Question about Motorola Mobility i776 Cell Phone
My i776 turns on, but only has a white screen on both inside and outside screens. How can I fix this?
My boost i776 says rss sim in session how do I fix
If you encounter any problems such as your phone displaying "RSS--SIM IN SESSION" then contact iDEN Customer Support at 800-453-0920.
Feb 08, 2010 | Motorola Mobility i776 Cell Phone
My Boost Mobile i776 broke about a month ago, the buttons wouldn't work the call button would be 9, the 2 a 7 and so on. Well then it worked suddenly, so I was using it and yesterday the same thing...
Sounds like the internal software took a dump. I too have the i776, and unfortunately Motorola even realized that this phone is more problematic that the Windows Vista op system.
Unfortunately, the only solemn advice I can give, without sounding like a *****, is to remove the sim and battery...let it sit for an hour, reinstall sim and battery, try to turn it on, and master reset it. If it wont power on again, you have a paperweight now. Sorry....I know its not what you want to hear, but the 776 is a problem laden unit.
Nov 23, 2009 | Motorola Mobility i776 Cell Phone
White screen when turned on inside and outside
The cable that connects the screen to the phone is damaged, causing it to white screen. Other than sending it back to the manufacturer or having Nextel fix it, there's no fix other than for it to be swapped out.
Nov 18, 2009 | Motorola Mobility i776 Cell Phone
Inside screen in black, outside is white
s see for software updations for your mobile in google & u can download it & install it in your mobile via data cable
Jul 17, 2009 | LG enV VX9900 Cellular Phone
Screen goes white all the time
There might be a problem with the LCD of the phone, you need to have it checked with a technician. I'm not sure if the phone got damaged due to direct heat of sun light. The phone's LCD is also sensitive and can only take mild heat. Might as well take it to a local techinician and have them evaluate the phone's LCD for you.
Jul 06, 2009 | Samsung SGH-E900 Cellular Phone
My Razor Front screen wont work
you will need to replace the LCD on the phone.
Jun 27, 2008 | Motorola Mobility RAZR V3
White screen
I had this problem too. My razrs screen would just go white every 15 minutes maybe, and i would have to turn it off and back on.There was a white line at the bottom of the screen also, so i went to http://direct.motorola.com/hellomoto/motosupport/source/SoftwareUpdateSummary.asp?country=&language=&web_page_name=SUPPORT&strCarrierId=US%20Cellular&strPhone=V3c&strCable=Mini%20USB%20Data%20Cable and downloaded thee software update. after it was finished the white line went away the screen never went white and it fixed everything
Sep 03, 2007 | Motorola Mobility RAZR V3
Blank screen
Aug 27, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola RAZR V3 Cellular Phone
Ok so when I close my phone I still see the time and my background picture but no light immanates (hope I spelled that right)from the screen if thats what your saying that's normal. Now as far as the inside screen if you dropped it the connection that lets the phone know it's closed may be jarred lose and offset (not sayin u dropped it)although you say it dims. When you close your phone the inside screen should turn white and then turn off just barely have your phone open to check, if it does this then the connection is working. And you need another opinion.
Dec 07, 2006 | Motorola Mobility RAZR V3
Motorola Mobility i776 Cell Phone Logo
544 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
