2005 chevy uplander rear blower motor won't turn off, none of the switches work, it seems to be stuck on high.I removed all of the switches that control it but it still runs.
  • 460 Answers
Well, you have a bad switch. see if you can get it replaced.
Posted on Nov 15, 2009
Rear blower not working on 2008 Chevy uplander
First think I would do is take an ohm meter and see if you are getting power to the rear blower resister. They go bad before the blower does. Also check your fuses and rear fan blower relay. Good luck.
Jan 07, 2015 | 2008 Chevrolet Uplander
Blower motor won't shut off on a 2005 chevy monte carlo
Your post is not making sense. If the blower motor wasn't shutting off, how would replacing it cause anything to change? Clearly, there is a problem with the power supply TO the motor. If you want the motor to turn off, you need to check WHY the power to the motor is not cut off when the switch is turned to the off position. Probably a bad switch. Or it could be the blower motor resistor even, albeit a lot less likely.
Feb 24, 2013 | 2005 Chevrolet Monte Carlo
Rear blower motor won't shut off, runs all the time on high when ventilation system is on
Check rear blower control switch for operation and for fault. You may need a multimeter to check electrical outputs.
Nov 03, 2012 | 2005 Lincoln Navigator
The heater fan does not turn on in the front of my 2006 chevy uplander the fuses are all fine and can hear the resistance when i turn the control knob
COULD BE FAULTY BLOWER MOTOR RELAY.CHECK TO SEE IF BLOWER MOTOR GETTING POWER USING A TEST LIGHT.WHEN YOU TURN ON BLOWER SWITCH POWER SHOULD BE AT PURPLE WIRE.IF YES BLOWER MOTOR FAULTY.IF NO YOU HAVE FAULTY HVAC CONTROL MODULE OR BLOWER MOTOR CONTROL SWITCH.
Jan 09, 2011 | 2007 Chevrolet Uplander LS Minivan
Need to remove factory overhead rear DVD player in a 2005 chevy uplander
how do I remove my dvd player in my 2006 chevy uplander? I need to replace it and dont want to spend that kind of money to have it pulled out. I dont see any screws or bolts
Nov 20, 2010 | 2006 Chevrolet Uplander
Chevy uplander rear liftgate will not unlock
The tailgate on my 2008 Chevy Uplander refused to open. The unlock fuse was fine. The handle pull worked fine. I could even hear the little motor that unlocks the tailgate whirr when I pushed the unlock button. But the gate would not release. Turns out the problem was the lock mechanism was jammed because it had dirt in it and not enough grease. From the inside, I pulled the lift gate panel out at the window so I could look down and see the lock mechanism at the bottom of the lift gate. I reached down and prodded it with my screwdriver until I noticed that parts of the mechanism weren't sliding back and forth like they should. I sprayed it with a silicone lubricant until the parts started working again. Finally, the lock unlatched and I could open the rear hatch. I could then remove the entire plastic panel and remove the lock mechanism. I found that the mechanism has lots of rubber and plastic parts which get chewed up and start to jam if not properly lubricated. I cleaned out the dirt with my silicone spray and thoroughly lubricated all the moving parts. The latch now lets go of the post very easily, and the lift gate no longer gets stuck.
Nov 19, 2010 | 2005 Chevrolet Uplander
2005 chevy impala rear driver power window stopped going up.stuck
If neither switch works it is a bad connection at the motor or bad ground or a bad motor. Remove the door panel unplug the motor push the switch and see if there is 12volts on the wires if there is the motor is bad There are small brushes in the motor that go bad tap on the motor while pushing the switch if it works that way replace it
Mar 29, 2009 | 2005 Chevrolet Impala
Blower motor will not turn off when car is off.
If it's only working on high setting it is usually the blower resistor that needs replacing. They are usually located under dash, passenger side, remove cover, and it should be bolted or screwed near blower motor itself. $10-$20 part
Mar 01, 2009 | 2005 Chevrolet Impala
207 people viewed this question
jasbo
jasbo
