Question about EuroTech Dryers
My eurotech dryer spins but won't heat, it goes
The dryer when u put u turn it on automatically goes on the delicates mode and it won't heat, it's suposed to go on the delicates if you press a button but even when I don't It starts like that
  • 3 more comments
  • chokinga2000 Nov 15, 2009
    Basically u r telling me to get another dryer please tell me if there is another reason why goes directly to delicates and won't heat
    Sn 20051702209 - 020477001- 02
    P1/20500486
    Model edc158
    20051702209-02047701-02
    Edc158
    20051702209-020477001-02
    How much is the control
  • 6,784 Answers
Hello. If possible, i will need the entire model number. This is very important. Without the entire model number, i will not be able to diagnosis the issue with accuracy. The model number will , also, allow me to direct you to the correct replacement parts ,as well.
Thanks..
Posted on Nov 15, 2009
  • 1 more comment
  • Michael Masters
    Michael Masters Nov 15, 2009
    Thanks, i will return with a solution shortly.
  • Michael Masters
    Ok, this is a control issue. The control sector may be damaged. To confirm, i will need you to preform a hard reset. This may correct the issue, if the damage isn't severe. To confirm the damage, simply shutdown the appropriate circuit breaker for five minutes. This will drain all stored power from the unit, and force a hard reset. You can, also, simply unplug the unit for this time, as well. After the five minutes have passed, simply re-introduce the power to the unit by plugging the unit back into the power socket, or moving the circuit breaker back to the on position. Once power is on again, try to run a drying cycle once more. Observe the units actions carefully. if the error continues, This will confirm that the control sector is damaged. It must be replaced in this case. the control sector can be a control circuit board, or a timer mechanism, as well. replace the control sector asap, if the error continues after you have preform the reset.
  • Michael Masters
    The control unit for your model will cost $170. 56. The price may vary, depending on where you purchase it. Normal price range will $170.56- $197.00
    It is recommended to order this control directly from the manufacture(euro-tech), pr the purchasing location.
  • 22,246 Answers
The control panel must be computerised with some sort of chip circuit and this circuit has got a headache or something like it because the chip controling it all has obviously developèd a fault so the only answer is to remove the control board and renew it.This sort of problem with computerised equipment is normally caused by brown out ,where the voltage has dropped below a certain percentage of the 220v say a drop caused by overload on the main supply dropper transformer .Then you fridge can burn the motor out ,this happens to your drier or washing machine ,lawn mower evan your tv.Conputers are not hit very often because of the fancy power supply that can correct the output voltage .But your drier ?? connected straight to the mains.And yes i am aware that america uses 120v so s coresponding voltage drop is evan more lethal to domestic appliances
Who services eurotech dryers near zip 98368
Clean out your vent before calling a repair man.
Apr 18, 2012 | EuroTech EDC158 Electric Dryer
My dryer spins but do not heat up...why is that
Main element disconnected or, burnt out. Disconnect cord, remove back panel& check that element is connected at all places. If broken element--you may stretch it a bit & attach both pieces together. Test before putting panel on, but stay clear--keep it away from ANYTHING flammable!
Feb 13, 2011 | EuroTech EDC158 Electric Dryer
It works but no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 21, 2010 | EuroTech EDV158 Electric Dryer
My EuroTech dryer turned on for a second then I heard a popping noise and it turned off. I noticed at the bottom of the dryer (right side) looking through the vent, I saw a spark. What is wrong? I do not...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The electric heating element broke and is touching the metal and shorting out...
heatman101
Sep 13, 2010 | EuroTech EDC158 Electric Dryer
Suddenly drier spins ans work as usual but does not heat up. therefore, clothes are not dried even after three hours of spin.
heatman101
Aug 29, 2010 | EuroTech EDC158 Electric Dryer
Won't heat up all of a sudden
heatman101
Mar 08, 2010 | EuroTech EDV158 Electric Dryer
Beko tumble dryer not drying. drum goes round but it doesn't get hot. Model DRCS68
go into service mode and reset
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
Apr 23, 2008 | Dryers
Dryers Logo
49 people viewed this question
Top EuroTech Dryers Experts
Tim Whalen
Colin Stickland
Colin Stickland
Are you an EuroTech Dryer Expert? Answer questions, earn points and help others
