When i start up the system it comes ut sterting and then flashes black and grey and wont dtert thankyou
    Problem Solver:
  • 7 Answers
I had a really hard time reading the question but it sounds like your computer won't start it just goes black after reaching a certain point in its start up process. if you tried to install a new os then the problem is either the processor or the graphic card can't handle it. if thats the case switch to an older os or be s.o.l. if you installed a new program the problem is your graphic card and reset it to default. restate your problem with some more specifics and proof read it this time and i'll try to help next time. trust me computers are easy with the right info.
Posted on Nov 16, 2009
My envoy wont start turn key and everything works but wont start
What ????? i try to sterted manuely and it start but turn off the light stays on with the ignition. What light stays on ????
i try to sterted manuely ???? I try to start it manually !!!!!!! You need to take your vehicle to a qualified professional technicia .
Jan 23, 2018 | 2005 GMC Envoy
My toyota hilux pickup wont stert changed diesal pump and still wont start
Being a diesel, and changing the pump, you de pressurized the system. . Sometimes near the fuel filter they install a pump, or on the side of the motor near the fuel line. . It's like an old coleman stove. There should be a rod to pump the pressure back into the system. You may want to look at that route. If the truck ran after the fuel pump was installed and you let it sit a day and won't start, I would re check the tightness of the bolts and filters. Sounds like you have air in the system. Remember diesels run on pressure. Good luck let me know if this helps you
Jan 11, 2013 | Cars & Trucks
Hidden objects
click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
hope it helps
May 01, 2012 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
2002 yukon wont start
Ok you might need to open and close your key switch about ten times before trying to start it. Off position the on position, not start but on then off. Ten time.
Nov 26, 2017 | 2002 GMC Yukon XL
My Bostitich air compresser wont start to refill
I would suspect that your pressure switch is defective and should be replaced
Dec 04, 2009 | Air Tools & Compressors
Screen goes black then flashes grey to black.
you are right: resolder the power connector
Nov 06, 2009 | Dell Dimension 8300 PC Desktop
Dell Latitude XT2 fails to start up.
I know this is an old post, but the LED code for CAPS lock on, F4 flashing, F5 on means memory issue. I had this issue, reseated the memory, and the issue was resolved.
Sep 23, 2009 | Dell Latitude XT2 Tablet PC
Chevy cavalier z24 theft system light on
This is a easy fix. Lucky just follow the procedure and your car will start. This is a theft system shut down.
The procedure is. Disconnect battery for a minimum of 30 seconds. ( one post is OK. )
Reconnect battery and get in the car and start as usual 1 time only. When it starts and stops letthe key just return to run position as if it was running. Do not shut it off and if you do you must stert the procedure all over again. i usually put on the emergency brake before i start and that shuts of the driving lights etc.
Just leave the key in on running position and go have a coffee. it takes 15 to 20 minutes for the car to recycle the system. When you come back to the car the flashing theft light will either be off or solid.
Try to start again. If it doesn't go shut it off and turn back on and start as usual. It will start and run and stay running.
The reason you have this problem is something electronic was disconnected whe the battery was hooked up. always disconnect the battery before you touch anything electronic and you will not have this problem.
Apr 03, 2009 | 1999 Chevrolet Cavalier
Need to reset as I broke the cycle and now cant get it to display any time at all or start. there is what looks like a key flashing. thankyou
thankyou for your email.   yes I have solved it...it was a simple matter, and Bosch are extrememly helpful       Paddy Grey
Jun 24, 2008 | Bosch Washing Machines
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
