Question about HP Computers & Internet
My lap top keeps shutting down
My hp lap top keeps shutting down on its own
  • 3,153 Answers
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some
good guides here
An alternative is to get a can of compressed air used to clean computers. Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
Do this outside with glasses on.
You may also want to remove the hard drive and ROM drive.
Take a
peek here for more ideas of what is involved.
There are a few are tips for various things in there.
DON'T touch the CPU cooler unless you know what you are doing and have some thermal grease for CPUs to hand.
To make newer laptops last longer between cleaning a good 3 fan cooling pad is suggested.
never use a laptop on soft surfaces as the ventilation can act as a mini vacuum cleaner and encourage dirt build up.
Soft surfaces also block the vents causing fans to run more and burn out sooner.
Hope this gives you the information you need
Posted on Nov 15, 2009
    Scholar:
  • 60 Answers
This is normally due to it over-heating. It will turn itself off as a safety measure to prevent itself from becoming damaged.
Make sure the laptop is on a hard, level surface with nothing blocking the air vents.
How to fix the HP Laptop are shutting down by itself
Hi Walter, The link below is a YouTube video showing how to fix your lap top shutting down by it self, Also there's videos down the right side of the link that may help as well, By the way instead of using a straw I'd undo the back..........CHEERS..
Don panic Is your laptop shutting off by itself or slowing down during use
May 11, 2016 | HP Pavilion dv9000z Notebook
Why does it keep shutting down
what are you doing when it shuts down? i'm having a similar problem with my HP. if i have the laptop on a hard, flat surface like a table, it works perfectly, but when i move the laptop to my lap, that's when it shuts down. it seemed to happen every time i touched the battery area. found out that it's a bad motherboard and i have to send it in to HP to be repaired.
Jul 02, 2014 | HEWLETT-PACKARD HP ProBook 6455b(WZ237UT)...
My lap top keeps shutting off
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Aug 23, 2012 | Acer Aspire 7720 Notebook
Is it free: My monitor goes to sleep. How do I stop this?
Right click on power options and remove the sleep option.
Hope that helps.
Jan 22, 2011 | HP Computers & Internet
All my saved pictures have been deleted and the screen continually goes blank
Greetings and thanks for the question, there are various reasons why this happens. Without having your computer here to see what is going on is anybody s guess on how to repair it. If I may offer some suggestions. Since I also do not know what operating system you are using I will assume it is Win 7.
I would personally go to control panel and check my power options to make sure I do not have the settings set you close display or sleep mode or anything set to soon to close your machine down. Often times people have these set to go off there are defaulted usually to save battery usage and your lap top from getting to hot and shutting it down. The thermal switch may be activating sooner than normal. What some folks do is purchase one of those underneath fan coolers to keep their lap tops from getting to hot and constantly shutting down.
This can be the case have this checked out at least set the lap top for more time before closing down or turning the monitor off. Let us hope it is not more serious than appears. Like a lamp in the monitor going out. If it is new the lap top I would not worry about that issue because it is intermittent. Which leads me to believe it is a thermal or a shut down issue. Get the cooler fan for your lap top I recommend anyone that reads this post to also do this as well. Clean your lap top blow them out it is critical to do this to keep dust away and keep it clean.
Now there is recovery software which is free to download Click Here to check this out to retrieve lost files. Also important to get those precious memories separate off your computer and on to separate CD or DVD or storage USB stick so that when this type of thing happens you have not lost your precious memories. I hope this helps you. John
Jan 17, 2011 | Samsung NC10-14GW Notebook
Computer keeps crashing. After I downloaded the skype for the built in web cam on my hp pavilion dv6000, the computer just shuts down, even when I am not logged in skype. Also, I have taken my lap top to...
turn on machine and hit F8 to into safe mode. If cannot load to safe mode i suspected your Operating system is corrupted. You might need to reformat your machine. Back up your files first before doing so because everything will be wiped out.
Jun 30, 2009 | HP Pavilion dv6000t Notebook
I cannot restore my acer aspire 3630 lap top
hi you need to press the FN and F8,9 or 10 repetedly to restore it to default settings.
May 04, 2009 | Computers & Internet
Shutting Down my LAP TOP
Check in your bios for the power settings - your laptop is likely set to wake on lan or some other hardware. Also, check in the windows power management for the settings in there.
Feb 12, 2009 | HP Compaq Presario v3000z Notebook
Have Vista,
the software may need to be reinstalled.
Nov 11, 2008 | HP Photosmart C4280 All-in-One InkJet...
Computers & Internet Logo
78 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
