Question about Xerox XA7-172i 17" LCD Monitor
Only displays for a few seconds - Xerox XA7-172i 17" LCD Monitor
  • Argospete May 11, 2010
    HAVE U PROPERLY SECURED PLUGS TO SOCKETS BOTH ENDS?
Stove clok is not showing time
try pressing the clock button after setting the clock .^-^
Mar 09, 2015 | Kenmore Kitchen Ranges
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermostat
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Feb 08, 2013 | Microwave Ovens
Display out after few seconds and a few seconds will appear
this is a problem with your phones display. It is better if you can insert a new display unit from a phone repairing shop
Jul 03, 2009 | Nokia N70 Cellular Phone
No display ,hangs and switches off/on bytiself evevy few seconds
it can be the virus... try to format your fone mate... type *#7370# then your security code.. w8 until it reboots....
Apr 23, 2009 | Nokia N70 Cellular Phone
Clock doesn't stay lit up
To turn the time of day display OFF or ON in the display press and hold for 15 seconds (the control will beep
once) and then release. This feature does not remove the set time of day from the memory of the control. When the display
is turned OFF the time of day will re-appear for a few seconds any time the pad is touched
Mar 04, 2008 | Frigidaire FEF366 Electric Kitchen Range
Oven controller not functioning
9. The time of day does not display on my electronic oven control. If I push the CLOCK pad on the control panel the time will display for a few seconds and then it goes blank again.
  • On many ranges with electronic controls the time of day display can by turned off or on by holding the CLOCK keypad down for 15 seconds.
    Push and hold the CLOCK keypad. The time will appear for a few seconds, and then disappear and finally it will reappear and beep. Release the keypad and the time should continue to display. Follow this same procedure to turn the time display off.
http://www.frigidaire.com/support/FAQ-New_Electric_Smooth_Range.asp#9
Nov 04, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Xerox XA7-172i 17" LCD Monitor Logo
53 people viewed this question
Top Xerox Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
JC Meredith
JC Meredith
Mark Magill
Mark Magill
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
