Question about Samsung DV448AGE Gas Dryer
My samsung dryer's drying cycle ends early...way to early.
2 Suggested Answers
SOURCE: have a retangle showing as the dryer ends it dry
I have the same problem with my dryer. I noticed this rectangle that showed up on time dry and there wasn't any code that matched this in the manual. I called samsung and they told me to flip the breaker and see if that helps. I have not tried another load, but I hope that fixed it.
Posted on Dec 21, 2009
Samsung dryer only dries on timed dry cycle. And where is the light bulb in the dryer??
sounds like the timer is sticking in some cycles and works only in timed dry? as the points in other cycles are seized and stuck close? as for the bulb should be along the back wall of tub or near door
Feb 13, 2015 | Samsung Dryers
Why does my dryer end its cycle early?
depending on what type of model. there is a moisture sensor inside the dryer. when you use any cycle other than time dry. if it is a small load ( 2 -3 shirts) it may not touch that cycle. making the machine think that things inside are dry and cut the time short. you can try time dryer and see if that helps. to check if moisture sensor on you dryer is working some models will have a test mode to make sure its sensing. try pressing more time button, then less time button back and fourth. all lights should come on. then you can open door. and when put your hand across the moisture sensor usually near the lint trap. you should hear a beep. to indicate that its reading moisture, meaning good..
Sep 19, 2017 | LG DLG5988 Gas Dryer
The signal dings at end of drying cycle but dryer keeps on running without heat
The drier works fine and heats during the cycle and then when the cycle is over the heat quits but the drier keeps running? Does it shut off when you open the door?
Aug 08, 2011 | Samsung DV330AE Dryer
Dryer will not shut off in any 'auto' mode. Time display ticks down, then jumps up again and keeps running. Dryer does works properly when 'timed dry' is selected. Checked and cleaned exhaust vent. ...
How long is the vent from the dryer to the outside? Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dry-ability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 14, 2010 | Samsung DV337 Electric Dryer
Dryer wgd5300, takes a long time to dry. seems
The burner is supposed to05245ec.jpg cycle on and off all through the drying cycle. Over time the operator coils 279834 get weak and quit. They are really easy to replace. This short video show a normal Burst of heat from a dry and the normal length of time it fires off
May 19, 2010 | Whirlpool WGD5300S Dryer
Have a retangle showing as the dryer ends it dry cycle. Dryer will dry but the rectangle shows up about 1 minute before dryer ends it's cycle.
Dec 03, 2009 | Samsung Dryers
I have a Kenmore gas dryer, model 80. The burner ignites but turns off fairly early during the cycle. It gets warm for a few minutes, but ends up not drying anything. I am trying to narrow down which parts...
Make sure the lint filter and the exhaust duct are clear all the way to the outside vent. If the gas cycles once and then does not light again the thermostat may be defective. If the gas lights but then goes off when the ignitor stops glowing then the secondary coil on the gas valve is bad. (This ignition cycle may continue to go on and off but the gas will not be lit enough to provide enough heat for drying.) The coil assembly can be replaced.
Aug 12, 2009 | Dryers
Samsung dryer DV328AER doesn't turn off
My Samsung dryer 8KG (SDC3K801) is not turning off after completed the cycle time. The panel showing end but the drum still running. If I choose Synthetics extra dry with auto cycle time 49, when the timer at 6, the display increased again to 25. It's seem the dryer is not stopping forever. Any suggestion please!. Thanks
Jul 20, 2009 | Samsung DV328AE Electric Dryer
Whirlpool model # lgr7646ez3
Here are a list of causes that may contribute to this lack of sufficient drying.
CAUSE
• Lint screen is clogged with lint.
• Restricted air movement.
Exhaust vent or outside
exhaust hood is clogged with
lint.
• Exhaust vent is crushed or
kinked.
• One fuse is blown or circuit
breaker is tripped. The dryer
will appear to operate, but you
will not get any heat.
• Cycle Control knob or temperature
selector is set on air dry.
• Load not contacting the sensor
strips and automatic cycle
ending early.
• Fabric softener sheets blocking
exhaust grill.
• Dryer located in room with
temperature below 45ºF (7ºC).
• Large amount of moisture in
the load.
• Cold rinse water used.
• Load too large and bulky to
dry quickly.
Here are the solutions to combat the issues.
SOLUTION
• Clean lint screen.
• Run dryer for 5-10 minutes. Hold hand under
outside exhaust hood to check air movement. If you
do not feel air moving, clean exhaust system of lint
or replace exhaust vent with heavy metal or flexible
metal vent.
• Replace with heavy metal or flexible metal vent
• Replace fuse or reset breaker.
• Select the right cycle and temperature for the types
of garments being dried.
• Level dryer.
• Use only one softener sheet per load and only use
it once.
• Move dryer to a location with temperatures above
45ºF (7ºC).
• Expect longer dry times with items that hold more
moisture (cottons).
• Expect longer dry times.
• Separate load to tumble freely.
This will help you fix this problem. i suspect an exhaust obstruction.
Mar 11, 2009 | Whirlpool LGR7646E Dryer
Samsung DV448AGE Gas Dryer Logo
268 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
