Question about Samsung HT-X50 System
The display shows all the icons of the sytem and wont clear...
I turned on my HT-X50 system and found that my display shows all the icons and I can't figure out how to clear them. It shows all icons and 5 shaded box's. How do I get rid of this, I don't want to have to take it back.
  • 10 more comments
  • Anonymous Jan 20, 2008
    I am having the same issue. I am getting ready to take my system back due to there being no easy fix to this problem.
  • Minat1 Jan 20, 2008
    I have the same problem with my system. I am getting ready to take it back this week do to there being no easy fix for the issue.
  • suriles Feb 20, 2008
    Exact same problem. One morning woke up to find all the LEDs(?) on front display lit up, thus you can't know for sure what your really doing to the system. Tried the "unplug power for over a minute", but the problem persists. Also tried resetting unit with no change to display. Any other ideas? or is back to the store?
  • Big Papa Al Mar 11, 2008
    tried using the remote buttons, I have unplugged the system overnight.
  • jaaron64 Mar 23, 2008
    I have the exact same problem. I've had the unit for three months. I can't find my original sales receipt so I may be hosed. Has anyone found a solution. Power clear doesn't work regardless of how long you have it unplugged. Is there a possible combination of pressing keys and powering up to cause a hard reset?
  • nikdotcom Apr 17, 2008
    Same problem, called samsung support, they had me do a system reset: 1-make sure no discs are in tray. / 2- power on unit. / 3- hold stop button (on unit) for 10 seconds (this will power off unit). / 4- unplug unit from outlet. / 5- again, hold stop button (on unit) for 10 seconds. / 6- leave unit unplugged for 15 minutes. / 7- plug unit back in and power up to see if fixed.
    This did not resolve my problem, I am in the mist of now sending unit into samsung for repair. fun times....
  • Fitawav Dec 01, 2008
    I have the same issue, I guess there is no resolution other then to replace it?
  • eddierc2006 Jan 21, 2009
    Has anyone figured out how to clear all the icons off the system?
  • Bryan212 Jan 22, 2009
    Same problem happened today. I occured right after a statis spark when I touched the power button and the screen LED went all on. Samsung customer service walked me through the rest but the problem persists. They said to send it in to have the motherboard replaced. Mine is out of warrenty so it's $160 which include parts, labor and return shipping. Takes about 7-10 days.
  • Britt73 Mar 11, 2009
    Thank you , I have had mine apart but couldnt tell what boards needed to be repalced....part is ordered now...
  • Fitawav May 11, 2010
    Is replacing the PCB a difficult fix? Is it litterally a board swap or is soldering involved and such?
    Thanks!
  • Big Papa Al May 11, 2010
    anything else
$38 part from Sears PartsDirect took about 30 mins to install.  Part # AH92-02673A Ay pcb-front.  There are actually 2 boards to this setup, I went ahead and replaced both but the power button side of the board has some wiring that requires you to remove the disc changer which is only 4 screws and 2 screws for the piece that holds the disc above the reader.
I couldn't find an easy way to get the knob off on the front it required me to force it, nothing borke but your replacing the board anyways..
Posted on Mar 25, 2009
I had this problem when I went to touch the stop button on the front panel I, unknowingly, static sparked the display, metal front panel?, and it went dead blank. I spoke with Samsung and went through their suggestions. I turned it off and back on and all characters lit on the display. I sent it for repair and got it fixed. I did the same thing again, static spark, when pressing a button on the front panel after getting outta the recliner. Sent it for repair the second time. Got the unit back again. Decided to put some clear tape on the metal front panel, maybe insulate it from the static discharge? About a month later I got up from the recliner and pressed a button on the front and blanked out the display AGAIN, and turned it back on and ALL CHARACTER LIT AGAIN FOR THE 3RD TIME! I have been using it with all characters lit but I've had enough. I removed the system and went back to my old surround sytem for now. I have a Samsung 54" TV that never had a problem, not to mention all the other Electrionic equipment I have next to this unit that never had a static discharge problem or any other display or functioning problem. I think this unit does not have proper grounding to the front metal panel to properly ground the static discharge when touched rather than send the High Voltage discharge through the display circuit causing this malfunction. Good luck.
