Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Saw will not stay running i just put all new gas in it also new air fillter gas fillter
I got a Tory Bilt weed eater the Model-TB2OCS and I just put in new fuel linds and a new fuelter.
Verify that the new gas lines are on the carb correctly and the bulb is holding gas. If that is ok then the carb is needing to be rebuilt because one of the jets is plugged up or both. If you pour gas in the carb and it starts and runs for a short time then the carb is probably the problem. You can buy a rebuilt kit for them cheap.
May 21, 2017 | Garden
How do i set air on husky 435 saw to fix boggy runnin
Mitch:
Adjust the fuel and air mixture screws while the saw is running... you'll find that "sweet spot"... it just takes a little patience! Small adjustments... If you over adjust and the saw quits running or starting, GENTLY turn both screws in all the way (don't damage the needle valves or seats) and turn both out one and a quarter (1 1/4) turns out. The saw should start, then adjust from there.
Jan 01, 2013 | Husqvarna GAS CHAIN SAW 435 16"
Gas weed trimer will not stay running/clean gas lines/new fuel gas fillter/new gas/oil
Try checking the sparkplug wire. They sometimes get loose and don't make good contact. Clean the contact, if it is corroded, clean with a wire brush. The Spark plug may need to be replaced, be sure a new spark plug has the right gap size (you can adjust that yourself). Beyond that, I would take it in for servicing.
If it still does not keep running, check for leaking lines. If there are air leaks around the carborator, it will run rough and not for long. Hope that helps.
May 02, 2012 | Garden
06 Nissan Pathfinder put gas in empty tank but it wont start
if your engine is TD27 turbo, replace you fuel fillter and replace with new one. fill up with your new fuel filter with your gas before installation. tighten if firmly, make sure no air/gas leak. then pump it manually. stop pumping until you fell that fuel line has no air inside or hard to pump/press.
Jan 24, 2012 | 2006 Nissan Pathfinder
Mine will not start without dowsing the air cleaner with a little gas... then it wont stay running for more than 5 to 10 sec.. i replaced the plug, checked it for spark... there was plenty of spark....
If you are putting fuel on to th fillter and it fires it sounds like the choke is not working right. Take of the air fillter and look to see if the butterfly is fully shut when pulled on. If it is a primmer pump look in to see if there is any fuel comming up when pumped if they are both working then try putting fuel into the plug hole and see if it fires if it does then it is a fuel problemTake off the carb again know you said it is clean but remove the main jet valve in the centre of the carb and clean it every hole blew out and 100% spot less rebuild carb and refit to mower hopefully that should short you outl davidson lawn mower tech
Feb 02, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I ran out of gas, after we put gas in it started I then went to the gas station got gas and now it won't stay started. Could it be the fuel fillter?
Could be the fuel filter, could be clogged injectors, could be the fuel pump going out. You need to do a fuel pressure check to find out
Oct 08, 2010 | 1994 Jeep Grand Cherokee
CHAIN SAW WONT STAY RUNNING
PLEASE stop shouting and provide a model number for your saw. I will provide an IPL with some fuel system detail and a schematic to use for hose replacement. Reply below. Lou
Mar 15, 2010 | Homelite Garden
I HAVE A 2 YR OLD STIHL 460 CHAIN SAW THAT QUIT IDELING WHILE CUTTING FIRE WOOD. I HAD RUN THE SAW APPROX 1/2 HR BEFORE THIS HAPPENED. I REFUELED, BUT THE SAW WOULDN'T START OR EVEN FIRE. I PUT A NEW PLUG...
The damage may have been done before this tank, or can of gas, Does anyone else have access to saw?
Only about 3 things can cause damage,
1, dirt or foreign object entering cylinder.
2. Unmixed gas or old gas the will cause gumming of rings.
3. overheating of cylinder due to clogged air fins.
Ok there probably a couple more but that is main things.
Put a new Kit in it and keep it away from everyone else. Or have your friend replace only what is needed if the cyl cant be saved.
Saws should have a trigger lock so no-one can borrow them.
Bill Czerkie
Feb 03, 2009 | Garden
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
109 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
