Question about Electric Marklin Digital Ho 3748 E70 Bavarian
My steam locomotive from 29825 era 111 digital mega starter set does not run properly. the locomotive moves very slow although all sounds still work. is there a problem with the motor?
Propably it needs to be reprogramed
Posted on Oct 25, 2010
  • Steve Cook
    Steve Cook Apr 25, 2011
    "Needs to be reprogrammed".... FAIL! - More likely it first needs the tiniest drop of oil on the motor bearings and gear train, then a little running to work it in. You may also need to check the motor brushes. If you don't have the original service sheet that came with the loco, join up to www.marklin-users.net and someone will be able to email you a scan of the original.
I cannot get my MTH engines to run properly. Power is on, bell and horn sounds, lights are on
MTH locomotives have internal batteries that may need to be replaced. The circuit boards in some older MTH locomotives can be damaged if operated with discharged or faulty batteries. Contact MTH customer service for help with your engines.
Feb 07, 2015 | Crafts & Hobbies
What year is Lionel Train Set 1463?
1463 set with #2036 steam locomotive - 1950
1463 set with #2026 steam locomotive - 1951
Oct 10, 2014 | Crafts & Hobbies
I bought a marklin steam locomotive where the wheels are frozen up or not moving at all. Any help ? Ho can repair it. Thanks
If the wheels don't move even when you try to "slide" them with your fingers, the possible problem is with the motor brushes: with a pair of tweezers gently push the springs that hold the brushes (there is one cooper brush and a carbon brush, on the motor). Remove the brushes and replace them by new ones (available from any Marklin dealer). Notice that there are 2 brush models - for old motors and new motors (these ones use 2 carbon brushes instead). Hope this helps. Best!
Oct 08, 2013 | Walthers Marklin "Veolia Transport" Class...
Lionel o guage santa fe steam engine locomotive won't reverse even with reverse switch on?
You do not specify which Santa Fe steam engine you have, but I am going to guess it's the Santa Fe RTR O27 set...
Here's a link to the manual for it. Go to page 9, read the last paragraph on the page. It may be the answer to your problem
.http://www.lionel.com/media/servicedocuments/71-1900-250.pdf
Hope this helps.
Jan 05, 2013 | Lionel New Haven Freight Train Set
Strasburg steam locomotive receives power, but does not move.
Try cleaning the track AND wheels with an INK ERASER. Put the engine on the track and help it along. It could just be tight from sitting in the box. I live about 8 miles from the Strasburg railroad and have 2 relatives working there. We have ALL experienced the same thing on4 different sets. It isn't just the Strasburg sets that do this, it's most of the new toys. Your Strasburg cars might not connect to other train sets. Their car couplings are different, just like on their real trains.
Dec 13, 2012 | Toys
Our Lionel Holiday Tradition Express Set 7-11102 will not move even though all of the other functions work properly
Did you check the reverse switch? Be sure that it is turned ON. If your locomotive still will not run, check that there are no fibers wrapped around the wheel axles or any exposed gears. If none of these fix the problem you will need to take your locomotive and tender to a Lionel Service Station.
Dec 21, 2010 | Toys
I bought the 6-30089 Pennsylvania Flyer Train Set last year. It's been in storage in the original box in a cool, dry place since last Christmas. I put it together, but it will not run. There is power to...
Hope you got the set working. If not, look underneath the locomotive near the rear (under the "cabin"). There are two switches, one on either side. One says "Smoke", the other says "Reverse". If the "Reverse" switch was set to "Off" when the locomotive was in Neutral, it will stay in neutral even when the power is cycled or the "Direction" button is pressed on the power supply. Even in Neutral, all the lights will work and I believe the smoke element will heat up but won't puff. Whatever setting the "Reverse" switch is on, try changing it to se if that works. Hope this helps...
Dec 04, 2010 | Lionel Pennsylvania Flyer Train Set
I need the intructions for the mega bloks express but can't download it
You can get the instructions for this and a lot of other sets at the Mega Bloks wiki - Blok City
The Mega Bloks set seems to actually be called the Steam Express.
If you follow the link below and then go to the bottom of the page you'll find the instructions for this Locomotive
http://www.blokcity.com/wiki/index.php?title=9778_Steam_Express
Sep 15, 2010 | Mega Bloks Steam Locomotive
Forward runs good but reverse dosnt work so good unless you give it a little push but if you slow it down again it dosnt work so good again even siezes. help
You will need to perform the following :
1) clean any and all electrical pick ups (with power off)
2) check, clean, and re lubricate gearing on locomotive
3) check switch on fwd and rev for contact and dust.
4) please note that sometimes this is a really good excuse to buy a new locomotive or upgrade to a BIGGER set.
Hope This Helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
Nov 29, 2009 | Lionel Trains Classic Freight Train Set
Electric Marklin Digital Ho 3748 E70 Bavarian Logo
198 people viewed this question
Top Electric Toys Experts
ray gallant
Robert A. Watson
Robert A. Watson
Tom Chichester
Are you an Electric Toy Expert? Answer questions, earn points and help others
