Ge will not spin. it does agitate and drain
Ge will not spin. it does agitate, and drain
    Sergeant:
    Champion:
  • 289 Answers
Check door switch
Posted on Nov 15, 2009
I have a GE washer model # WHDRR418GWW. It is about 19 months old. It stopped agitating and spinning. It will fill with water and the timer/knob will go thru the cycles. But when it reaches the washing...
You have what is called "agitating dogs" there are usually 4 of them at the bottom of the agitator. They have small grippers which lock onto the agitator and agitates. If the washer is ever overfilled or over time filled to heavy this will wear down the nylon teeth on the "dogs". The top of the agitator will spin off, you will see a bolt inside at the bottom, remove bolt and the agitator will pull out. Google "agitating dogs on washer. It will give you pictures for a better understanding. If the belt was broken the washer would not drain, because the belt turns the pump. These dogs are about $5 and honestly easy to install. Good Luck.
Dec 04, 2010 | GE WHDRR418GWW 35 cu. ft. Washer
GE Washer WJSR2080V3WW will fill, spin and drain but not agitate.
The problem is the agitator coupler (about $ 7.00) simply pull straight up on the agitator - Give it a good tug. take the one bolt holding the coupler off - pull straight off. Replace the coupler and bolt (they are sold together). Line the agitator lines up with the coupler lines - when they line up it should go all the way down and snap back into place. and your done.
Sep 01, 2009 | GE WJSR2080V
GE Profile Washer WPSR3120W2WW agitates but won't drain/spin
Your drain line is more than likely plugged with a sock or something of that nature.
Aug 11, 2009 | Washing Machines
Wont agitate,but does spin/drain
you have worn out dog agitation ears. it's a very easy fix. parts should be no more than $10. Good luck :) please let me know if you need any other help.
Jul 07, 2009 | GE WVSR1060A Top Load Washer
1.5 year old ge profile washing machine will not agitate or spin
Timer seems to have gone bad. Manually move the timer to make the dryer spin. If you get it to spin and drain then it's your timer.
Jul 01, 2009 | GE WDSR2080D Top Load Washer
Will not go in to spin cycle
Remove agitator (it will pop off when pried) then you will find your answer. Mine was a broken tub collar to shaft.
May 09, 2009 | GE WBSR3140DW Top Load Washer
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
