Question about Lexmark Optra SC 1275 Laser Printer
Two black dots on right side of page
I get a pair of black ink dots spaced vertically about 2-3 inches only on the right side of a printed sheet. There are usually about 3 sets of these on a page, I have changed the PC, all the ink cartridges and now am frustrated to see this after all the money spent. Any ideas would be really helpful as I was planning to keep this printer for my work
  • BJMAT Jan 09, 2008
    yes, the spots are on the exact same spot on each page. I replaced the fuser something...it came with the new PC that i had installed...
    any other ideas anybody
  • Anonymous Mar 03, 2008
    i have the problem not with two black dots but all page is black in first time when i change toner now its blue what is proem :S
Does anyone can tell me when i can find the fuser of lexmark optra sc 1275 tell me in email [email protected]
Posted on Mar 08, 2008
Have the problem not with two black dots but all page is black in first time when i change toner now its blue what is problem :S
Posted on Mar 03, 2008
Yes john A. I have dots and now I also have smudges. I can email you a copy if you email me @ [email protected] with your address. I think you are right in it being the fuser assembly, I checked the inside of it after opening the back the orange colored drum seems to have a few streaks on the right side of it, which I am thinking mirrors the points and sludges...let me know what you think...
MORE importantly - I want to thank you for your kindness and time !
Posted on Jan 09, 2008
  • 186 Answers
Are the marks in the same exact spot on each page? If not and you have changed the toner cartridge then most likely the fuser assembly needs to be replaced. This is a job I recommend for a professional.
Good Luck
John
  • john archer Jan 09, 2008
    Can you fax or email me a copy with the dots? Are they smudges? Are the dots identical on each page?
6ya staff
SOURCE:
Konica Minolta 2430 DL has Smudges or dots on page
Not an expert on this brand of printers but it looks like dirty feeder rollers to me. Try cleaning them and Print a Blank document and see if the marks show up
Jan 24, 2014 | Konica Minolta magicolor 2430 DL Laser...
5x7 inch paper moves towards end of print and black ink smudges edge of paper
Check for any small paper jam. Check the rollers, also use an alcohol swab to clean the rollers and check for ink leaking. Check you ink pad, it could be time for a new one.
Jan 21, 2014 | Epson Stylus 1400 InkJet Photo Printer
Little dots on right side of margin (Brother HL-5040)
I would have guessed the trouble shooting steps you first performed. It could still be a bad imaging drum. Or a fuser. Not sure if this model has a replaceable fuser or not.
Jul 08, 2009 | Brother HL 5040 Laser Printer
Tiny dots about 1 inch apart down the side of page
Again, this was actually HP Laserjet 3800. Problem solved by chatting with HP, and them having me go into a diagnosis mode that disabled cartridge check. Then, I removed the cyan cartridge, the dots went away. They then had me put the black into the cyan slot, and not dots appeared. I had backup toner on hand, swapped in a new cyan and magenta, and all was good. HP agreed to replace the cartridges.
Jun 19, 2009 | Brother HL 2140 Laser Printer
Printing vertical grayish black ink on the left and right side of page
replace the toner cartridge, you wont have anything "dripping" out of it as the toner inside is a powder. if it still appears replace the fuser.
Oct 22, 2008 | HP LaserJet 4250dtn Printer
Vertical dots on print output
1 1/2 inches apart would correspond to the diameter of the primary charge roller. You have one chrarge roller inside each toner cartridge so you need to determine which color the dots are and then replace that cartridge.
Oct 22, 2008 | HP LaserJet 4600dn Color Printer
Epson 9800 Prints black dotted vertical line
This is a workaround - I too need a definitive answer. Symptom: black dotted vertical line 1/2 to 3/4" from leftmost image edge. I have begun adding single vertical line to my prints .25" from the left edge of the paper to force the "dots" off my print - this seems to have the desired affect, but it does not answer the cause or provide a true remedy (it will save many of your prints while we wait for complete solution). dkh
Apr 18, 2008 | Epson Stylus Pro 9800 InkJet Printer
Brother laser printer printout
You need to clean your drum unit:
see http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000001044&Sympt=The+print+jobs+have+black+spots+or+black+dots.+How+can+I+improve+the+print+quality%3f&Model=3&ProductGroup=1&Keyword=dot&ProductID=HL2040
Worked for me!!
Dec 19, 2007 | Office Equipment & Supplies
Lexmark Optra SC 1275 Laser Printer Logo
178 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
