Question about E-Machines eMachines Desktop PC
I can't get onto our administrative account. we type in the correct password and it tells us that the account cannot be loaded.
  • 460 Answers
If no access through windows then it has to be thru. the bios. it is not a good thing to setup admin. account through windows. usually the password gets scrambled through time and use of the computer likely by bugs or hackers...
Posted on Nov 15, 2009
  • 585 Answers
Press F-8 at boot to get into the options and try accessing the account from safe mode. If that fails, your system has problems, and I hope that you have saved a recent restore point for system restore.
Unlock code password
Please be more specific about which unlock code you need. If you can not sign into your windows account; you may be able to get into your computer using the built in 'Administrator' account. Restart your machine, and hold F8 while it loads. You should get a black and white menu asking if you'd like to start windows normally or enter into safe mode. Choose one of the safe mode options, and log in with the Administrator account.
If you can not get the menu to show up, try unplugging/turning off your machine while windows loads, and then restarting it, it will pop up saying that windows was unable to start correctly, and will ask you what you want to do. Safe mode will be one of the options under that menu as well.
If the built in administrator account option does not work, try going into 'Safe Mode With Command Prompt'.
In the command prompt; we will create a new user for you.
In the command prompt, type 'net user *NEW_USERNAME* *NEW_PASSWORD* /add ' , obviously *NEW_USERNAME* should be the username you want, and *NEW_PASSWORD* should be the password you want.
Then, type in 'net localgroup Administrator *NEW_USERNAME* /add', which will add the account you just created as an administrator. Restart the machine, and this account should show up as an option to log in with the username and password you just set.
Dec 17, 2013 | HP Mini Computers & Internet
Tip
Little trick help you to reset Windows Password!
Method one: Login with the default administrator account
Step 1: Start Windows PC
Step 2: When you can see the Windows login screen, press ctrl+alt+del keys Twice and it’ll show Classic Login box
Step 3: Type Administrator as Username and leave the Password field blank
Step 4: Press the Enter Key and then you can be able to login the default windows administrator account which is it created by default when install windows.
Note: When you input the key combination Please don’t put the cursor on any account. And if you change the name or password before, you cannot login by this way.
Method two: TRY command prompt about password reset trick
1. Log in with any valid account.
2. Bring up the command prompt.
Type: net user
You get a list of accounts
Type: net user Administrator *
Type: net user (any account on that list) *
3. It prompts for a password. Enter one, then enter it again when prompted to confirm.
Now, try to log on as ‘Administrator’ with your new password. *
Please note that this might not work on a LIMITED account .
Method three : use a Windows Password Recovery cd
1. Visit the windows Password Recovery tool official site: http://www.windowspasswordsrecovery.com
2. Download the tool and run it
3. Burn the password reset cd to a blank CD/DVD or USB flash drive
4. Turn to the computer which you lost password, reboot it, insert the nearly created recovery disk.
5. Click Del key to load bios setting, set the system load from cd/dvd or usb, save the change
6. reboot the computer, load the password recovery software
7. select the windows os installation folder, select the user accout , reset the password
8. finish. you can login windows with a blank password now.
on Jul 12, 2010 | Computers & Internet
Tip
Little trick help you to hack Windows Password!
little trick that might help you!
Step 2: When you can see the Windows login Password screen, press ctrl+alt+del keys Twice and it'll show Classic Login box
Note: When you input the key combination Please don't put the cursor on any account. And if you change the name or password before, you cannot login by this way.
Type: net user
Now, try to log on as 'Administrator' with your new password. *
http://www.windows7password.net/
7. select the windows os installation folder, select the user accout , reset Windows 7 password
on Jun 29, 2010 | Computers & Internet
How can i recover my administrator password on windows xp if i forgot it
You could do the following; when you boot up, the screen will tell you to press ENTER if you want to get into the operating system RESTORE MODE. When you set up your system you will have saved configuration settings, and hopefully, you would have carried out a number of saved "BackUp's" of your HardDrive as you used your computer. If you did, you can carry out a 'Go Back To A Previous Setting'. You will lose any files you created since that previous time but it does get you back into your drive. Did you not create an Administrators Password BackUp Disc? If you did use that. Good Luck. George
Mar 31, 2013 | Dell Dimension 4600 PC Desktop
Forgot my username password so cannot get onto my pc at all, any help would be much appreciated.
AnyPasskey Windows Password Recovery would be your first choice! This easy-to-use yet powerful Windows password reset tool could reset any account passwords, including Windows local administrator, Domain Administrator and other user account password, etc. instantly by creating a bootable CD/DVD or USB drive on all Windows OS, such as Windows 7, Vista, XP, 2000 and Server 2003, 2008, etc. Just in minutes, no need to re-install Windows or formatting hard disk, you can get access to your computer again without any data losing or file damaging. Pretty easy procedures even it is your first try. 6_19_2012_2_15_03_am.jpg
May 17, 2011 | Microsoft Windows Vista Ultimate Edition
Tip
Change XP Password
I generally don't like telling people how to change passwords because they can go doing it to other people but for some people this is a life saver.
