Question about Kenmore Elite 45986 Front Load Washer
How do you reset the overfill switch on the kenmore Elite calypso machine? It shows FL and we cut the power. There is water inside
  • 15,935 Answers
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
I have kenmore elite calypso washer. FL shows on the control panel. Some says drain the water manually or check the water pressure. how do I do it?
Probably something in the pump. Remove the base panel take the pump apart get the junk out of it
Older Calypso washers have a pump like this newer ones have a diff type pump that can be taken apart. The FL error : FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for FL to be displayed.
Causes of flood condition. Inlet valves stuck on, Sediment in water level pressure tube. Clogged pump. All of the above. Service manual and more HERE
And HERE
Jul 01, 2011 | Washing Machines
Washer won't drain..like filter is clogged
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%@#$
Mar 27, 2010 | Kenmore Elite 21082
Just replaced the motor and pump, 3 weeks ago. Now I am getting an ld and then an FL?? Calypso Kenmore washer Elite
Flood Condition:
Mar 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite washer model 21082000, won't
Flood Condition:
Feb 19, 2010 | Kenmore Elite 21082
Machine stoped after wash cycle tub did not drain and reads F L kenmore elite calypso model #22064 100 type 170 cannot get it to start at all it keeps beeping and reads FL
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%#@$
Feb 09, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Calypso SM9710976A has "FL" on front panel. Whats wrong?
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^!!$#
Oct 14, 2009 | Kenmore Elite 45986 Front Load Washer
My kenmore elite reads fl and stops working,
Flood Condition:
Jun 16, 2009 | Kenmore Elite 45986 Front Load Washer
My Kenmore elite with Calypso motion top load washer is reading FL and is asking for the overfill switch to be reset. water is leaking from underneath. what do i do besides turn the water off to the...
Flood Condition:
Jun 07, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Calypso 21082
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@
Dec 16, 2007 | Kenmore Elite 21082
FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. This could just be a fluke, or you could have a possible bad pressure switch that is not shutting off the water supply correctly. In addition, fill valves have been known to short out causing water to constantly fill in the wash tub. Lastly, your household water pressure could be too low and won't shut the fill valves off properly. Inlet water pressure should be a minimum of 10-20 psi. With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display. I hope some of this leads you in the right direction.
May 12, 2007 | Kenmore Elite 21086
Kenmore Elite 45986 Front Load Washer Logo
243 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
