Question about Pioneer DEH-P5500MP CD Player
Faceplate DEH-P5500MP My unit and faceplate works perfectly except for the LCD display lites. I can't read anything on the face plate. I had it in its protective case and dropped it. The lites stopped working. I took it apart, played around with it put it back together and it worked fine till I dropped it again. I tried to manipulate it again but no luck! Is there a way to repair this or do I need a new faceplate?
Dude im real good at this stuff and if u dropped it once ur lucky it still worked but if it dont work now ur definitely going to need a new one...
Posted on Jan 09, 2008
Basically I have the same problem that has been displayed a lot on this site. My pioneer DEH-P7800MP display won't show when the face closes. When the face opens up all the buttons and lights and display...
The faceplate and head unit is is attached via a flat ribbon cable. (Caution only continue if you have some courage). If you open the faceplate you will see that the ribbon cable is seated in too a flat connector on the PCB (Printed Circuit Board). This connector has a locking mechanism on it that when locked presses the contacts of the cable to the connector. Ensure that the cable is seated properly and that the latch or the lock is in the locked position. Assuming that the tension lessons when the unit is closed so it draws away from the connector and when the unit is open it pulls tension creating a contact. If you see no signs of mishap on this end of the connector try the other end.
Hope this helps.
Nov 17, 2010 | Pioneer DEH-P7800MP
How to reset my DEH-P5000UB, because my display turned off, weird
Re:"everyother light turns on the faceplate but the display is off"
That means that the unit is either faulty, or one of the two powered lines required had not been connected.
The unit is reset by simply disconnecting the connector at the back.
This will not help in fixing the problem.
Ensure that unit is wired properly. Use a voltmeter to test wiring.
Here installation manual with proper wiring.
Here also the owner manual.
May 26, 2010 | Pioneer DEH-P5000UB Car CD/ MP3 Player
Pioneer deh p3100ub shuts off when i touch deck
sounds like the faceplate is not seated right or has dirty connections but it is in your detachable face plate. your still under warenty.
May 24, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
None of the buttons on the faceplate seem to work except OFF. The remote works and still can control all functions on the radio. I have read the manual and don't see anything about the faceplate locking or...
check the gold contacts on the back of the face and the unit also check the release mechanism theres a little black button (not the reset) that when face is pressed up against it it activates power to the gold contacts thus powering the buttons
Dec 14, 2009 | Sony XPLOD CDX-GT200 CD Player
Another one with Faceplate buttons not working?
The capacitors in these plates tend to burn out quickly for being so hot and lack of air cooling circulation. You can test all connection pins on the deck and faceplate with an ohmmeter in ohm setting to see which pins is not sending 25-30 ohms or 5 volts of power
Oct 23, 2009 | Pioneer DEH-P3500 CD Player
Buttons locked
if the face is remove able change the face your problem like that is cause by face plate
Jun 24, 2009 | Pioneer DEH-P6700MP CD Player
Screen not working, but controls do work
the ribbons do brake no then alot and its not cheap to have repaired as well mos of the time its the side of the light which brakes first and the rest stays working but the only other thing it can be but i cant see it is the leds in the front screen have all blown have you drop the face plate if so you might have damaged the pcp board i hopei might of helped you let me know how you get on
May 29, 2009 | Pioneer DEH-P9800BT CD/MP3/WMA Player/Blue...
Pioneer premier deh-p980bt screen went blank
Its the ribbon cable needs replacing going from the deck to the faceplate
May 29, 2009 | Pioneer DEH-P6800MP CD Player
My Pioneer DEH-P645 faceplate display is FAINT
The circuit board is broken.
I was trying to find out about setting the display dimmer option. I found someone that had a manual and was told to set/reset the "dimmer on/off" by pressing the function button repeatedly while the unit is powered off. When dimmer showed on the faceplate press up or down to set or reset the dimmer option. This was done in a dark closet as the display was so dim. Anyway, setting dimmer to on/off made no difference in the brightness of the display. Oh well. . . BTW, I found that the manual is not a free download and can cost between $18 - $40 on the internet - geeeeee whiz, Pioneer is not a user friendly company.
Mar 06, 2009 | Pioneer DEH-P645 CD Changer
Pioneer DEH-P6900UB
make sure that you have power not only to the red wire but also the yellow wire... one is battery power the othe ris ignition on power. If it only is getting one power it might not think the ignition key is on.. also maks sure there is not a reset button somewhere that you can press with a pen...
Aug 27, 2007 | Pioneer DEH-P6900UB CD Player
Pioneer DEH-P5500MP CD Player Logo
202 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
