Question about Shure 515SBG18X Professional Microphone
Shure 515SBG-18x microphone
My Shure 515SBG-18x LO Z Dynamic microphone doesn't have a connector piece. It looks like something was unscrewed from the bottum. What can I do?
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
The 515SBG does not come with a connector. They come from the factory as bare wire. Thus, every installation will be custom.
Posted on Jul 15, 2010
How do you take a sm85 microphone apart
Unscrew the top portion with your hands to expose the capsule. The connector at the bottom is unscrewed with either a small phillips or slot screwdriver.
Aug 11, 2014 | Shure SM58 Professional Microphone
What type of pickup is in the mike
EC2/58, which includes the world-famous Shure SM58 cardioid
dynamic microphone.
• EC2/87, which includes Shure's SM87 supercardioid condenser
microphone.
• EC2/Beta 58, which features Shure's premium supercardioid dynamic
Beta 58 vocal microphone.
• EC2/Beta 87, which features Shure's premium supercardioid
condenser Beta 87 vocal microphone.
You can look you do a search. Just put in the mic model in the search bar.
You can Y
Jun 11, 2014 | Shure Audio Players & Recorders
Short in wire at plug,cant take plug apart
The mic will disconnect from the transmitter. Simply push the black button and pull outward. Then, the black part of the connector unscrews from the silver part of the connector in order to get at the guts of the connector.
Mar 20, 2014 | Shure SLX Series Wireless Microphone...
I have a client who wants to put hardwired headsets into house sound breakout rooms. Can I use a Shure PG30TQG or a WH20TQG and convert it to hardwire with a MX1BP
Bring a dynamic mic, the WH20 just needs a new connector put on it. The PG30 would need the MX1BP or the RK100PK with a phantom power supply.
Sep 06, 2013 | Shure PG30-TQG Consumer Microphone
How do I take apart a beta52a?
Unscrew the grill and look for a plastic piece that holds the capsule in place. This plastic piece also can be unscrewed and will allow you to reach the PC board inside. Check for broken wiring (most common problem) but low output usually indicates a damaged mic capsule that must be replaced.
Feb 18, 2013 | Shure Beta 52A Professional Microphone
Have a beta 57a it wont work ? nothing
I'm assuming that you have tried the obvious stuff like using a different cable and a different amplifier?
The Shure beta 57a is a very robust and reliable dynamic microphone and there is very little to go wrong with it apart from
  1. A wire broken off inside
  2. A broken capsule - can be caused by dropping it
You can inspect for broken wires by very gently unscrewing the microphone head and peering inside - however the wiring is quite short so be careful not to pull any wires off in the process.
A broken capsule can be replaced - contact your local dealer for parts.
Feb 09, 2011 | Shure SM87 Professional Microphone
I want to take my kms32 apart
Look near the XLR connector. There is an outer ring with two dots. The dots allow for a special tool to unscrew that ring.
May 06, 2010 | Shure KSM32 / SL Professional Microphone
I cannot hear myself on the microphone shure sm58
What sort of a preamp are u using this needs to be plugged into the lo impedance XLR input (this is a lo output dynamic mic 1.85Mv out)
The XLR should be input pin 2 return (gnd) pin 3.This mic does not NOT use phantom power (48v) if it is a dual input (pin 1 48v) source make sure the phantom power is turned of.
If this is being done then there maybe a problem with the mic.
You can check this by plugging a source in to the input to check that it is working line out from cd player midi or some other source.
biinary 6
Sep 16, 2009 | Shure SM58 Professional Microphone
Microphone
It really depends on where you will be using the microphone and and whether it is just going to be used for fun at home or in a club oor for recording?
Some golden rules for microphone selection.
1) Make sure the microphone is Uni-Directional. This means it will only pick up sound from the direction it points in. You are less likely to get feedback or background intereference.
2) For a vocalist, make sure the mic is a reasonable size. If it is too small and you need to hold it, after a while it becomes fiddly and uncomfortable.
3) When singing always use a foam hood or pop filter with the microphone. This will reduce explosive sounds on the letter "P" etc.
4) Choose a microphone with a wide frequency response but not too much bass which can make vocals sound boomy.
5) Finally, the microphone must have a reasonable dynamic range so that if you suddenly shout it does not distort excessively, but it will also work when you speak or sing softly.
Feb 29, 2008 | Audio Technica Audio-Technica ATW-T341...
Shure 515SBG18X Professional Microphone Logo
128 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
