Question about Brother MFC-5840CN All-In-One InkJet Printer
I desperately need to perform a scan, but cannot
I desperately need to perform a scan, but it will not let me continue without replacing the ink cartriges, it is now midnight, what can I do?
    President:
  • 2,049 Answers
There is a sensor in the printer that checks ink levels. The sensor uses a beam of light to do so; if the light bounces back, the machine assumes there is ink in the cart and continues to operate. If the light is not bounced back, the machine assumes that the cart is empty and starts beeping and won't allow any other functions until cartridge is replaced.
Take a piece of black electrician's tape and placed it on the cartridge’s spine. The sensor will assume the cartridge has plenty of ink and will function.
Posted on Nov 15, 2009
Testimonial: "I cannot thank you enough for the quick post, your suggestion worked perfectly, you saved me from A LOT of trouble!"
    Master:
  • Brother Master
  • 956 Answers
GO TO BED, IN MORNING PURCHASE REPLACEMENT CARRIAGES, MAKING SURE U HAVE A STANDBY, FOR NEXTIME?
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
I installed the drivers for a canon pixma mp210 and it wont scan. it keeps saying " E 1 6"
"E 1 6" error code means Ink has run out.
Replace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress and you want to continue printing, press the Stop/Reset button for at least 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing. The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
Jun 11, 2011 | Canon PIXMA MP210 InkJet Printer
My Deskjet 1220c printer does not print it just take out papers without being printed
Ink jet printer manufacturers have us between a rock and a hard place, use it and you have to replace empty cartridges, do not use it and the cartridge jets dry up and can more often than not, not be unclogged, and I fear this is your case. Try standing the underside of the cartridges in a shallow dish of hot water for a while, repeat several times if necessary and then try perform the cartridge cleaning procedure. If it does not work try taking it to an ink shop to see if they can apply suction to clear them, but I fear you may end up having to replace the cartridges.
There is another desperate measure you can use at your own risk and a mouth full of ink, With the cartridge upright, give a short sharp **** on the print jets. You will possibly get a mouth full of ink but it often works - this is at your own peril!
Mar 29, 2011 | Office Equipment & Supplies
Won't fax without ink
This is a Inkjet printer, i needs ink cartridge to be filled to function properly.
Please replace ink cartridges. You cannot print with one ink tank.
Regards,
Riztech
Mar 04, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Can I scan
go to scanners and cameras in the control panel and double click on your scanner, you should now be able to use your scanner directly without using Kodiak's software.
Aug 14, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
PIXMA MP610 can't scan without ink (makes no sense)
You can scan when out of ink. You have to press and hold the reset button (red triangle inside a circle) for five seconds which tells the printer to ignore ink problems and continue.
Jul 24, 2009 | Canon MP610 Photo All-In-One Printer
Canon MP240 all-in-one, doesn't scan without ink???
hello!
I had the same problem, and I solved it.
You have to disable ink status wiever, you do that by holding start/stop button for at least 5 sec.
by konac!
Apr 03, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Just want to scan, no ink cartridge
Just press the Reset button for 5 sec till it displays "1" then u can scan without replacing the ink.
Mar 13, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
CANON PIXMA ERROR 5800
The waste absorber is full ,Replace the pads
then if you still get the error,you can reset it by following the directions below.
(reset without replacing pads can cause damage)
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
2) Enter NVRAM by pressing <--- or ---> then OK
3)SET ABS-M LEVEL TO 0
4)OK
Jan 20, 2009 | Canon Pixma MP450 All-In-One InkJet...
I have a new canon mp210 printer ink is low i bought new ink to replace old their is no ink cartridges in printer. When i look at the pictures to load new ink and put it in alarm light is flashing
Even if the ink level is low, you can continue printing.Press the paperfeed knob for 5 seconds. inklevel indicator will stop now.
Sometimes a new (or refilled) cartridge is not recognised correctly.
When one color is really mt, stop printing and replace inmideatly the colorcartridge.Printing or scanning without the 2 cartridges in place is impossible.
Dec 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Brother MFC-5840CN All-In-One InkJet Printer Logo
200 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
