Question about ViewSonic VX2235WM Monitor
Sometimes when I turn on my monitor pixels will go green or flicker. I have tried switching graphic cards, and inputs but neither of these fix the problem. The only fix I have is that I turn the monitor off and then back on. This seams to correct the issue but doesn't actually fix it. Any help would be appreciated. Thanks.
4 Suggested Answers
pollyluvpat
  • 103 Answers
SOURCE: Monitor turns off and is dim
replace pwr inverter board...
replace the video/keyboard as well...
Posted on May 14, 2009
Suricatta
  • 92 Answers
SOURCE: ViewSonic VX910 monitor has a power supply issue.
Your monitor have a bad condensator in the PSU.
The only thing to do is to replace the Power Supply Unit (very expensive, more than a new monitor) or if you have electronic tools, found and replace that condensator.(cheaper way...)
or
Have you connected your monitor with a new power cord ?
Best Regards!
Posted on Jun 29, 2009
  • 194 Answers
SOURCE: ViewSonic VX910 monitor appears to have power
try running the self test on the monitor
Self Test:
turn off the system disconnect the data cable from the tower and connect only the power cable to the monitor and trun on the monitor if you see colour full bars then the monitor is ok then try to go BIOS and see if the monitor is working
Posted on Jul 01, 2009
When I turn on my computer the LG Monitor displays the Digital Message appears and it goes to sleep. How do I fix this problem
This sounds like what happens when the monitor receives no video input.
The problem could be your computer, lead or connection rather than the monitor.
If your computer has a graphics card, try removing it, switching the computer on, switching off and refitting the graphics card or testing with a known good graphics card or computer.
If nothing works the monitor probably has a fault.
Feb 28, 2015 | LG Computers & Internet
My dell gx260 ligth come green if i turn it on but for a few mins time it turn orange why
Do you mean the monitor's power light starts green and then turns orange when you turn it on? Most monitors will go to a power saving mode when they do not get a signal from the computer.
The Dell GX260 has a green power light when on. When the computer is off, the light is off. If it is green and blinking, then the computer is in a power saving mode.
Diagnosis: start with the obvious: is the monitor cable plugged into both the computer and the monitor (if not permanently connected to the monitor)? Are you connected to the active port? (You can add a video graphics card in most desktops. The motherboard video port usually needs to be disabled to use the card ports. If you plug in the monitor cable to the disabled port, it won't work.) Is the monitor set to the correct input? (This applies if the monitor has several ports. In that case, there will be a Source or Input button on the monitor.) Is the computer on? The GX260 has the power button on the front. (Other computers have the power button on the top.) There is also the power supply switch on the back which needs to be on.
Next try a different data cable between the monitor and the computer (if you can). Try a different monitor. If a second monitor works, than the monitor has a damaged main board. If the second monitor doesn't work, then the video graphics adapter has probably failed. Replace the add-on card, if in use, then boot in the safe mode to remove the old graphics driver. Then install the correct driver for the graphics adapter.
Note: the computer and the monitor should both be off when you connect the cables. Then turn on the monitor first and set it to the correct source before turning on the computer.)
I hope this helps.
Aug 21, 2011 | Dell OptiPlex GX260 PC Desktop
I have a new BenQ G2220HD monitor connected to my MacBook as an external display. Since I've had it, it's had problems such as flickering pixels, lines that flicker, screen goes gray and flickers and is...
Your onboard video card is going bad on you computer. Some shops may sale an external video device which can be installed in place of your onboard video and it will fix your problem. Average costs aer about $50. Before you try YET ANOTHEr monitor, please try to hook the computer up to a tv to see if the problem pesists, if so, it is time for the above video adapter
Jan 28, 2011 | BenQ G2220HD Monitor
My monitor has been flickering from switch on for about a month. After re-starting 3-4 times it would clear. Then it took up to 8 times then it is just sometimes blank when I switch on. When it is plugged...
its power to the pixels causing the flickering the eletronics controlling which to use may be on its last legs,sorry but it sounds terminal for its use
Jun 22, 2010 | Samsung 226BW Monitor
My hp slimline's screen flickers violently at times and then it calms, but sometimes my computer restarts. Sometimes on restart it will not communicate a signal to the monitor. Problem has gotten steadily...
That issue normally happens with the graphics card. I am not sure if you have a PCI or an AGP graphics card or an onboard graphics card. But for all of the issue, you can try updating the motherboard chipset driver, or the graphics card (incase you have the onboard or AGP graphics card).
Try logging in to BIOS stay for some time and check if the screen flickers. If the screen flickers still in BIOS, its a possible graphics issue
Dec 13, 2009 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
Power light blinks red, green and off. No picture
Is there another monitor input on the back of you computer? Sometimes this happens when your graphics card is not compatible so it is best to try another one. If you have another one plug it in there first. If you don't try the monitor on a friends computer. If it still does the same thing, it may be a manufacturer defect and may need repair.
Nov 06, 2009 | Planar PL1911M-BK (Black) 19" LCD Monitor
I HAVE PURCHASE A SAMSUNG 20" LCD MONITOR MODEL NO. 2033 SW PLUS ON 09/10/2009 IT SHOW A VERTICAL GREEN HAIR LINE ON SCREEN PLEASE SUGGEST ME...........
return to the retailer and exchange it. if it's a green line from top to bottom, the retailer should be able to exchange it. some retailers have a minimum of "stuck pixels" before they will take it back (ie. 10 pixels), but if it's a line, that should be more than the min.
Oct 22, 2009 | Samsung 204T 20" LCD Monitor
I can not go past 1152 by 864 resolution, the screen will turn off and flicker also now it looks like video shown on the monitor is very high in contrast and sometimes the monitor will be on but no picture...
This means that you have reached the limitation of the graphics card of the PC that you have connected to it. You could try changing the Refresh rate of the card to see if you can get a higher resolution.
Oct 14, 2009 | Princeton Digital VL180 18.1 in. Flat...
Alienware monitor flickering green
this is most likely, a fault with the tft panel ( cfl Tube Or invertor )
Or a motherboard fault. I,d change screen invertor first Then new Panel.
Also if it has 2 graphics cards, 1 may have a fault.
Thankyou for using Fixya.
Mike @ compurepair.
Jan 21, 2009 | Computers & Internet
Flickering monitor attached to notebook.
doe syour lcd screen have pc input or dvi > also in your nvidia control panel u nee dto tell it add 720 p tv outto display manger always 60 hertz try differt resultion 1024x 768
Jan 10, 2008 | SPARKLE Computer GeForce 6600GT, (128 MB)...
ViewSonic VX2235WM Monitor Logo
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
