Question about Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor
1 year old dell monitor
My flat screen comes on for two seconds then goes blank. Can someone help me?
  • 59 Answers
Dell monitors separate 3 year warranty. call tech support at 800-8228965. have the monitor replaced.
hope this helps.
thanks.
Posted on Jan 09, 2008
Dell 17inch flat screen monitor will not remain on, the screen go
If your Dell monitor still under into warranty, better to call Dell technical support and have them replace your monitor coz there is no way you can fix on it.
If the monitor is beyond with the warranty already, better to but a new one than taking it repair that will cost you much.
Thank you.
Oct 06, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor goes blank after 2-3 seconds
could be hardware failure but i would try buttons on front of monitor first. notice, usually green led on monitor is green, if it goes to amber, you are loosing sync pulse.
Aug 20, 2009 | Computers & Internet
Pavilion f1903 silver goes blank seconds after turning on.
The monitor you have has bad components on the circuit boards inside.
This is a classic problem with all LCD monitors.
I rebuild them on a daily basis so I recognize the symptoms.
I would suggest finding someone who can do component level repair on the circuit boards inside.
I also suggest not trying to repair yourself as there are many breakable components to them as well as components inside that do not like static electricity discharges.
May 17, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
My monitor screen goes black
The monitor is going bad. Either going to be a bad screen or a bad inverter. Also Since you tried it on another computer and its still giving you the same symptoms, you know the computers are fine. To be sure, try another monitor on your computer and if you get video on the new monitor then thats another way of verifying that the dell monitor is bad.
May 16, 2009 | Dell UltraSharp 2000FP 20.1" Flat Panel...
Monitor goes blank after a second after power outage
what happend is your monitor cought the brown out and the power supply capcitors are not defective and what that means is the monitor needs to be repaired there is no quick fix please rate accordenly thanks.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 24, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
My E172fp has a blank screen...when i unplug and plug it back in,the "dell dimension" or whatever that logo is comes on for a second, then the screen goes blank and stays that way.another monitor works...
i have the same issue before with my DELL 2001FP, I replace the 3 capacitor on the board that look like defective because the top is look like swolen, it should be flat. I replace it with the same value and now the it works better.
i hope this might help .
Feb 25, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell Flat Screen Monitor
hello can someone help me?? the problem is when i turn the monitor on i just can see shine white i can do anything my monitor is del E197FPf lcd thanks a lot
Jun 25, 2008 | Rosewill R900J 19" Flat Panel LCD Monitor
Dell F1703 17 in. Flat Panel... Problem
There may be problem of heating the inside components. see him to expert.
Mar 03, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Blank after 2 seconds
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps.
Jun 14, 2007 | Dell UltraSharp 1703FP Flat panel TFT 17"...
Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor Logo
103 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
