Question about Elna 2007 Mechanical Sewing Machine
Needle stays stuck whilst motor runs. Elna sewing machine
Every few seconds the needle stays down and doesnt move but the motor still goes, plus motor makes a squealing noise sometimes...a mechanic on phone said it might be the timing? is it fixable at home?Its an Elna Stella SP sewing machine.
  • Elna Master
  • 1,133 Answers
Its a lovely swiss made machine, this is an electronic motor so the needle pressure should remain constant no matter what speed you sew at. The needle staying down and the squealing sounds more like drive issues inside or possibly gunk buildup.
If it was my machine, I would take it to a qualified Elna technician and ask for him to look at it. These machines are small and well made so well worth spending the money to give it a service and get it back to 1000% IMHO.
Posted on Apr 11, 2011
  • Tally Girl
    Tally Girl Apr 11, 2011
    whoops, typo, that would be 100%
The feed dog is up but has stopped feeding
Are the feed dogs moving at all--like moving toward the back of the machine, dropping down below the needle plate, moving forward, rising, and then moving toward the back of the machine? Make sure the stitch length is set high enough to actually move the fabric--not set at zero or near zero. If the feed dogs stay below the needle plate, then most likely they have been dropped for darning.
If the feed dogs are frozen, not moving, and it is an older mechanical machine, they may be seized due to old oil.
Wheel on right side that controls the needle up and down is very tight...
Or, the feed dog mechanism is broken.
Sep 01, 2017 | Sewing Machines
Machine stiches fine a few seconds then slows to a stop
Not knowing the make & model of your machine, it is difficult to advise. If it is a mechanical machine, could very well be that it is seizing due to old oil prohibiting mechanical parts from moving.
Jan 12, 2017 | Sewing Machines
Why does it make a knocking noise as it sews?
the needle position is up tight in the holder and no where else
the cut away bit of the needle faces the bobbin case hook and the groove in the needle faces the end of the machine and gives clearance for the thread to pass through the material
from your description and what you did, the needle /hook timing needs adjusting as it is out
turn the machine over by hand as in sewing and watch the position of the eye of the needle and the bobbin case hook
just as the needle starts to move up, the hook should be just above the eye of the needle at the edge of the needle
The adjustment is by loosing off the screw on the vertical shaft at the end of the machine that is attached to an arm that moves the needle up and down and move that bit up or down until the needle is positioned correctly to the hook
tighten up the screw
next is to check the needle tension is not too tight
workshop manuals are available on line in pdf version or take it to a sewing machine repair shop for a proper diagnosis
May 12, 2016 | Singer Stylist 7258 Electric Sewing...
Machine won't sew
they do have a belt that breaks .I would suggest a repair shop visit
Dec 12, 2015 | Singer One Plus Computerized Sewing...
I have a Bernina 180 sewing machine that the needle is not coming down?
This might be a bit hard to explain without showing you a video or photos, but here goes.
The 180 and many other Berninas do what is called a basting stitch. When a machine is doing this stitch the needle stops going up and down for a very short time this producing a long basting stitch. There is a mechanism on the needle shaft that has a black short lever on it. When the basting selanoid pushes in on this lever the needle stays in the up position. Simply stated this lever mechanism can stick if it is not oiled and your needle will stay in the up position and not move when the machine is running. Sometimes just pulling the needle shaft down, then letting it go so it snaps back up into place will lock the basting ever back in place. Once you get the needle shaft to lock back in everything will work again.
I can guarantee you that this is your problem if the machine runs but the needle stays in the upper position. I pose helpful Bernina videos on YouTube under the name JoeKind1958. It would be so much easier to show you how to oil the basting assembly on your machine. Contact me through that site and I can make a video showing you what to do.
Aug 08, 2014 | Bernina Artista 180
Trying to make a buttonhole on singer 7422. Using a sample piece of the 2 fabrics together which the finished piece will be, the buttonhole worked perfectly. On the actual object, again 2 fabrics, the...
One thing to try is that the button hole lever has not moved to the front or back of the guide, make sure that it is in the direct middle. Sometimes they get moved when you take out or insert fabric. If, that is not it, call Singer and find out if there is a problem with this model, because if it is maybe you can exchange it. Their phone number, 1-800-4singer
Jan 04, 2011 | Singer 7444 Mechanical Sewing Machine
I have a Brother ex-660 and it is making a thumping noise, it seems to make the noise every time the needle goes down into the fabric. I noticed the plate under the fabric is chipped (could be from the...
Change the needle and then using the side wheel wind through the stitch process manually. If the needle is still hitting something down under the needle plate, then your timing is out, take it to a mechanic.
Oct 07, 2009 | Brother Sewing Machines
Motor works needle does not go up and down
You can call the company toll-free at 1-800-361-4639 and they can tell you what to do. All the phone reps I've talked ot have been wonderful.
Mar 25, 2009 | Euro-Pro Deluxe 7130 Mechanical Sewing...
Elna 2007 Mechanical Sewing Machine Logo
504 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
