Question about GPS
How to remove/replace roof interior light assembly.
  • 460 Answers
Remove the lens and you will see a couple screws. the rest is simple unless it is glued in place..
Posted on Nov 15, 2009
Replacing quarter glass on left side on 2005 pontiac gto
Remove the door opening weather-strip. Refer to Door Opening Weatherstrip Replacement in Doors.
Remove side sill trim plate. Refer to Door Sill Plate Replacement in Interior Trim.
Remove the lower quarter panel trim. Refer to Rear Quarter Trim Panel Replacement in Interior Trim.
Remove the center pillar upper trim panel. Refer to Center Pillar Upper Trim Panel Replacement in Interior Trim.
Remove the quarter upper trim panel. Refer to Rear Quarter Upper Trim Panel Replacement in Interior Trim.
Remove the center pillar outer applique. Refer to Center Pillar Applique Replacement in Exterior Trim.
Remove the roof drip molding. Refer to Body Side Roof Drip Molding Replacement in Exterior Trim.
Important: It is necessary to use new nuts when reinstalling the quarter window.
Remove the nine quarter window nuts (1), securing the quarter window assembly (2) to the body opening.
Caution: When working with any type of glass or sheet metal with exposed or rough edges, wear approved safety glasses and gloves in order to reduce the chance of personal injury.
Important: When removing the quarter window from the body opening make sure that the attaching pins are clear of the outer body.
Remove the quarter window (2) from the body opening.
Remove the rear seat cushion. Refer to Rear Seat Cushion Replacement in Seats.
Remove the rear seat back. Refer to Rear Seat Back Replacement in Seats.
Remove the door sill plate. Refer to Door Sill Plate Replacement .
Remove the 3 quarter trim panel retaining screws (1).
Starting at the lower edge of the trim panel and moving alternately clockwise and counterclockwise, pull outward on the trim panel to disengage the eight rear quarter trim panel attaching clips (2).
Remove the quarter trim panel from the vehicle.
Remove the 4 radio speaker grille speed clips (1), securing the speaker grille.
Remove the speaker grille (2).
Remove the rear quarter trim panel insulator (1), from the back of the quarter trim assembly (2).
Remove 7 rear quarter trim panel armrest retaining clips (1).
Remove 7 rear quarter trim panel armrest retaining nuts (2).
Gently pry the quarter trim panel armrest insert assembly (3), away from the rear quarter trim panel and remove.
You mite look for a video on youtube !
Dec 23, 2016 | Pontiac Cars & Trucks
How do i remove the interior light housing in the roof
On most vehicles use a thin metal (screw driver, knife) object to pop the cover off. That would gain you access to thebbulb. Usually there are either two screws that hold the assembly in or a couple of tabs. Release the tabs or remove the screws and the assembly should come out.
Oct 13, 2016 | 2008 Saturn Aura
Clock backlight, heating panel light and door light not working
So--there is no back-light on the heat panel and roof mounted display?
Similarly to a gauge cluster--there are bulbs that produce the back-light. I have a 90's vehicle and I had to replace the bulbs in the heat panel and on the gauge cluster. On some vehicles however you have to take the whole car apart just to access these bulbs. So--just take your time, consult a book, and check the bulbs to see if this is the culprit.
Hope this helps.
Oct 21, 2013 | Volkswagen Cars & Trucks
How do I change the interior light in a 2002 chrysler sebring
perhaps if you were to take a good picture and post it we would have a better idea, as I can not imagine a metal cover over the bulb unless it is some sort of heat shield .
Aug 21, 2012 | 2002 Chrysler Sebring
Interior lights problem on a 2006 Lexus SC430
Only one light inside light works on my Lexus SC430 and I have been told that I have to replace the whole part which is about $700 because it is computerized. Is this true
Aug 10, 2012 | 2006 Lexus Sc 430
My interior lights in my 2007 pt cruiser wont go off. I had to pull the bulbs out of the dome and reading lights so the battery wouldnt go dead can you help me?
There is a short in the wiring of your interior lights. The wire has come loose and is now shorting against the metalic roof of your car. Remove the interior light from the roof enough so you can see the wires. Make sure the contacts are secure to the pins in the bulbs
Mar 18, 2011 | 2003 Chrysler PT Cruiser
96 Buick roadmaster= interior lights stay on while driving
Check to see if the over head light has shorted to ground. EG: touching roof, from weight being put on the roof. EG: Cargo hauler.
Jun 01, 2009 | 1996 Buick Roadmaster
FUSE BOX HAS CLICKING SOUND
i'm sure that would be somewhat disconcerting. it's one of the relays clicking. remove the fuse panel cover and put your finger on each relay till you find the one that is clicking.... pull it out and replace it. you'll know you have the right one if the interior lights go off when you pull it out.
Robert
Please take a moment to rate this solution ... thanks
Apr 15, 2009 | 1995 Jeep Grand Cherokee
2003 Ford Focus radio antenna broken off.
Should be a dome light in the interior that lines up with antennae on roof if it's same as I remember. Remove interior light and there should be screws in there holding base of antennae to roof. If it's just a broke off mast, try to unscrew stud from base & replace.
Jan 10, 2009 | 2003 Ford Focus
Roof is leaking near the handles by the front windshield, onstar speaker, and rear interior light
It could possibly be one of the exterior perimeter lights that has bad plastic/foam seals.... You may need to replace these seals by making your own using materials found at a hardware store or buy new light assemblies...
Aug 02, 2008 | 2003 Hummer H2
GPS Logo
23 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
