Question about Price Pfister Single Handle Lavatory Faucet - 42 Series T42-AMCC
I have a price pfister kitchen faucet with 2 handles, similar to the Avalon, and I have a drip and I think it is the cold water side. but how do you get to the seat to possibly fix. The handle is all smooth.
  • 119 Answers
There is no seat replace cartridge/stem
Posted on Nov 15, 2009
How to disconnect the quick connect spray hose in a Price Pfister Parisa
I also needed to remove the "hidden" flow restricters from my Price Pfister Parisa Kitchen Pull out faucet. The hot water side had never flowed the same as the cold side. Now both sides are flowing the same as should have been all along.
Nov 30, 2012 | Price Pfister Marielle Kitchen Faucet with...
Faucet dripping
Call Price Pfister at 1-800-PFAUCET and ask them to send you a new hot and cold stem for free. These faucets are easy to repair. Here is the parts breakdown for your faucet. Turn the water supply of to the faucet. Remove the index button from the top of each handle. Unscrew the handle retaining screw. Pull the handle off. Unscrew the stems with an adjustable wrench; turn them counterclockwise. Install the new stems and reinstall the hanldes; it may take a couple of times to get them set in just the right positions. Slowly turn the water back on and open the faucet.
Sep 05, 2010 | Price Pfister Savannah Two-Handle Kitchen...
I installed Series 26 Avalon faucet. The water flow rate is very slow. All fittings to the faucet are new. Could the problem be a faulty valve ?
Remove and clean the Price Pfister aerator. Turn the water on after you remove the aerator and check the flow-rate. Many new Lavatory and kitchen faucets are now equipped with Eco friendly water saver aerators. if the flow is normal without the aerator, the faucet is OK. if you want more water flow from your lavatory faucet, you will need to buy one of the old style high flow aerators from your hardware store. If you remove the aerator and still get low pressure from both hot and cold faucets, you may need to replace the faucet. Call the Price Pfister warranty phone number that came with your faucet.
Aug 28, 2010 | Price Pfister Plumbing
Dripping faucet price pfister kitchen
Very nice kitchen faucet. I like Price Pfister's products. To repair it you will need a phillips screwdriver to remove the handles and crescent wrench to remove the cartridges. If it is dripping then one of the faucet cartridges need to be replaced. Its best to replace both cartridges as inevitably the other one will start to leak after you've replaced the troublesome one. Your local hardware store or plumbing supply store should have a replacement cartridge for this model. Remove one of the cartridges and take it with you to ensure you get the correct part. There is an exploded diagram of your faucet on the Price Pfister site at that shows the part number for the cartridge. Good luck and let me know how it turns out.http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/savannah/savf8h6-85/ex-036-01.pdf
Jul 25, 2010 | Price Pfister Savannah Two-Handle Kitchen...
Installed a new price pfister two knob kitchen faucet and the cold faucet turns off backwards. How do I make it shut off in the right direction ? Thanks !
you will have to remove the faucets and turn the base around, that is the only way to make it right you installed them backwards
Jun 28, 2009 | Price Pfister Savannah Two-Handle Kitchen...
Installed new faucet worked then all water stopped
If it has a side spray the diverter might be stuck. try flicking the spray handle on and off.
Jun 10, 2009 | Price Pfister Marielle Kitchen Faucet with...
Kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
May 04, 2009 | Price Pfister J103-BC 100 Series Kitchen...
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Handle on faucet shuts off on its own
I had the same problem. The Price Pfister web site recommends removing the handle (unscrew the dome cap, then remove the phillips screw to get the handle off) then tightening the retaining ring (I used channel lock pliers on largest setting. It worked. However the retaining ring is plastic on some models, and they recommend replacing it with a brass one. I haven't taken that step yet, we'll see how it goes (mine is plastic).
Dec 01, 2008 | Price Pfister Marielle Kitchen Faucet with...
Price Pfister Single Handle Lavatory Faucet - 42 Series T42-AMCC Logo
227 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
