Question about Refrigerators
How do you replace freezer door gasket correctly?
  • 1 more comment
  • Kirk Kleist Nov 15, 2009
    I looked under the gasket and saw no screws as you mentioned, the gasket is between the plastic shelve liner and the metal door. Any Ideas?
    Whirlpool Model ED5NTQXKQ00
  • Kirk Kleist Nov 16, 2009
    Yes it was thank-you for your help
    President:
  • 704 Answers
You can do this yourself with just some basic tools and a little patience and assistance.
You'll need to remove all food from the freezer as it will take at least 45 minutes or longer, depending on how well you do.
If you roll back the door gasket, you'll see the fasteners that hold the gasket in place. Remove these starting with the ones on the bottom edge and then the sides. Finally, remove the top ones, leaving the two top corners for last, that way you can have someone help hold the door liner, so it doesn't drop to the floor and get damaged.
I would also suggest that a day or so before you're going to do the repair, that you let the new gasket lay out on a floor somewhere where it can't get damaged so it will relax and get most of the kinks out of it from shipping, etc.
Then simply put the gasket onto the door liner and reinstall all the screws back onto the door frame.
There are some models (you didn't provide a brand or model number to zero in on the exact version you have) that have the door gaskets glued onto the door frame. On this types, you'll have to use either a plastic or metal putty knive to gently run around the entire edges of the door, between the gasket and the door frame, to get it to come off.
Then you'll need to have someone help you reinstall the new one, as you'll have to reglue the gasket onto the door frame. This will require some non-marring clamps (about 4-6) to hold the inner door panel and gasket onto the outer metal door frame, while the glue dries. Typically, this is done with the fridge door removed from the fridge and takes at least a day once it's installed to glue in it place and fully cure.
In either case, please go to the link below and enter in the model number of your fridge so you can see which type you have and get a line drawing that shows the replacement parts you'll need. You can order them anywhere you wish, it's just very convienent that Sears provides the info for just about all brands of appliances made.
You can find your gasket part at www.searspartsdirect.com by entering in your model number for your unit and looking at the drawings and parts list provided.
Hope you've found this very helpful and best regards!
Posted on Nov 16, 2009
  • Mark
    Mark Nov 16, 2009
    Sorry, It appears that you did provide a make and model number, in a follow up comment. Unfortunately, with the way Fixya operates, experts aren't able to see any comments from other experts, nor can we see your comments, until AFTER we've posted our answer to your question. Just a little glitch in the system. Anyway, here's a direct link to your model number with a line drawing and parts list.
    http://www.searspartsdirect.com/partsdir...
    According to the parts list and line drawing, your freezer door does have screws holding the gasket and inner door panel onto the exterior metal door. If you look by rolling back the gasket at the corners, you should see if there are any screws holding your freezer door gasket onto the outer door.
    You might have to look under the inner door panel edge, hence the reason to look at the middle section or corners to make this a bit easier to do. You might have to remove the inner door panel from the gasket first, in order to get at the screws that hold the gasket onto the metal door frame.
    Don't pull on the inner door panel too much, as you really don't want to crack or break it, since your goal is to only remove and replace the gasket. Take your time and you should be able to get it off and replaced.
    Of course, don't remove this until you've got the new one available and then allow plenty of time to do the job, which means getting the fridge and freezer emptied completely, so have plenty of coolers available with lots of ice!
    Hope you find this Very Helpful and best regards!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You’ll need following tools--
  • putty knife
  • nut driver
  • combination square
  • hair dryer
  • clean towel
  • replacement freezer gasket
Steps/Procedure to replace the gasket:
1. First use the combination square to see if the doors are properly aligned. Measure the gap between the freezer and refrigerator doors at several points, and also check the gap between the freezer door and the side of the appliance.
2. There are screws under the fold of the freezer door gasket that holds the brace for the gasket in place. Lift the rubber gasket to expose the screw head, one section at a time. Just loosen the screw, and do not take it completely out.
3. Take down the model number of your refrigerator and buy a replacement gasket. If the gasket has a kink in it when you remove it from the packaging; you can clean it by heating it with a hair dryer. Use a low-heat setting on the dryer and be careful not to get it too close to the gasket.
4. Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in. Pull back the lip of the gasket and use a nut driver to free the gasket.
5. Only remove enough nuts to free half the gasket. If you remove them all, the tray inside the door will also come off and it will be difficult to realign everything.
6. Wipe the area clean, and then use a putty knife to slip the new seal under the tray. Once you get it started, work around the gasket into place around the door. Remove and replace the retaining nuts as you go. Pay attention to the corners so they're aligned properly.
7. Check the seal by closing the door. You should have a nice, tight seal.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
ylee
Posted on Nov 15, 2009
  • Rylee Smith
    Rylee Smith Nov 15, 2009
    Hi
    The procedure i mentioned usually applies for mostly all the refrigerator's freezer. However, i can provide you with model specific information if you can provide me with Brand and model number of the refrigerator.