Posted on Feb 21, 2009
  • brgmchevy Feb 21, 2009
    Also, I am working on getting the info for this display to fix mine and I will post the info, if and when, I get it. The solution so far is not to zap the unit. Unfortunately, this info could have been more useful beforehand.
    I just found the front PCB Assy# AH92-02673A at Sears Parts Direct for $38.44. Looks like plug-in-go repair, maybe. I will have to get this front PCB and see if it works. I will try to ground the metal front panel to the chassis better to keep from repeating this failure.
    Genius:
  • 1,067 Answers
Ya nice system i have x 40 buddie shas x50 did u try to unplug from wall put let for 1 min then back in cheak remote no butons stuck in
Posted on Jan 09, 2008
My HT-X50 front display screen has all of the LEDs lit up like they do when it is first powered up (self check). They all stay on regardless of the mode the unit is in - DVD, Aux, etc. The room the unit is...
The display is damaged. This is how this series dies. In some cases the receiver still works except you can't see the display. Samsung service center can repair it, nobody else.
Apr 01, 2010 | Samsung HT-X50 System
Samsung ht-x50 home theater system keeps shutting off
You have probably set the sleep timer. Here's how to switch it off: To cancel the sleep timer, press the SLEEP button until <OFF> appears on the display.
Jul 07, 2009 | Samsung Electronics - Others
My samsung home cinema system - HT-X250; Trips off every couple of minutes with "Fan Check" higlighted on the display
Had this same issue with my Samsung HT-X50, it seems these systems have cheap fans. Mine was under warranty but when I contacted samsung they wanted me to pay to ship it to them. **** that, it would of cost me 70 to ship.
What I did was open the unit take the fan and go to a computer store asking for a similar one, I got all this done for about 10 bucks. **** that samsung warranty
Apr 09, 2009 | Samsung HT-X250T Theater System
Making the HT-X50 Region Free
Remove all discs from player.
2. Turn off the player
3. Unplug the power cord to the player
4. Wait 30 seconds, then reconnect the power cord.
5. Turn on player with the remote control. Wait until player LCD says 'No Disc'.
6. Press 'Enter' on remote control. (There will be No On-Screen Response.)
7. Press 8, 4, 2, 6, 9 on the remote control. (There will be No On-screen Response.)
8. Press Enter on the remote control. Player will power off.
9. Turn player on using remote control.
10. Open the tray.
11. Close the tray.
12. Turn player off then on.
13. Player is now Region Free
Dec 31, 2008 | Samsung HT-X50 System
Picture HT-X50
This problem to the system e.g; ( PAL,SECAM,NTSC....etc)
First check that you tv should be multi-system (not too old model) if it has supported system then turn on the required system manually.
Secondly Check the settings of your Home theater system and change the system accordingly.
Thanks.
Oct 26, 2008 | Audio Players & Recorders
Samsung HT-X50 and HP Personal Media Drive
you need to format as fat32... use a mac computer... otherwise it wont recognize it... no NTFS... just fat32... that is how i did it.. hope this helps you.
Aug 25, 2008 | Samsung HT-X50 System
SAMSUNG HT-X50
Do you smell anything burning. This happened to me and I cut it back on. It stayed on for 30 secs or so and did the same thing. After doing this 2-3 times, I smelled a burning. Being a member of the Fire Dept, I didn't want to see my buddy's coming to the house, so I unplugged it. The next day, I took it apart and there was a burnt resistor or something under neath the fan. I took it back and they gave me a new receiver, but I'm expecting the same with this one.
May 16, 2008 | Samsung HT-X50 System
No picture on my tv
what u meen usb ? style thats only for music players u could use nero 7 or 8 verison make a dvd slide show of your pics with music thats coolest way
Jan 24, 2008 | Samsung HT-X50 System
IPod Support for Samsung HT-X50
the ipod scrambles the names of the tracks making it impossible to find songs, thus encouraging you to buy an official ipod player.its all about money
Jan 18, 2008 | Samsung HT-X50 System
Shutting off When Volume is Turned Up
geting hot is sumting on it welll vented ?
Dec 25, 2007 | Samsung HT-X50 System
Samsung HT-X50 System Logo
504 people viewed this question
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
