Question about Acer Aspire 5500 5570-2609 Laptop
Touchpad is detected and said to be operating correctly but it doesnt work?
Touchpad finger enables
If you ever put your own operating system on you may not have installed any touchpad drivers. To find it download all motherboard drivers for that make and model and operating system. If you upgraded your operating system without researching whether drivers were even made for that OS then they likely didn't. If you have the original OS then go to control panel find touchpad and choose as default or whatever.
Oct 28, 2013 | HP Compaq nc4400 Notebook
Touchpad doesnt work
Try reinstalling the touchpad driver.
You can download the touchpad and device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Please click on this link: -
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
May 03, 2013 | Toshiba Satellite A135-S4477 Notebook
My dell inspiron 1440 mouse pad doesnt work
You should go to http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INSPIRON1440&os=WLH&osl=en&catid=&impid=
download the drivers for your computer but if the problem still exist ,the touchpad may be bad and you will need to replace it.
Aug 16, 2010 | Dell F3534 Touchpad
Touchpad doesnt work.
if ur touch pad not work than after install .driver of touchpad,ok than it is propearly work done.
Apr 03, 2010 | Acer TravelMate 6291-6753 Notebook
The touchpad of my msi pr400x stopped functioning
You should makes sure you have the touchpad enabled. This is usually Fn F5 or whatever key is assigned to the touchpad. This is indicated on the F1-12 keys by a little blue icon. Hold the Fn key, and hit the corresponding key. Check to see if it turns back on. If the touchpad still doesnt work, you've got a hardware problem.
Oct 19, 2009 | Computers & Internet
Touchpad does not work
in such case you can restore your program to old date...such as 5 days before.. hope your touhpad will work like before..
restore your program to the early date from when your touchpad was working...
reinstall touchpad driver....
otherwise you have to reinstall your Operating System...
Jun 23, 2009 | Acer Aspire One Netbook 8.9" Notebook
Scroll wont work
Hi
Browse to the below given website.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_PM_1525&os=WLH&osl=en&catid=&impid=
Choose the operating system. Download the Ricoh driver in chipset category and touchpad driver under Input Device Driver category. It must resolve the issue.
Revert back for any clarifications.
Warm Regards,
Zulfir Sadat M
Apr 11, 2009 | Dell Inspiron 1525 Notebook
The touchpad got locked
u can try this all u can do is just go to this website and click on driver detective scan now and then click on the download now and then restart ur computer and then the touchpad should work and still if it doesnt work then uninstall and resintall the touchpad driver and the synaptic drivers and restart the computer and still if it doesnt work replace the touchpad from dell...the website is http://www.drivershq.com/Drivers/VistaDevices/Dell-Input-Dell-Touchpad-Pointing-Stick-Driver/13926/Drivers.aspx ................... thanks
Jan 22, 2009 | Dell XPS M1530 Laptop
Ibm t42 thinkpad turned off touchpad in system tray
Any idea why the USB mouse isn't detected? Is it a Special series of mouse needing software?
Does the laptop have a PS/2 connector, so you can try using an old PS/2 mouse and try with that?
Maybe with some short-keys (like Alt-Esc for the windows Start button), you can reach the software or config application that you used to disable the mousepad...
Try that one, and see if it helps you...
Nov 13, 2008 | IBM ThinkPad T42 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
19 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
