Question about Sony KP-46WT510 46" Rear Projection HDTV
Replaced convergence clips and blue wave will not line up can move but way off
  • Sony Master
  • 3,459 Answers
Check the pico fuses.
Posted on Nov 28, 2009
When i try to adjust the convergence, the red and blue adjust ok, i assume the green in the basline color, but it turns up on the right side of the screen and the picture has a green wave in the lower left...
The tv 100% have convergence problems,it dead,if have any colors lines mis alignment or don't stay in the convergence - + grid.The tv convergence board is dead.The 2 STK convergence ICS and some or all is resitors are dead.Must replaced these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 11, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
I have this same problem with the PT51HX41E but in the convergence menu the green and red are allowed to move. but the blue on the right side of the screen is not allowed to move and it looks like its...
My first guess would be a bad convergence amplifier - this is common, although usually all three of the amplifiers in the integrated circuit die at the same time, which throws off at least two colors and creates a "bow-tie" effect. I surmise you have half of a bow-tie in blue only.
If you could look at the blue output waveforms with an oscilloscope, you would see right away if this is the problem (flat-line instead of sawtooth wave). It is possible that both of the blue convergence amplifiers are working, but one output is not getting to the blue deflection yoke.
Don't mess with the convergence anymore until you get this taken care of. Changing the convergence now will only make it harder to get it back to where it should be once the circuit is fixed.
Sep 22, 2010 | Panasonic PT-51HX41 51" Rear Projection...
JVC- red wave on screen and letters doubled
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Mar 12, 2009 | JVC AV-48WP74 48" Rear Projection...
I have a blue wave on my screen
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in or warped.
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Jan 28, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Blue line
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 28, 2009 | Hitachi 43F300 43" Rear Projection...
Convergence issue
try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
Nov 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Picture shadowing and waving pictures
  • Screen looks 3D
Oct 19, 2008 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP30 started displaying vertical lines every inch
it looks like theres a wave in the top of my screen on my jvc av-48wp30 not sure but i think it has something to do with the bulbs because the projection mirror wasfine and all wires seemed to be hooked up properly.. can you help? tell me where i can find the bulbs to replace them?
May 13, 2008 | JVC AV-48WP30 48" Rear Projection...
Wave at bottom of screen with green and pink shadows
  • Screen looks 3D
Feb 17, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
82 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
