Question about Smeg FAB28
I want to change the door on my Smeg fridge from a left hand open to a right hand open. It seems easy enough to change the hinges to the other side, but what do I do about putting the door handles on the other side??
Just look how you taken it off easy as that mate
Posted on Nov 15, 2009
Both the freezer and fridge doors hinge on the right, and the left hand side has sagged a little so neither neither door is sealing properly. How do I adjust the doors to raise the left side of the...
The lower hinge on each door may have a door closing cam. It raises the door up ΒΌ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
May 04, 2011 | Refrigerators
May Tag Referigerator
The MBR1952KES Has the hinges on the right only, you need to order a custom made door to move hinges on the left.
Here is picture
Jul 27, 2008 | Maytag Refrigerators
How do i change the side the doors open on my Ariston AS108 fridge freezer
if you look at the door and fridg where the hinges are mounted you will see plastic or rubber covers for the opposite side. the doors and hinges are made to be left or right handed and can be changed in only a few minutes with a screwdriver
Nov 26, 2009 | Refrigerators
Help . Change doors from right to left opening
first remove the door from the fridge, remove the hardware connected to the fridge, on the opposite side should be rubber or plastic caps covering some bolt holes. remove caps and install top of hinge transfer everything you see on the left to the right
Oct 21, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
The door gasket on my Smeg fab28 is not sticking to the fridge properly. The Smeg only wants to sell me a new door. What to do?
I have a need trick to solve this problem
you door wont close all the way probably because to inner side of the door (the hinge side) the gasket is touching the fridge frame and been bend back .
or the top or bottom is miss align
the solution is simple
loose up the bolts than hold the hinges
and use coins as shims
"yes" "coins" nickles pennies or quarters
slide then in between the hinge and to bridge body and will give the gasket he necessarily space to close properly, may take several times on till you get the right combination
and make sure is no gap left after that
It has work for me lots of times.
good luck :)
Jun 10, 2009 | Refrigerators
Change sides for hinges
doors are reversible but a little work.once you start taking hinges off you will see inserts that are covered with a plastic grommet.pull those out and put grommets back on other side.you should see it is very easy but time consuming.
Mar 06, 2009 | Whirlpool ER6AHKXPQ Top Freezer...
Change door opening direction on whirlpool fridge door
Here is a setp by step manual to reverce the doors on ther fridge. Refer to page 5 through 8 will sho you how. good luck. jon please rate.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GB9SHDXPB_Use%20and%20Care.pdf
Dec 17, 2008 | Whirlpool GB2SHDXP Bottom Freezer...
Change right hand door ,to left hand
Not sure with this model but most time you can and I'm sure this is no different, look at the screws holding the hinge bracket, there should be identical screw holes to match on the opposite side.
Aug 06, 2008 | Dometic RM2652 Refrigerator
Fridaire model frt181l6d50
You'll need to remove the top hinge cover from whatever side it is on currently and then lift the door off the hings post ( set the door aside) .. then the top of the fridge will have small removable caps that hide the nuts for where you fasten the hinge to that side. Reinstall those caps to hide the holes in the top of the fridge where the hinge used to be. Next, you will have to transfer the handle on the door to the opposite side ( same process as the hinge) .. You wil find small plastic caps that hide the holes you'll be using to secure the handle to the opposite side,. use the same process for the freezer door too..This process only applies to top/bottom type freezers and not side by side. Hope that helps
Aug 03, 2008 | Frigidaire FRS26R4A Side by Side...
Smeg Fab 32 door problem
Remove the lower hinge on the fridge door and pack out using a piece of cardboard resrcew the hinge onto the door, this will resolve the problem Regards Advisor Smeg Agent
Jun 08, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Smeg FAB28 Logo
578 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
ashburton
Mike
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