First of all you will need access of a account on the same computer. Unfortunately I haven't found a way to do it without going onto xp. If you don't have any other accessable accounts then try the administrator account unless it's in use as your account. If you can't see follow the instructions below. If you have got access skip this group of instructions and go to the next steps.
Get into administrator account:
1.) When starting the computer, press F8 continuesly until you see a black screen with writing saying how would you like to startup windows.
2.) Go to safemode with command prompt and click enter until you see the bootup screen(windows logo...).
3.) It should have the administrator account along with the one that you have locked. Go into the administrator account and if there is a password on that you'll have to know it from the company that gave you the computer because they generally put a password on it.
Change Password:
Once you're in the account you'll see a black screen with writing.
1.) type in net user.
It will come with a display of user names.
2.) With exactly the same format as on the screen(Uppercase/Capitals), type the users name after net user and a star as a new word after the name(e.g. net user Tommy *)
3.) Just type in the password you want to change it to and confirm it by typing it again.
Once you're finished just type shutdown /r and it'll reboot like windows normally does.
Please tell me if this was useful.
on Jan 01, 2010 | Microsoft Windows XP Professional SP2
My account as a administrator is gone for any reason ,maybe went I tried to open another account with an standard type password I overwrite my administrator account.Now I end up with two standard accounts...
For administrator account recovery, turn on your computer start tapping F8 key and the Windows Advanced Options Menu screen will appear. Select safe mode using arrow up or down key then press enter then press enter again to select the operating system. Wait for the loading which could take about 3-5 minutes to load the safe mode.
For system restore: Click Start, Click all programs, Click accessories, Click system tools and click system restore. Here is the video on how to system restore,
Turn on your computer start tapping F8 key and the Windows Advanced Options Menu screen will appear. Select safe mode using arrow up or down key then press enter then press enter again to select the operating system. Wait for the loading which could take about 3-5 minutes to load the safe mode.
Click Administrator to enter that account and click Yes to start running on safe mode, after loading go to control panel and click user accounts. Click create a new account and type the name of the new account and click next. Now pick an account type select administrator then click create account. Restart your computer and when you prompted on your user accounts click the admin account that you made and you have the admin account have a nice day.
Mar 19, 2011 | Computers & Internet
Windows xp pro logon error message "unable to log you on because your account has been locked out"
Hey!
If your computer is a part of a business network, you should contact the network administrator so he/she would setup or reconfigure your user account correctly.
If it's a home computer, you'll have to log on as Administrator to unlock your account. To do so:
  1. Click Start -> Log off (user name).
  2. Press Ctrl+Alt+Delete twice.
  3. Type Administrator in the user name and fill in the Administrator account's password. Leave blank if there isn't any.
  4. Once logged in, Click Start -> Run...
  5. Type in: LUSRMGR.MSC and click OK.
  6. Double-click on Users folder.
  7. Double-click on your locked user account.
  8. Uncheck "Account is disabled" and click OK.
  9. Close "Local Users and Groups" window.
  10. Click Start -> Log off Administrator.
  11. Login to your user account!
Note: If you don't have access to the Administrator account (because you don't have the password), please do tell and I'll give you the instructions on how to reset it.
GOOD LUCK!
Pelu.
Apr 06, 2010 | Microsoft Windows XP Professional
Passward broken
Unless you can get hold of a Linux password recovery program to reset or remove the password from the Windows Administrator's login, you will need to reinstall Windows again, the device drivers and your programs.
In this process you will lose all your data that is stored on your hard drive.
If you want to save your data before you install Windows, remove the hard drive, connect it to an USB hard drive adapter (most likely you will need power to the hard drive) and plug it into the USB port of a working computer. This computer will see it as an external hard drive, copy your data you require so you can load it back onto your computer after you installed Windows.
OR
You can connect your hard drive into a working computer on the 2nd IDE controller, then you can see this drive and copy your data files.
May 21, 2009 | Dell XPS M1330 Business Laptop, Crimson...
I have purchased windows XP SP2 CD and loaded onto my existing windows XP SP2 beacaue DLL cache had been removed it is now asking for the Administrators Password for the old XP how do I obtain this,...
While you enter the windows when the welcome sreen comes and ask you to password in the administrator account now press Ctrl+alt+del key. Then the username and password comes. In the username type "guest" and no entry in the password. Now you can enter into the windows and change the administrator password or create the new administrator account and try it.please inform when the new prob occurs.
May 05, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
62 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
