Question about Samsung J700 Cellular Phone
I have a cracked screen on my phone and i want to transfer my images onto my laptop
Laptop fell to floor, cracking the screen. Was able to use content of computor via a separate monitor from another computor system we already had. Bought another monitor off of e-bay (Samsung).Monitor...
hi,
i think : no it is not safe for connection because each one of laptop use of the different graphic
and the fujitsu laptop for protection advise you at the booting up " auto adjustment is locked"
in the other hand each minitor use of the special voltage. therefore this flash advice at the
first of booting and before transfer the graphic data and power voltage to samsung laptop
alarm you : stop
i suggest you to contact seller
good luck
gorbesia
Jun 13, 2011 | Computers & Internet
How to plug in a 3G sim in a acer aspire 5738 card slots
Hi
have you any discs and usb leads that came with the 3G mobile phone
i would think that this is how to transfer images onto the laptop
Feb 25, 2011 | Computers & Internet
Broke the screen on my cob kyros can i get it fixed?
A broken screen isn't something which can be repaired with a software upgrade. There are two types of broken screens. An internally broken screen is where the image on the screen looks cracked, even though there is no physical signs of abuse. It will turn on but you'll see all these funny colors come onto the screen. An externally broken screen is basically if you took that laptop and dropped it onto something hard. You wouldn't get an image, you'd just hear some noise from the power supply.
Your best bet if you have a broken screen is to take it to a service technician to see what a screen replacement will cost. If the laptop still works you can also plug an external monitor into it. This won't let you use it so easily on the go, but at least you'll be able to use it at home.
Hope that helps.
Jan 02, 2011 | Coby Computers & Internet
My screen is broken how do i get my contacts onto my laptop
just connect the phone to laptop via usb or bluetooth. When you connect via usb remeber you should have phone tools for your mobile. select mass storage and transfer
May 12, 2010 | Motorola Mobility SLVR L7 Cellular Phone
I cant upload my photos to my pc
hi friend
here are several ways to transfer mobile phone photos onto your PC, ranging from, emailing them using GPRS, Bluetooth file transfers, Infrared file transfer, using MMS service, using a card reader or simply using a data cable. VideoJug themselves even have a film on the subject, but this guide will address transferring photographs to your PC using the manufacturer supplied data-cable and software.
  1. Step 1: Check To See If You Have The data Cable And SoftwareMost mobile phones nowadays come standard with a USB data transfer cable and bundled software utility. Check the box that your mobile phone came with for the cable and CD-Rom. If not provided with the software, it may be available as a free download from the manufacturer’s website. If your phone did not come with a data cable, check the manual if your model supports data cable transfers.
  2. //');document.write('');document.write('');} //]]> google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
  3. Step 2: Install The Communication SoftwareOnce you have located your software CD, check the system requirements necessary to run the software such as hardware specifications, operating systems supported etc. Install the software following on-screen instructions, but do not plug in the USB data cable or phone in just yet, unless the software requests you to do so during the installation process.
  4. Step 3: Connect Your Mobile Phone To The PC Using The Data CableOnce the installation is complete, the software would usually require a reboot of the PC before plugging in the mobile phone for the first time. Then connect your mobile phone to the data, and the cable to the USB port of your PC. Several phones may display a message on the mobile display that the phone is now connected to the PC, but if not don’t worry just yet!
  5. 1px.gif Remember never to unplug or disconnect the data cable from the phone during a data transfer or you could end up damaging your phone or loosing all your data.
  6. Step 4: Start Up The Software Package And Locate The Image Or File Transfer UtilityOnce connected, start up your mobile phone’s software, and browse through the interface. Most manufacturers offer some form of phone browser where you can browse through the content on your phone, copying files onto, or taking files off the mobile. The software utility may also offer a separate tool for transferring photos and video shot with your mobile, if this is the case use the utility!
  7. Step 5: Transfer Mobile Phone Photos Onto Your PCUse the software’s browser or photo utility to transfer your photographs to your PC. Some software tools provide image editing tools as well that will enable cropping, rotation, and sharpening of images once transferred to you PC. Don’t be afraid of referring to the software’s help file incase you get stuck.
  8. 1px.gif As phone models and manufacturers vary, it is always a good practice to read through the mobile phone user manual and the software's help or readme file while using this guide. It is also always good practice to use the backup function of the software first to ensure you can restore your phone back to its original state should anything happen to it.
download Samsung Pc suite and
Mar 31, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
How do i transfer pictures onto my labtop from samsung T429, when theres no usb cable or memory card system installed? I tried connecting bluetooth, but didnt get how to transfer them to my husband cell...
*Laptop?
And you have to make sure his cell has the bluetooth enabled also.
Then go to the picture you want to transfer, go to options and there should be a button that says something like bluetooth visibility. Enable it. Then he should get a screen on his phone that says transfer files. Or something like that. But the phones have to be within a certain range of eachother. A few feet or so.
Apr 08, 2009 | Samsung SYNC SGH-A707 Cellular Phone
LG Lotus - how do file transfers from laptop?
Did you format the sd card to your lotus? Make sure that when you are connecting your lotus to your laptop via the usb cable, you are putting your phone on usb mode. Go to menu; tools; usb mode (option #4 in your tools).
Mar 28, 2009 | LG Lotus Cell Phone
I 580 PHONE
ok so for the I580 you can only put .jpg pictures on the phone, but the catch is that they can only be at the most 134kb.. When you go to put them onto the phone just drop the file into the images folder on your sd card.
Feb 26, 2009 | Motorola Mobility i580 Cellular Phone
Pictures transfered on the phone doesnt show!!
Here is the MAGIC NUMBER. Make sure all your jpegs are saved sized: -
640 x 480
The phone CANNOT ADAPT any other image size it seems.
Jan 01, 2008 | LG Prada KE850 Cellular Phone
Images
This is no problem. Its work also in this condition bcz you import your image and in importing your all images in camera transfer to your pc, if you want to safe your images in your camera please use a card reader to copy your images in your pc. After that your all images also safe your camera.
I hope its very helpful for you
Oct 17, 2007 | Nikon COOLPIX S7 Digital Camera
Samsung J700 Cellular Phone Logo
16 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
