Question about Maytag MSD2456G Side by Side Refrigerator
Burning smell coming from fridge maytag msd2454gr
  • Maytag Master
  • 1,606 Answers
Pull the refrig out and remove the back panel . On the side of the compressor , is the overload/relay . Carefully pry this piece off , as it will come off in pieces , due to burning . Part number 12002784 , is the replacement .
Posted on Nov 15, 2009
  • Mike Smith
    Mike Smith Nov 17, 2009
    The smell could also be the plastic liner , behind the inside rear freezer panel , melting or disfiguring , due to the heat from the defrost heater . You will need to remove the inside rear freezer panel ( 2 screws ) , and inspect the left and right side , by the heater . If melting or burning spots , Cut a 4 " X 8 " piece of aluminum ( I used the lower panel of a dishwasher kick plate ) , and insert on both sides , to block the heat from the liner .
Smoke coming from Refrigerator
Start components or wiring could be getting old and brittle. Take the back cover off. Its usually a cardboard cover with metal screws and inspect/repair the wiring.
Nov 08, 2013 | Maytag Refrigerators
Fridge has a burning smell
Are the coils clean by the compressor?
Nov 26, 2012 | Frigidaire FRS23R4A Side by Side...
I just bought a used Maytag Refrigerator MSD2454GR.I want to hook up the water. Underneath their are two(2) lines disconnected. One to the door and one to what looks like the drain pan.Is their a part...
there is nothing missing, the one to the drain pan is coming from the freezer, The one going to the door, is going to the water dispenser. If you pull the fridge out and go behind, you will also see one going up to the ice maker. At the bottom of the fridge in the back, remove the cardboard panel. Once removed you will see the water inlet valve with two lines leading from it. (The one going to the door and the one going to the ice maker. At the front of the water inlet valve is where the main connection gets hooked up to supply the water. Remember to use teflon tape or it will leak. Hope this helps
Mar 28, 2011 | Maytag MSD2436GR Side by Side Refrigerator
I have a burning smell coming from inside my kitchenaid superba side by side fridge. It smells like a burning plastic. The fridge still turns on and keeps things cool, but it started to kick out that...
Remove the power plug and move your fridge forward. Now look at the rear bottom side of the fridge to see if there are any parts that heats up. You can trace this to the smell emitting from the heated part and confirm. It can be the motor, contactor or the defrost timer.
Mar 18, 2011 | KitchenAid (KSRD22FKST) Side by Side...
MSD2454GR Side by Side refrigerator- freezer side fine, refrigerator side will not cool below 50 degrees; lots of condensation
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 01, 2009 | Maytag MSD2454G Side by Side Refrigerator
I have a Maytag side-by-side MSD2756GEB that quit cooling.
sounds like either the fan motor or the compressor. go ahead and open upo the bottom baclk panel and see if the fan is running or if the compressor is. could be just a burned wire.
Feb 07, 2009 | Maytag MSD2756G Side by Side Refrigerator
Burning Rubber smell coming from fridge
try taking the bottom panel off and vacuming all the dust on the coils. The dust may be heating up and burning. The coils are usually at the bottom of the fridge. Check to see if the fan is running also.
Jan 16, 2009 | Refrigerators
Maytag MSD2454GR
Im going to be honest with you,to me it sounds like 1 of 2 problems,
either you need a re gas on your fridge or you need a compressor.
Let a repair man take a look for you just to tell you what it is..
Sorry for this news.
Wouter.
Sep 30, 2008 | Refrigerators
Maytag MSD2454GR
compressor relay shot. needs ground wire to frame of fridge also.
May 18, 2008 | Maytag MSD2454G Side by Side Refrigerator
Maytag fridge made some clicking noises and then stopped cooling
For what it is worth. I had this problem twice and both times the compressor ad to be replaced. Ton this day it sounds like a pin pong game whenever it runs. No it is not the fans or the ice maker.
Nov 29, 2007 | Maytag MSD2454G Side by Side Refrigerator
Maytag MSD2456G Side by Side Refrigerator Logo
704 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
