Question about Bugaboo Cameleon Jogger
Brake doesn't work on bugaboo pushchair
One of the brakes on my bugaboo cameleon pushchair isn't at the same level as the other one and doesn't stop the rear wheel when I put the brakes on. Only one brake works, basically.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 274 Answers
You can have it fixed @ www.buggypitstop.co.uk thay fix bugaboo's and sell spare parts.
Posted on Jan 11, 2010
Can I replace white break with australian red break?
Last week the brake was broken and my husband bought a new brake in ebay and it was so easy to change. He found many brake's sellers and he bought to the cheaper one. I leave the link where he bought it if you can help.
http://www.ebay.com/sch/i.html?_sacat=0&_from=R40&_nkw=bugaboo+cameleon+brake&LH_PrefLoc=2&_sop=15
Dec 03, 2012 | Bugaboo 'Cameleon' Stroller
The brake on our bugaboo cameleon is not working
Jun 04, 2012 | Bugaboo Baby Gear
Bugaboo cameleon cable repair issues: I just installed a new cable for my bugaboo cameleon and after I finished, the wheels are in a brake position with the level not being on brake. How can I fix this...
Your inner wire cable is to short in relation to the outer black cable. Check outer cable is correctly seated in to lever assembly and the cable adjuster at the bottom end of the black outer cable. Is the cable adjust wound right back? I've added a link to my tips section you may find more help there. www.fixya.com/support/r7805449-fix_bugaboo_brake
Aug 10, 2011 | Bugaboo Cameleon Jogger
My stroller is 2 years old and i want to get the brakes checked and replace some parts before baby number 2 arrives. is there anywhere you can take it to be serviced?
Your Bugaboo is now out of warranty so Bugaboo won't be very helpful. Google to see if there is a local stroller repair agent if not try your local bike shop.
Dec 31, 2010 | Bugaboo 'Cameleon' Stroller
Wheels sticking will not open lock jammed
The bugaboo brake lever can lockup. Check the screw nut at the bottom end of the cable. If you can wind that down to take some tension off the cable the lever will them release. If there is no adjustment try lifting the lever up higher (as to put the brake on harder) then push the white release button at the same time. The break lever uses a set of ratchet teeth that must move up slightly to release.
Dec 30, 2010 | Bugaboo Cameleon - Tailored Fabric...
Cameleon Jogger Stroller: The brake cable has snapped on my Bugaboo Cameleon...
You should contact www.buggypitstop.co.uk they are the only company I know that sells bugaboo spare parts like brake cables and levers.
May 18, 2010 | Bugaboo Cameleon Jogger
How do you use the brakes on a Bugaboo Cameleon I am having problems with it
Your brakes may need adjusting you can do it yourself or get in touch with www.buggypitstop.co.uk they do all repairs to bugaboos
May 17, 2010 | Bugaboo Cameleon Jogger
Bugaboo Replacement Brake Foot - Cameleon
you can try www.buggypitstop.co.uk they do repairs to Bugaboo they should be able to help. They fixed my pushchair and did a great job. I would highly recommend them.
Mar 05, 2009 | Bugaboo Cameleon Jogger
Hood for bugaboo cameleon pushchair
you can order it through bugaboo or a local retailer.
Nov 11, 2008 | Bugaboo Cameleon - Tailored Fabric...
The lock on the brakes of my bugaboo cameleon doesn't work.
I just repaired my Bugaboo Chameleon brake. If the white brake lever doesn't "lock" i.e stays in its forward position, locking the brake you need to disassemble the brake handle housing. Open the black plastic cover by unscrewing the two screws. The handle should come off with a little tweaking. Remove the brake wire. The "button" where you are supposed to release the brake is actually a sort of cogwheel that stops the lever from springing back. Sometimes the cogwheel gets too pushed in the handle. You can tell if it has done so by observing the 8 small grooves that are out of place. Simply take a small flat object like a flat screwdriver and pry the button out. It should pop out as it is spring loaded. Now put it back in its position but TURN IT so it fit in the grooves. Put it back in the black handle, by reversing the disassembly process. Easy!
Best Regards,Fred, Stockholm, Sweden(Sorry about the English, hope you understand)
Aug 17, 2008 | Bugaboo Cameleon Jogger
Bugaboo Cameleon Jogger Logo
477 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