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith Nov 17, 2009
    Hi
    Please do accept the solution if the issue is resolved.
    Thanks
    Rylee
Electrolux FFU14F5HWB has intermittent defrost issues
Thank you for your post friend.
I understand that you are having intermittent defrost issues with your Frigidaire refrigerator. Are you experiencing an accumulation of ice buildup, are you losing food? Defrost issues can be caused by a variety of things such as a defective defrost heater, thermostat or defective door gasket. I recommend that you visually inspect the door gasket for defects such as gaps or tears. You can also use a dollar bill to test the door gasket. Place a dollar bill in between the door and the body of the freezer. If the dollar bill pulls out with no to little resistance, you may need to replace the door gasket. A faulty door gasket can allow warm air to enter the compartment and cause frost to buildup.
If there is a miscommunication within your freezer, a reset can possibly correct this issue. I recommend that you reset your refrigerator by unplugging it for 10 minutes. I hope this information has been helpful. -NS
Mar 04, 2015 | Electrolux Freezers
Is there any way to increase the section on the freezer door? It is the lower half of a fridge freezer unit.
There is not a suction to bring the door into seal. the closing is done at the hinges. Either the door is warped (twisted), or the door gasket has failed. To check this take a half sheet of paper and close the door on the paper at six inch intervals around the door perimeter. If you can pull out the paper easily at any point the door seal has failed at that point. take a close look at the gasket at the failure point. Is it crushed? if so replace the gasket. If there is a large failure point and the gasket is in good shape the door has been twisted. This can happen if you try to force the door shut with an obstruction inside. I.E. (large Turkey dish). This can usually be corrected by twisting the door back into shape, using the paper to test with.
Sep 18, 2014 | Refrigerators
Freezer door has mosture on the outside
You need to order and replace the door gasket. Also check and be sure there the hight adjustment is correct, meaning the door is centered on the opening and not off set to where it can seal.hope this helps
Aug 10, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My Kenmore frost free freezer is not getting cold enough, door seals correct and it is leveled the compressor is cycling fine and there is no ice build up, help
Hey Betty,
One suggestion is to check and see if your freezer's gaskets are in need of replacement. Cracked, torn, warped gaskets can be the cause of not being able to keep the cold in. We have universal gasket kits for residential coolers and freezers just click here to view our options. Or give me a call and I'd be happy to help!
- Nicole
1-877-442-7538
Sep 23, 2013 | Kenmore Freezers
Ge pfs22mi door gasket
This is going to be tricky so watch the video and tell me if the answer to you question comes out and resolved by the tricks revealed in the below video.. Sea Breeze
When you say latch can you tell me the part number of the latch you say that you need replaced? Here is a link to the parts you are describing HERE
GE Profile French door bottom freezer Model # PFS22MISBWW Door Gasket and related parts
Apr 01, 2013 | GE Profile Bottom-Freezer Refrigerator...
Samsung french door freezer gets lots of frost inside - we've replaced the gasket but still get frost
Could be the rail slides not closeing correctly keeping door open slightly. Also they have made a new stronger set of rails to be used. Try going to the Samsung web site for tech info our recalls for that unit
Aug 18, 2012 | Samsung RF265AA Bottom Freezer French Door...
How do I replace door Gasket?
White plastic strip just to the refrig side of the center gasket needs to be removed first, then gasket pulled back enough to reveal gasket retainer. Use a flat bade screwdriver to pop out the white clips at the top and bottom allowing strip to be removed. Now gasket can be easily pulled out of groove. Be careful when re-installing clips to get springs in correctly.
Feb 19, 2011 | LG LFX25960 Titanium Bottom Freezer French...
Motor still running after gasket replacement
it will take at least 24 hours for the freezer to settle down to the correct temp -18c.the water is the frozen condensate that builds up inside the outer door over a period of time and should be allowed to drain away when you do a full 48hour defrost once a year....frost free means frost free where there is an air flow.....
Jul 21, 2010 | Amana ABB1927DE Bottom Freezer...
I have an upright freezer and replaced the rubber gasket around the door. It is not sealing correctly and ice is building up and also, water is leaking from the bottom of the door. It is a Fridigaire...
ice on top of freezer door they came out with a fix but does not work two vent holes on bottom of door seal mthem off with silicone moisture getting in if that don't work you need to take liner off and spray foam the liner cavities
Jun 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer door is accumulating frost inside it at the very top. Frost build up has been occcuring for 7to 10 days and we have been removing it periodically. Freezer purchased on 6-23-05. The gasket appears...
The gasket is not sealing correctly and is allowing warm air to meet cold air just below the seal.
Get someone with more skill to fit a new gasket , preferably one made by the original manufacturer , which should fit unlike some of the parts made by third party suppliers
Jun 11, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
