Question about Microsoft Xbox 360 Console
MTU every time i try to sign into x box live it says that my mtu failed and every thing else above it is fine!
    President:
  • 4,402 Answers
Http://support.microsoft.com/kb/908882
Posted on Jan 09, 2008
Not enough mtu to go to xbox live at hotel
An MTU is the largest physical packet size, measure in Bytes that a network is capable of transmitting.. If messages are larger than the MTU they are divided into smaller packets before they can be sent. All networks have different MTU's which the owner of the network set at what they want to set it at. 576 is a very common MTU if you connect through PPP. 1500 is the most common MTU for Ethernet connections. The Xbox Live system requires your network to have a certain Maximum Transmission Unit (MTU). MTU values are important to the performance of online games. If this test fails, you can adjust the MTU setting on your network router or equivalent device to resolve the problem. Xbox live requires the network you use to have a maximum MTU. This is key to online gamesing. If the MTU fails then you have to adjust the router you are using. If you cannot access the router to adjust the MTU the you will not be able to play online games.
Mar 22, 2011 | Microsoft Xbox 360 Console
Tip
XBOX LIVE MTU ERROR FIX IF ALL ELSE FAILS
MTU ERROR FIX: IF YOU TRIED EVERYTHING EVERYONE ELSE SUGGESTED DO THIS, CHECK TO SEE IF YOU HAVE FIREWALL RUNNING ON SECURITY SOFTWARE (MY CASE WAS AVG INTERNET SECURITY) DISABLE IT AND EVERYTHING SHOULD WORK FINE, IT DID FOR ME AND I HAD LOST ALL HOPE AND XBOX LIVE HAD BEEN WORKING FINE BEFORE THIS ERROR BUT I RUN MY XBOX CONNECTION FROM MY PC (ICS) SO THATS PROBABLY YOUR PROBLEM IF YOUR SET UP LIKE ME. ITS THE SIMPLE THINGS THAT CAUSE THE BIGGEST PROBLEMS.
on Mar 08, 2010 | Video Game Consoles & Games
360 mtu test keeps failing
Access the routers setup page by typing 192.168.1.1 (ip address of the router) on the address bar on IE.
then on basic setup page at the bottom part of the page you will see MTU normally its on auto,
to change the value set it to manual. ask your isp what is their prefferred value for the mtu you can go as high as 1300 to 1500.
Sep 13, 2008 | Linksys Wireless-G WRT54G Router
Xbox live cant connect mtu failed
Hi can you please help me i was on xbox live tryed to connect with a router and now my 360 is askin for an ip address,but we do not no it can you please help thanks Paul
Aug 02, 2008 | Microsoft Xbox 360 Console
X-box live and mtu setting
im having the same thing happen to me it used to work and now it always says mtu is to low i think its because this router is **** and just doesn't work i got this from some one else for free and the wireless doesn't work at all (for my wii) and there right next to each other
Jul 29, 2008 | Blitzz Technology BWA711 Router...
Mtu test is failing
I've had the same problem and struggled with it for hours... If your on the Comcast network, there seems to be problems with adjusting MTU. I have a Dell 2350 router and that particular router cannot have MTU modified. Also, sometimes the MTU is effected by computers or phones in the house being on. One more suggestion, try a gaming router. Good ones start at 90 dollars, somewhat expencive but well worth it.
Jun 03, 2008 | Microsoft Wireless Network Adapter Xbox...
Mtu
If you have your Xbox connected through a router, most routers, on their control panel (192.168.1.100 for example) give you the option of setting an MTU, or leaving it to default. This option is normally found on the setup page of your routers control panel.
MTU stands for maximum transmission unit, basically a speed thing.
If you can set it, change it to something above 1500 depending on how fast your internet connection is, but I am fairly certain that 1500 is the minimum that you would want to have set for xbox live.
Another way to do it is, if your router has this option, set the MTU to Automatic. That way your router (should) be able to do all of that dynamically as the need arises.
I hope this helps to solve your problem, good luck!
May 16, 2008 | Microsoft Xbox 360 Console
Mtu keeps saying failed
I assume you mean you can't play games online?
Is your account Gold or Silver? (Go the the Marketplace blade, then down to account information, membership.)
You can only game online with a Gold subscription, which is like $50/year.
May 11, 2008 | Microsoft Xbox 360 Console
Xbox live
You appear to be on a router where you flipped on a security switch in the router and now this MTU is not working properly. There is a small, small button on the back of your modem or router. You have to press it with the tip of a pen, it's that small! This will reset all settings on the modem or router and then you can power off and on the box for 30 seconds, leave it on and try again. ONLY DO THIS IF YOU OWN CONTROL OVER THE BOXES OR GET PARENTS PERMISSION FOR THIS KIDS! By default, all the security settings are disabled and go back to original working state for configuration or use or the box. If you turn on anything security related on your router or modem, this will give you MTU issues all the time! Stop touching those settings if you don't know how to configure a router.
Apr 26, 2008 | Microsoft Xbox 360 Console
MTU fail actiontec gt704wg
I opened my xbox 360 and i did not see a switch any where. don't do it its a lie.
Jan 06, 2008 | Actiontec (GT704WG) Router
Microsoft Xbox 360 Console Logo
22 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
