Question about Magellan Maestro 4250 GPS
I just bought a refurbished Maestro 4250 and it will not turn on. It has been charging over night in the house. I can not get it to turn on with the car adaptor either. I pressed the reset button also. Any thoughts other than to send it back to have it repaired.
    President:
  • 1,111 Answers
This model is know for this problem usaully caused by a bad usb port. you might get lucky though, because there not all bad.
if you have it plugged in, press and hold the power button for up to 15 seconds.
there are other thing you can do to see if yours has a usb problem, but unfortunately it will cost you money....i suggest if it doest turn on after what i suggested, take it back and get a different model..if you need a recommendation, let me know.
sadly, magellan will not recall these for this factory blunder
bill
Posted on Nov 16, 2009
Hey I want to updating maps or software for magellan maestro 4250, but i can not found the right software for it,so pleas can you help me,thank you.
Hi muntaserabou
you can get the latest firmware 4.86 for your 4250 HERE and the
2010 Map update for it HERE
Nov 27, 2010 | Magellan Maestro 4250 GPS
Firmware Update 4.86 failed in mid-update. Maestro 4250 will not respond. Menu screen comes up but will not work.
try and run the firmware update again. make sure the its fully charged or plugged in. this usually works though sometimes it wont depending on what files are missing..they are other ways to fix this problem, but i recommend you call magellan to get it fixed. they will repair any of their gps that were rendered inoperable do to there updates.
you can go here to contact magellan support
Jul 19, 2009 | Magellan Maestro 4250 GPS
Our Magellan Maestro 4250, came on by itself and will not turn off.
is it plugged to AC charge when it comes on?
If not seek out the RESET hole and place a fine pin or paper clip end in and reset the unit
Jun 20, 2009 | Magellan Maestro 4250 GPS
Magellan Maestro 4250 fuse
It is a Fast Fuse Glass type 5 x 20mm, 2A, 250v. Magellan 4250 can only take 1A of current at 5Volts Radio Shack
Jun 10, 2009 | Magellan Maestro 4250 GPS
Magellan Maestro 4250 freezing up
I just purchased a referb from TigerDirect and the only issue I discovered was a lockup when the unit goes to sleep. Try holding down the power button for 15 seconds then release it to cycle the unit. Then hold the power button down again for 5 second to start it back up. I had to do this for my bluetooth to work and not freeze up. Now I just turn it on and off manually and avoid having it go to sleep. I also downloaded the firmware update to 4.86, you can download it from Magellan's website. My unit works great so if that doesn't work contact Magellan and I'm sure they will have a solution.
May 29, 2009 | Magellan Maestro 4250 GPS
I HAVE MAGELLAN MAESTRO 4250 AND TOUCH SCREEN IS NOT WORKING WHAT CAN I DO THANKS
I got the touch screen from ebay, with search key word "4250 digitizer".
May 26, 2009 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4250 2008/2009 Map Update will not update my GPS
I also had problems with a refurbished Magellan 4250. The paperwork inside said to install the 4.85 firmware update which I found would not work with Windows XP Home at least for me. I used my laptop which has Vista Ult 32 bit it updated with no problem that is so far the only solution I used.
Apr 21, 2009 | Magellan Maestro 4250 GPS
Battery of Magellan Maestro 4250
Here is a link to some batteries.
http://search.ebay.com/search/search.dll?from=R40&_trksid=p3907.m37.l1313&satitle=Magellan+Maestro+4250+battery&category0=
A couple of screws out, to replace the battery, 10 minute job.
Hope this helps
Regards
Richard.
Mar 16, 2009 | Magellan & RoadMate 1200 North America GPS...
My Magellan Maestro 4250 got a lot of small black dots on the screen spread out on the right and side. Then most of them moved so they are now clustered together in a small circle on the right side. ...
It seems to me that you may have some dead pixels on your screen and the only fix is a new or good used screen.
I purchased a unit off ebay that had software issues and now my unit works great.
Hope this helps you out
Mar 11, 2009 | Magellan Maestro 4250 GPS
No a practical solution, but at least you will get your device repair, after being on hold for 40 minutes I spoke to a very nice rep, unfortunately evethough she didn't admit it, it seems a software problem with the new 2008/2009 map update, in other words no way to fix it, you need to send it for repair, make sure you tell them to update the device with the new 2008/2009 Maps, if not you will have the same problem later on, Good Luck
Jun 25, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4250 GPS Logo
151 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
