Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
MY WASHER FILLS UP UNTIL IT OVERFLOWS. WHAT IS
MY WASHER FILLS UP UNTIL IT OVERFLOWS. WHAT IS CAUSING THIS?
  • 5,911 Answers
The water level is controlled by the pressure switch which is located behind the load level selector knob on the control panel. Before assuming you have a defective pressure switch, however, read the following link:
http://www.fixya.com/support/r762094-washer_overflows
In many cases the small air hose on the pressure switch can come loose from the pressure switch and cause the symptoms you are experiencing. Check the air hose to ensure it is still attached to the pressure switch and check the electrical connections to ensure they are not corroded. If the air hose is intact, check the entire length of the hose from the pressure switch to the air dome on the wash tub to ensure it is not leaking anywhere. The air hose is how the pressure switch senses the pressure differential as the wash tub fills. Without it, and the pressure switch will not work. If you need to gain access to washer interior, follow these steps:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
Check the air dome on the lower right hand side of the wash tub. This is a small plastic air hose that runs from the wash tub all the way to the pressure switch. If this hose comes loose, the washer will start to leak as it fills. Simply reattach if it comes loose.
If you need an illustration of your washer and components, searspartsdirect.com, appliancepartspros.com, or pcappliancerepair.com usually has some excellent exploded view diagrams that you can refer to.
To reinstall the washer casing, follow these steps to ensure you get the case correctly placed and secure on the frame:
1. With the lid of the washer open, grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If these preliminary measures do not work, replace the pressure switch. If the pressure switch requires replacement, you can search for the best price at these web sites:
repairclinic.com
If you have questions, or require additional assistance, please let me know. I hope you find this information helpful.
Posted on Nov 15, 2009
    Sergeant:
    Champion:
  • 289 Answers
With unit unpluged,turn water on,if water come's in you have a bad inlet valve,if not than check rubber hose from outer tube to water level switch,if thy are connected than you have a bad water leaval switch.
Washer continuously fills
Not sure if you mean that it fills all the time and overflows or you mean that it just always fills and never has enough water.
The first problem would refer to a faulty water level switch - need to replace.
The second would be that the washer drains as it fills - if the drain hose is lower than the washer, inspect the anti-siphon valve.
Apr 10, 2014 | Maytag PAV2300 Top Load Washer
Washer occassionally overflows WATER DOES NOT SHUT
If you have a problem with your washeror dishwasher continuing to fillwith water after the valve has closed, then you this tip will help youunderstand why that is happening.
Here is a tip that will help you...
Washer orDishwasher Fills with Water when off
heatman101
Apr 22, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have a whirlpool washer LXR7244PQ4 that fills up and overflows until I turn the water off at the connections.
I guarantee your water level sensor is bad. It is not picking up the amount of water you have in the washer. Change it and it should be fixed. A vote is very much appreciated if you appreciate the solution. Thank you very much William.
Feb 26, 2011 | Washing Machines
Washing maching overflows
inside the washer is a fill valve it has a tube from the bottom of the tub leading to this valve if the tube is blocked with sope the washer over fills clear this tube first also if there are any holes in it it still over fills the washer, the valve works on air presher,,as the washer fills the air presher builds up in the tube and shuts this valve off stoping the flow of water into the washer,,,ok? sorry but me spelling is roten?
May 05, 2010 | Fisher and Paykel WL26CW1 Top Load Washer
Washer over flows with water and does not go into spin cycle
water level sensor is not working properly
with your solenoids to shut off water
Jun 02, 2009 | Washing Machines
My washer fills until it overflows...when I turn the dail to the wash cycle, it just drains and spins...
Most likely the water level switch broke or water level hose came loose, if the washer keeps on filling on after you turned it off, then is the water valve. Which brand is it?
Jan 20, 2009 | Washing Machines
Slow steady leak fills machine then overflows
three screws along back of machine top remove valve wires and screws remove inside hose and fill hoses..probbly have sand or rust in valve..be sure screens are in port and are reinstalled if ever removed to clean
Apr 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer constantly fills with hot water even when turned off.
Sounds like a bad mixing valve. To verify that it is the valve you need to turn off the washer when it is filling. If water keeps running, replace the valve, Cost is under $50. for most washers.
Jan 03, 2008 | Washing Machines
Washing machine overflows
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Sep 24, 2007 | GE WJSR1070A Top Load Washer
Lavamat 6955 sensorlogic - carries on filling until water overflows from soap tray
fault f1 is slow or no cold fill. this fault code with overfill points to: air chamber blocked with sludge hose from air chamber to pressure stat blocked or split pressure stat faulty of these the first is the most likely
Dec 12, 2006 | AEG Lavamat 88840 Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
123 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
