Feature in it to transfer your files into CD or DVD.
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall hope this helps
Two thinhgs your software doe snot like the CD or you have wrong type of CD, make suer that if you using the CD for Music that you have the correct CD and same with Files...and all your setups are correct.
What is exactly the problem, Does your computer have the software and the CD burner in it? What are the steps you follow to burn music? Normally to burn the music from the computer , use Media player or any other software that can burn CD. Pick the music files to be burned from the local drive. Insert blank CD in the CD burner. Hit the burn to CD button from the CD burning software.
What burning software did you use? I always use movavi dvd burner to burn music to CD, it works pretty well for me, if you need detailed info, here is a guide about it http://www.freedvdripper.net/guides/burn-dvd-copy-dvd-make-music-dvd.html Hope it helps. Contact me if you have any other question.
you may need to check to see if you have a CD writeble Rom, open up the computer to see if the cd rom cord is in all the way. I would put a DVD rewriteable in the computer new ones come with the software. you may need a driver. www.download.com
you may only have a CD rom, and you need a CD writer to burn songs. A DVD writer can burn CD's and DVD's
