Question about AcerPower 1000 - Athlon 64 3800+ 2.4 GHz PC Desktop
I cannot seem to update the bios, it keeps saying jumpers not set properly. in the bios screen it says boot sectors is set to erasable. my machine type is the acer power 1000 (w athlon chip)
    President:
  • 995 Answers
1. Don't flash your BIOS unless you really need to. If you got a reason for flashing your BIOS, by all means, but remember that If you load the wrong version or something goes wrong, it's a new motherboard that you will be needing.
2. Get the correct install procedures from the makers of your motherboard or the place where you downloaded the BIOS update from. If you know how to read, you know how to do it. There is nothing very complicated here.Be safe and good luck. :-)
Posted on Nov 15, 2009
I have a Acer Aspire3680-2022 Laptop and can't boot it up. I checked the Bios and it seems to be Ok.
It could be. It could be your boot sector is placed on a bad sector of your harddrive that's why your going in repair page everytime you boot, because it cannot read your boot sector properly. Removing your harddrive and check it with HD Tune Pro to find if there is a bad sector on your harddrive. HD Tune Pro can be used in Trial Mode, google for it.
Oct 01, 2012 | Acer Aspire 3680-2022 PC Notebook
No boot sector on internal hardware
There are several causes for this. First make sure the Bios recognizes the Hard Drive as the Primary Hard Drive. Second, double check to be sure the drive is properly seated and connected . If these are both done and set properly your drive has either been erased or lost it's master boot record due to a Virus or Error. You can try using the Windows recovery system to recover the boot sector but I would simply use system recovery and format the drive and reload it to factory specification.
Nov 12, 2011 | Dell Latitude 110L Notebook
I have a PCchips M701 that wont boot after long time I dint use.
It's unlikely that the BIOS itself has been "erased".
The BIOS is "software", recorded on a small "Eraseable Programmable Read Only Memory" chip.
It takes a piece of hardware, an 'EPROM-writer' to update the contents of the chip. Or, the BIOS can be updated by a "BIOS-update" from the manufacturer of the motherboard.
The BIOS has "settings" -- the battery on the motherboard should supply a "trickle" current to the chip that holds those "settings" -- like an alternator provides a "trickle" charge to recharge your automobile's battery.
Try using the "BIOS reset" jumper on the motherboard, to reset those "settings" to their default value, and then try to boot the motherboard.
Jun 10, 2010 | PC Chips (M925G) Motherboard
Hello, Trying to update this motherboard, now cpu celeron 3.20G 533ghz and would like to update to pentium 4 3.6G 800ghz that the user's manual says is doable. The problem is the motherboard will not...
Always remember that when you add new hardware like a processor or faster memory you have to clear the CMOS to reset the BIOS to defaults so it will recognize the new hardware. Sometimes you have to do this with hard drives particularly SATA drives.
On the motherboard, near the motherboard battery look for a small coloured plastic jumper. If your motherboard has one it will be marked as CLR_CMOS. Just move the jumper to the other position and press the on/off button. That will clear the CMOS.
If you don't have a CMOS jumper then remove the power cord from the back of the computer and take out the BIOS battery for half an hour or so. Replace the battery and plug in power. Turn the computer on and hopefully the the computer will boot and you will see a splash/post screen. If you do remember to set the correct date and time in the BIOS utility.
If your still not getting a post screen go back and check the processor is compatible with the motherboard. Check that the processor is locked in the socket properly and also check to make sure your system memory is seated properly.
Post back if need anymore advice.
Reagrds.
Sep 29, 2009 | Mach Speed P4MBMS Motherboard
Dell Poweredge 4300 Bootup problem after cmos battery replacement
Check the version for the Raid Controller. This may need to have the firmware to be upgraded. If the controller is removable, take the controller out and then see if the computer will continue past the bios. If the controller is built-in, then disable it in the bios, and try to see if it will get past the controller setup.
On most system I have worked with, if you are booting from a scsi hard drive, then the bios cannot be set to let any IDE to boot, or the bios must be set to no hard drive to boot. There may be two places in the bios which must be set to no hard drive. Another setting which may make a difference, is the scsi boot setting, if it has it. Another chance is that something is wrong with either the cabling or the controller itself.
As far as the jumper, that may be the erase bios jumper. Usually though, you have to move the jumper to one of two, sometimes three or four jumper. You would simply move the jumper to the erase setting, and then move it back. However, by doing that, you will lose all setting which had been set. Also, if the computer will go past the bios when the controller is removed, that could also mean some thing is wrong with a drive, or the boot drive is not set right in the controller bios. If a scsi drive is a boot drive, that boot drive number must be set right in the bios of the controller.
Aug 22, 2009 | Computers & Internet
I cant install any operating system in a desktop Gateway
you cannot install an operating system on an hdd on one system and just plug it in to another computer, as windows installs itself according to the specs of the machine you install it to. Have you tried plugging it in to a the second IDE slot? also check your jumper make sure that it is set to master
Apr 30, 2009 | Computers & Internet
HELP! I can not access "setup" (by pressing the delete key). When I press the delete key it say, "entering setup", then shuts down. I have tried barebones, 1 stick of ram in each of the 4 slots, nothing...
Have you tried clearing the bios? there's a jumper in the motherboard that let's you erase all settings done in the bios and return it to its original state. Some motherboards even include a password erase jumper for the bios. Check your motherboard manual for the location. Just place the jumper in the clear position and return it back. Some motherboards may require you to turn on the pc while in the clear position and then turn them on again in the normal position to perform a through clearing.
If this isn't working you might be dealing with a corrupted bios... data on it might have got altered by a virus or some error. So now it doesn't work as it should.
If you can't boot your PC and enter windows or browse the internet, then you must work from another computer and download a bios image from the manufacturer web page and look for an alternate method of bios update that lets you update your bios from a floppy disk or maybe from a pendrive.
If you can access windows and the only problem is that you can't access bios, then do a bios update through windows directly, downloading the new bios image from the manufacturer's webpage.
Take note some motherboards won't boot up if there's a problem with the CPU fan, to protect the CPU from burning.
Jan 04, 2009 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Emachine boots to bios with a new hard drive installed
Go inside to your BIOS menu then set the BOOT sequence to CD as the first boot so when your PC with the operating system installation disk inside it will load the installation wizard.
Good luck hope that helps........
Jun 16, 2008 | E-Machines eMachines T3830 PC Desktop
ASUS M2N E SLI Boot and Audio Problems
I would check if there is an updated BIOS available for your board, as this may help
Dec 04, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
BIOS in BAD Shape
First thing the problem only with O.S(as per your statement - proper shutdown and restart). Your O S afftected by virus. you must format the full harddisk(all partions) and reinstall your O S. BIOS File always having the .ROM extention file, not BIN file. Pls reset the BIOS using the clear cmos jumper or removing the CMOS battery from motherboard.*****severe virus attack. Dont try to backup****
Feb 23, 2007 | Syntax SV266AD Motherboard
AcerPower 1000 - Athlon 64 3800+ 2.4 GHz PC Desktop Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
