Question about Quest ITT Night PVS-14 Gen 3 Night Vision Scope w/ FREE UPS
I have an NEPVS-14 that was left on while facing
That's pretty much it.
    President:
  • 2,702 Answers
This is not much to go on???? i gess you have found out its not working by now,,,try changing the batterys? these scopes only have a life span of about1500 hours after that there dead they are "bright light protected" so leaving it switch on in daylight should have just knocked the batterys out,,,
Posted on Nov 17, 2009
Shift solonoid e e is for external it the one on top of trans two screws and a plug on top it not on top Marc is correct I think I looked up camry and not solara thank you
First, check your information on the location of the shift solenoid in the Camry Solara. It is like most cars on the road. The shift solenoid is located under the drain pan cover on the valve body wall (the valve body faces the drain pan cover. To access it, you will have to do this:
  • Wait until the transmission is cool and the fluid has settled
  • Drain the transmission fluid (depending on brand automatics have up to 9.5 quarters of automatic transmission fluid in them so you can see the necessity of draining it first. Instead of having a rush of tranny fluid gushing out at you, you are only facing about one quart)
  • Place a bucket under the transmission drain pan cover
  • Loosen the 14 bolts along the cover flange
  • Gently place the transmission pan cover into the bucket
  • Let the quart or so that is left in the transmission drain out
  • Look at the valve body, just revealed by the removal of the fluid and cover
  • Locate the solenoid on the upper right of the valve body
  • Replace the right-hand one first
Jun 28, 2015 | 1999 Toyota Camry Solara
How to remove the chain from a husqvarna 235e chainsaw?
Like this or pretty close.
  1. Cock brake while expanding chain brake binder by pulling brake handle towards left-hand (wrap-around) handle grip, hard, until it locks in place.
  2. Loosen 2 brake-asssembly-and- bar retaining nuts but do not remove yet.
  3. Unscrew (turn CCW) bar adjustment screw on front face of unit in order to shorten bar and slacken saw chain.
  4. Slip chain off bar over bar tip and towards inward side of bar.
  5. Remove two nuts loosened in step 2 and pull brake assembly and bar straight out and off bar mounting studs.
  6. While rotating clutch/brake-drum, maneuver saw chain off sprocket and around drum perimeter to remove from saw.
  7. Repeat/reverse steps 6 thru 1 in that order to reassemble.
25045742-0m3nstwfcb55vn4usb1qox2f-3-0.jpg 25045742-0m3nstwfcb55vn4usb1qox2f-3-2.jpg
Sep 01, 2014 | Husqvarna 14-Inch 34cc Gas Powered...
Deactivate facebook
since 3/26/14 If I clicIf I click like on a friends comment it returns me back to the top of my face book wall// since 3/26/14 if I click on a friends name status to see theyr newest status it returns me back to the top of my face book home page, I tried clicking on that thingy on the right hand corner of my face book page to report problem but it jus freezes it does not open up, I have tried deactivating my acct again it jus freezes at that spot I have deactivated face book from my phone but I am still able to get to my wall on face book pleae Help I am so annoyed with this problem
Dec 13, 2013 | Boyaa Texas Poker
Face Spa Purifying Clay Facial Masque Clay & Ginseng burn my skin..why such effect?
ginseng is pretty powerful, depending on the content of ginseng and the combination of other ingredients (which can compound it) it would not be unlikely to have reactions if you were fair skinned or have delicate skin, i have to watch EVERYTHING i use on my face "Or Else"...lol.. you might try one of the Abba products they seem pretty gentle and pretty natural.
Mar 26, 2012 | Cst Face Spa Purifying Clay Facial Masque...
How do i unlock the safety position on my Ryobi miter saw?
There should be a metal pin on the back left side(tool facing you) near the pivot point. Just pull this in or out to lock/unlock the safety position.
Mar 02, 2011 | Ryobi ZRTS1342L Factory-Reconditioned 14...
How do you shut off the check engine light?
If you are trying to reset the check engine light, you remove the EFI fuse from the engine compartment for about a minute. If there is a problem, it will soon light up again. This is where the EFI fuse is located. As you face the front of the 4Runner, you will see the battery at the front right. The FUSE BOX is just beyond the battery. The top of the fuse box has a panel which identifies each fuse. The EFI fuse is the MIDDLE FUSE, closet to the right fender. If you're talking about the maintenance reminder light reset button, its to the left of the guages, labeled "reset"
Jan 31, 2010 | 1995 Toyota 4Runner
Error code H4 on Sharp AL-1641CS?
Usually a flase code on these models. Try clearing by pressing "C" then far left key (Exposure Mode) then "C" then far left again. Must be pressed quickly and if done correctly display will go blank. Then key in 14 as if making 14 copies. Then press Print.
Short Version: C, far left, C, far left, 14, print
If code returns then you have a fusing unit problem but 9 times out of 10 this is just a false code.
Good Luck
Dec 23, 2009 | Sharp AL-1642CS Copier
Pfaff hobbylock 794
The needles are changed by inserted the hex wrench into what looks to be holes on the front and left side where the needles go into the machine.I'm not sure what size the hex wrench is but it's pretty small. From the manual,
"Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out." and
"Inserting needle: When the neddle bar is at the highest position, insert a new needle in the needle holder, making sure that the groove of the needle faces you. Push the needle as far up as it will go and tighten the needle clamp screw." "Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out."
The machine takes DB x 1, or 1738 needles, and a size 14 needle is recommended.
Hope this helps!
Mar 31, 2008 | PfaFF Hobby 4260
Settings on a sidekick
pretty simple, the menu button which is the botton on your sidekick marked with 3 lines, one under another. (top left hand corner of face of sidekick)...your questions seems like you want more to add tho
Feb 05, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Optics Logo
131 people viewed this question
Top Quest Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Quest Optic Expert? Answer questions, earn points and help others
