Question about Ovens
Duo-therm brisk air AC unit leaks water into my RV when it rains
When it rains, my duo-therm brisk air AC unit leaks water into my RV. I used my AC this summer with no problems.
    Sergeant:
    Champion:
  • 289 Answers
Take the cover off and make sure the drain line is clear on top off RV.
Posted on Nov 15, 2009
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
Dec 19, 2015 | Thermador C272 Electric Double Oven
Condensation between the two glass in oven door frigidaire
Bad seal. You may have to get new door
Nov 18, 2014 | Ovens
Cleaning roof of oven, does the can the element be removed
Oven roof is made up of metal normally and i think Liquid Roof is best for repairing leaks. You should have a look at it.
Liquid Roof AND RV Roof Coatings
Mar 24, 2014 | Bosch HBN 131560B / 131520 hot-air...
Amana pth153a35ac
The first 3 answers were from idiots. If a person had read her problem they would understand that it is not a oven / stove, but a PTAC unit that heats and cools a room. This type of unit is what is commonly seen in hotels and motels where the individual heating / cooling system is in each room.
Nov 29, 2013 | Ovens
Kitchenaid double digital convection conversion oven keypad went out. Any ideas on the problem. Electric panel circuit breakers are okay. Sharon C.
I think these use the same controller board as the Jenn-air units, they have a weak capacitor (C3) on the control board (Timer/control Display). Remove the top panel and look for a discolored or leaking capacitor (usually black about 1/2" high 3/8" in accross). Replace the capacitor and the problem goes away, until next time you use the self clean cycle which seems to overheat the control board and ruin the capacitor.
Sep 23, 2009 | Electrolux 30" Built-In Double Electric...
Amana oven doesn't heat
IS it gas or electric? If it's gas, you may need to have a technician regulate the air and gas. If it's electric your t-stat may need to be replaced. Hope this helps! :>)!
Aug 14, 2009 | Ovens
Pilot light still going out
If this oven has a "stack" (where the hot gases & heat vent to your hood) air could be blowing down the stack affecting the pilot. Simple test, Bic lighter lit at the top of the stack in the middle of the opening. If the flame is being sucked down the stack, then you have air blowing the pilot out. How old is the thermocouple on this unit ? Pilot flame heats this up to send a signal to your main gas valve to open up so the burners light. A weak t-couple could be your problem. Hope this helps
Jul 23, 2009 | Bakers Pride FC-616 Gas Single Oven
Water leaking on cooktop when using oven.
is there a fan for venting with this unit, if there is you will need to turn it on while cooking, it helps dissipate any steam or oil particles that move into the air, hopefully this will solve your problem, if you do have a fan and it is running, you may want to check the screen and clean it,as build up will cause the fan feature to not work as intended, thanks for your question,
mr.grzz
Jan 23, 2009 | Ovens
Turning off oven.
The fan only comes on in the back of the oven when convecting and Automaticaly turns off when you open the door. The exhaust fan coming from the front stays on for qutie a while, maybe 2 hours or so till the oven cools. I think it is just a function of the oven. A good thing in the winter but uses a bunch of airconditioning in the summer
Oct 23, 2007 | Electrolux ICON 30 in. Double Wall Oven
Ovens Logo
195 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
