Question about Motorola Mobility RAZR V3i Cellular Phone
How to pair TCL bluetooth with V3i Motorola - Motorola Mobility RAZR V3i Cellular Phone
V3i how to instal game&themes
well.........you can download the games, themes from the internet and send them into your mobile
For games check these site
http://www.gamemobile.co.uk/motorola_v3i_games.htm
http://www.mobilerated.com/motorola-razr-v3i-games.html
For themes and apps
http://www.mobileheart.com/cell-phone-themes/819-Motorola-RAZR-V3i-Themes.aspx
http://gallery.mobile9.com/c/motorola-razr-v3i-themes_289/1/
http://www.mobilerated.com/motorola-razr-v3i-home.html
http://www.mobileheart.com/cell-phone-softwares/819-Motorola-RAZR-V3i-Software.aspx
send the applications via bluetooth or usb wire
Aug 22, 2009 | Motorola Mobility RAZR V3i Cellular Phone
My computer unable to readmy motorella v3
you have got 3 option
1. bluetooth enable phone and computer, make the pair and thats all
2. a seperate bluetooth adopter which connect to the computer and make pair to your phone wirelessly.
3....a software and cable for your phone. load the software in to computer and connect your phone to the computer via cable.
thanks
khan, south africa
May 04, 2009 | Motorola Mobility RAZR V3i Cellular Phone
BLUETOOTH INSTALATION
Be sure to follow every step to setting up and connecting a bluetooth device to your phone.
http://www.askdavetaylor.com/cant_pair_bluetooth_headset_with_motorola_razr_phone.html
Apr 08, 2009 | Motorola Mobility RAZR V3i Cellular Phone
I cant listen to music connecting my bluetooth
check out that is the phone's bluetooth is properly paired with the bluetooth headset if not check it
or
search for the bluetooth devices from the search list of the bluetooth devices in the bluetooth menu of your phone
Mar 09, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Motorola V3i phone tool free download
what I need to know is where can i get free download for Motorola V3i phone tools to use my phone as a modem. Thanks. Richard.
Jul 14, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Connection problem pc to moto v3i
hi, please enter any number say for example, 22
then on the other device when it asks for the pairing code enter the same number ie. 22.
hope this will solve ur problem
Jun 21, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Blue Tooth Pairing
I think that you are usiing an uncompatable headset or your doing it wrong.
How to pair your Bluetooth Head Set:
  1. Turn your Bluetooth on, on your phone.
  2. Turn your Head-set on.
  3. On your phone, in the bluetooth menu; go to "Look for Devices".
  4. Your phone should automatically detect the headset and allow you to connect.
Try http://carphonewarehouse.com to see if your bluetooth head set is compatable.
Jan 02, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Bluetooth
when you go to connection make your bluetooth visible and make sure the BT is on then search for available devices then pair with them.
Nov 01, 2007 | Motorola Mobility RAZR V3i Cellular Phone
My Motorola V3i Buetooth will not connect as is it permanently busy.
try to use the service after removing the memory card and than try, if the same problem presist than the problem is with the BT connector, it will be solved by any local vendor nearby u, and if it works after pluging out the memory card than format the memory card once and than try...... take the bacup of ur data first.
Oct 15, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola V3I
DONT TELL ME THAT U HAD CONNECTED UR HANDS FREE OR PAIRED UR PHONE WITH A BLUETOOTH EARPHONE AND FORGOT TO PUT IT IN UR EARS ok if ur not that dum then try this first if u have a recording software in it try to record ur voice and hear the play back if this step goes right then its some IC (handset circuit or programme) problem get in touch with the nearest motorola service provider
Mar 20, 2007 | Motorola Mobility RAZR V3i SLVR L7 L8 OEM...
Motorola Mobility RAZR V3i Cellular Phone Logo
37 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
