Question about Ariston Technologies AW125NA 13 lbs. Load Capacity Washer
F-08 is on the display
It`s leaking water and if left on continues to make a low noise with f-08 on the display
  • Ariston Tech... Master
  • 3,463 Answers
Error code F08 indicates heater relay stuck.
  1. Check pressure switch connections.
  2. Check heater connections.
  3. Check module connections.
  4. Check and clean pump and or pump filter.
Please rate my solution.
Thanks.
Posted on Nov 16, 2009
FE Code for model WM1812CW LG Washer
Hot water inlet valve most likely needs replacing
May 14, 2017 | LG Washing Machines
Heater core
May not be heater core, sounds like leaking water into car from some other source.Low coolant could be engine gasket related Check for coolant leaks in engine compartment & under car.
Also check for water leak at winshield before replacing heater core.
Nov 30, 2013 | 2008 Pontiac G6
How to troubleshoot a water heater
1) If water flow stops when tap is off, then Sound of water running: could be factory-installed heat trap inserts or nipples: These things cause noise.
http://waterheatertimer.org/Low-hot-water-pressure.html#trap
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#heat-trap
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
2) If sound of water continues when tap is off, then there is a broken pipe or leak somewhere in plumbing system.
Feb 17, 2013 | Reliance 606 Series 40 Gallon Natural Gas...
C180 kompressor 2002 model, power steering makes a noise.Less noise if the iol level is very low. There is a slight leak and I am thinking that it **** air and causes the noise. However it is also di
The noise is the result of air bubbles in the system due to low fluid level, if allowed to continue without repairing the leak the pump will be destroyed.
Oct 09, 2012 | 2001 Mercedes-Benz C-Class
Pool pump running low psi
your pump should be just fine once the water starts flowing again. You may have run it too long without enough water to cool the seal.
If it is leaking water between the Jacuzzi Pump housing and the motor then you will need a new pump seal. Those are common pool parts.
Rod
US Parts Center
888-521-6183
Jun 09, 2012 | Jacuzzi Magnum Force Series Pool Pump 1...
Noise when steering oil leaking not engine oil
Power Steering will make a bunch of noise when it is low on fluid. Find the spot it is leaking from and fix it, then make sure the fluid level is at full then you are done.
Continuing to let the power steering stay low on fluid can cause the unit to fail.
May 03, 2010 | 2005 Ford Focus
I have fluid leaking and makes noise during turns
sounds like the water pump is leaking onto the drive belt for the steering pump, have the water pump tested for a leaking front shaft..
Mar 11, 2010 | 1989 Chevrolet Beretta
Sub zero #590
Have a small water leak up top on left hand side and looks like it could be a small plastic hose?
Dec 25, 2007 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Bought the display unit and water will not work.
hi there the low humming noise that you are getting sounds like the fill valve, this could be due to you perhaps not turning the water back on after fitting the new dishwasher or the fill hose being kinked when the dishwasher was put back ,hope this is of some help to you.
Dec 02, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Washing Machines Logo
518 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
