Question about Garmin Streetpilot ColorMap GPS Receiver
Data card acquisition problem.
The unit says it can't acquire the data card. Is the card bad? I heard these cards have a finite read/write lifespan.
  • Harold Levy Mar 26, 2008
    I'm having the same problem, I would love to know what the fix is. thanks
    Scholar:
  • 174 Answers
Howlong have you owned the card? Since Garmin switched to ROHS complience the cards seemed to be incompatible. Check with Garmin.
Posted on Jul 28, 2008
I accidently formatted photos and can not recover and if I save to SD card, then reset are photos deleted?
GT Recovery for Windows Download: www.gtrecovery.net.
Lost your photos on Android phone & need to recover deleted pictures, try GT Recovery for Windows- the World's 1st Data Recovery Software for Android smart phones.
It can directly recover deleted pictures, photos lost due to deleting, restoring factory settings, flashing ROM, rooting, etc., from SD cards inside Android devices. It let you preview the deleted photos before recovery. Watch the video tutorial to learn how to retrieve photos from Android phone easily with simple clicks.
Key features of Data Recovery - GT Recovery for Android:
1). Preview & selectively retrieve photos and video lost due to any problem
2). Support all Android phones/tablets, like Samsung, HTC, LG, Motorola...
3). Only read and recover the data, no personal info leaking, 100% safe
May 03, 2015 | Cameras
My sandisk micro sd card of 8 gb. when inserted to laptop showing that it got corrupted & to use it i have to format & all data in it will be erased. plz provide solution as it contains my valuable data.
First off we need to make sure that it's the Card and not your computer. Does your machine read other cards? If so go to the next paragraph. If you don't have other memory cards to try to find another computer to try your card in., or if you can read your card in another computer, or other cards can't be read in your computer then your computer has the problem, and I would reinstall the drivers.
If you card is the problem the only thing to try is to clean the contacts. Lay the card down on a flat surface; gently rub the contacts with a pencil eraser to buff the contacts. Be careful not to use as much force as to damage the contacts.
But finally, you've probably heard this before but, "All media goes bad." Removable media is particularly vulnerable due to the way most people handle it. I have all my important files in at least 3 locations. But I too learned this lesson the hard way.
May 17, 2014 | Electronics - Others
My brand new Garmin Approach G6 will not acquire a GPS signal. Is there some way to correct the problem?
All gps units need a clear view of the sky to collect enough data for a proper "fix". The less obstructions there are, the faster & more accurate the fix will be.
Initially, the first fix may take up to 20 minutes. Long acquisition times typically occur when the unit is powered up after being moved hundreds or miles or more since its last fix. This would be the case from manufacturing location in China where it was shut off to where ever you are now when you turned it on.
Acquisition times after this should be significantly less (10 - 60 seconds)
I hope this helps and good luck.
Jan 15, 2013 | Garmin Approach G5 Handheld GPS Receiver
The sound totally becomes muted when a data card is inserted in my laptop
There is a conflict between the data card and your sound system or it may require shared files that current sound system uses, there for muting it out so full access is acquired.
Apr 07, 2012 | Lenovo ThinkPad 570 (5703BUK) PC Notebook
How do i use songs from my sd card as ringtones
The phone is not designed to read data stored on a sd card. Acquire the ringtone from the network instead or upload the tunes on the SD card onto a computer to be saved to a network site from where to download to the phone which should have been connected by which time the network.
Dec 04, 2010 | LG Neon GT365 Cell Phone
I need help installing a map onto a gramin sat nav
No. They are refering to maps sent from the computer to the Garmin device. Maps are not transferred off the SD card to the unit. Simply insert the SD card into the device and the Garmin will read the maps from the card.
to double check follow these steps
  1. Power on the unit with the card in
  2. Press Tools
  3. Press Settings
  4. Press Map
  5. Press Info (or map info)
This page should list out both your UK and Ireland maps(old as dirt) and your new Benelux and France maps as well
Apr 20, 2017 | Garmin Nuvi 600 Car GPS Receiver
GPSMap 172c Can not read Garmin Data Card
I have the Sounder 178C. It will only work with 128 Mb Cards (or smaller). It does not work with the 256Mb Cards - says "Reading Card" forever.
Per Gramin, I had to buy the 128 Mb card and DVD map update. Then program the card with a USB data programmer to make it work.
May 01, 2009 | Garmin GPSMAP 172C GPS Receiver
Not seeming to read SD map Data Card anymore
I have seen this before, if you turn off the unit while its saving data such as your last position or your last destination, especially if you shut it down while its still navigating. the card data can get corrupted. the only way to fix this is to reload the map data. Fine Digital is out of business so I created a DVD that has the last issue of map data and firmware for these units. you can find this dvd on ebay by searching for finedrive dvd. its way cheaper than what fine digital used to sell upgrade dvds for ( $150)
May 02, 2008 | Fine Digital FineDrive 400 GPS Receiver
Garmin Streetpilot ColorMap GPS Receiver Logo
78 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
