Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
How to test heating element in kenmore h3 dryer
  • 5,911 Answers
You can test the element while it is still installed if you like. Just make sure the dryer is UNPLUGGED, first. Dangerous voltage is still present with the dryer turned off. Remove the lower toe panel under the dryer door. This is accomplished by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off.
NOTE: Propping the two front feet of the dryer up can provide better access. Placing the feet on a 2x4 works well for this).
You have to remove the blower fan housing to better access to the heating element. Make sure you reach inside the door and remove the lint screen first. Then, remove the screws holding the assembly in place and remove.
Disconnect the wires from the heating element before taking any measurements. This ensures your readings are accurate and you do not read any parallel resistance paths. Do a resistance check across the heating element terminals making sure you do not ground your leads to the element heater box. A good reading will be between 9 and 13 ohms. If you have any questions, please let me know.
NOTE: This is a good time to clean the dryer interior and blower fan, while you have everything removed.
Posted on Nov 15, 2009
2 Suggested Answers
  • 13 Answers
SOURCE: kenmore stack unit dryer not heating
Dryers usually have 2 thermal sensors a low temperature sensor and a high temperature sensor. The parts are inexpensive and if one or both are bad, they will keep the dryer from heating.
The way to check them is to use an OHM meter to see if they are OPEN. If you are using a Digital ohm meter, the setting will most likely read OL for overload.
It is most likely the low temperature sensor, but could be either. Replace both. Again, they are inexpensive and easily replaced.
To access them, you have to get to the back of the dryer and remove the panel. UNPLUG POWER before taking the back panel off. You will see 2 small rount (quarter sized) pods attached by sheet metal screws to a vent stack. One at the top and one close to the bottom. The wires should have push on connectors.
Remove the wires and check each with an ohm meter to be sure.
That is your most likely culprit.
Have FUN!
Posted on May 07, 2009
Where is the heating element for a Kenmore heavy duty 60 series soft heat large capacity?
How to Replace Your Electric Dryer's Heating Element
www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid Electric Dryer's Heating Element. Here's a common job that many folks are afraid of, but it's ...
Whirlpool / Kenmore Dryer Heater and Thermostat Test ...
? 7:40
https://www.youtube.com/watch?v=KZY9CQ_CqvY
Sep 13, 2010 - Uploaded by Bill Newberry
Basic checks for a Whirlpool made dryer. ... Whirlpool & KenmoreDryer Repair - How To Diagnose No Heat ...
Whirlpool - Kenmore - Maytag Dryer Not Heating Repair ...
? 2:42
https://www.youtube.com/watch?v=i95okOr2rOI
Mar 1, 2011 - Uploaded by ApplianceAdvice
It will explain step by step instructions on how to test the thermostats, fuses, and heating element inside the ...
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
Dec 12, 2015 | Kenmore Dryers
Dryer spins but no heat
Conventional dryers are usually accessed by removing the rear panel. I would think these would be the same. Unplug the dryer and remove wires from heating element. Test for continuity with an ohmmeter. If there is no reading, the heating element is bad. Disconnect wires from the hi temp thermostat and test with an ohmmeter and if no reading it is bad. Sears has these parts available.
Nov 07, 2013 | Kenmore Dryers
My Kenmore Elite H3 dryer check the lint screen comes on when I try to dry my clothes but the dryer does not produce any heat help me
You should check for continuity on the heating element. If you have continuity there, be sure you have voltage to the element. You have 2 (I beleive) temp sensors in line also. Check them, one may have a reset button (not sure). Make sure your exaust duct is clear to prevent thermo sensor burn out in the future.
May 16, 2011 | Kenmore 82822 Electric Dryer
My Kenmore 400series 6942 electric dryer works, but doesn't get hot. Pulled the heating element had it tested. It shows good. Had three other relay/fuses tested. They show good. It has to be easy enough...
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpg if there is no heat then one of the thermal fuses is bad you will need to check the continuity on them and replace the one that does not have any continuity
Jan 20, 2011 | Kenmore 400 6942 Dryer
Kenmore series 70 dryer will not heat up replaced heating element thermostats check ok with ohm meter
If heating element was replaced and still no heat, Then what I would do is test the voltage current in the wiring and see if there is actually power to the element.
All parts to make dryer heat are:
heating element
thermal fuse
thermostat
timer
any one of these units can be faulty
Oct 10, 2009 | Kenmore Dryers
T|he heating element won't stop heating
Hi, The element has broke and shorted out against the metal on the dryer. You will need to replace the element. If this is a rear access panel dryer, here is how to get to the ele UNPLUG the dryer! Remove the rear panel of the dryer and locate the element on the right hand side. Plug the dryer back in and test to see if there is 240V going to the element posts. If there is voltage, but no heat, change the element. If it does not, you need to test the thermostats for continuity. If any of the thermostats are open, replace it. I hope this helps you.
Please let me know if this help or if I can assist you further.
Thanks
Vic
Jul 15, 2009 | Kenmore 62602 Electric Dryer
Heating element gone in our kenmore dryer
Hi, Without having a model # so I can see the exact dry style you have, This is how to get to the most popular style element. UNPLUG the dryer! Remove the rear panel of the dryer and locate the element on the right hand side. Plug the dryer back in and test to see if there is 240V going to the element posts. If there is voltage, but no heat, change the element. If it does not, you need to test the thermostats for continuity. If any of the thermostats are open, replace it. I hope this helps you.
Thanks
Vic
Jul 12, 2009 | Dryers
Dryer not heating everything else works fine had heating element tested and it is okay
Just a general troubleshooting guide for your washer! hope this helps!! PS don't forget to give me a rating if this helped!! Thank you!!
http://fixitnow.com/2005/09/washing-machine-diagnostic-and-repair.htm
May 07, 2009 | Kenmore 64992 Electric Dryer
Everything seems fine but will not heat up I checked continuity, on every thing and it seems fine and I did the more less more less and all codes came up fine took the heating element out and it seems fine...
First things first...Are you sure that you have 220 volts to the dryer? Just because the motor runs doesn't neccesarily mean you have the proper voltage. Also check the connections where the cord comes in to see if they are tight and intact.
Apr 06, 2009 | Kenmore 63942 Dryer
Heating element continuity?
Unplug the dryer from the wall. There are 2 wires connecting power at the heating element. Take one of these wires off, doesn't matter which one, but take at least one of the 2 off. Then put your meter probes across the terminal of the heating element where you took the 1 wire off and the other terminal of the heating element that still has a wire on it. Your meter will pretty much read full continuity if good, no reading at all if bad. Also check from one of these terminals of the element with one meter probe going to the metal frame of the unit. You should get no reading. If you do the element is shorted and would have likely tripped your house breaker.
Better to test a heating element for voltage with your meter like I described to you in your other question. I've seen heating elements read good when just doing a continuity test, however once voltage is applied and they start to heat they can expand and open up, thus not work, even though testing good when doing just a continuity test. Not always, but sometimes, it does happen enough to note to you.
Mar 11, 2009 | Kenmore 62602 Electric Dryer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
408 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
