Question about Casio G''zOne Type S Cellular Phone
My front screen is very dim and hard to read, how can i fix this?
I have a singer confidence and the LCD screen is very dim. How do I fix that so I can read it?
Without knowing the exact model it is hard to say, but small screens like that are not easy to repair for the consumer. They have back lights on them and they are usually one piece.
Feb 15, 2017 | Singer Sewing Machines
What would cause instrument and radio light to dim
With the lights on auto, the dash will dim when the lights go on, based on the dimmer setting. If it's set low [wheel] they will be really dim. If it's light outside it will be hard to read. there are not many other causes other than a low battery or bad alternator.
Jul 29, 2014 | 2004 Buick LeSabre Custom
LG RH2T80 DVD/Recorder front display very dim.
Very clever and an easy way to fix a problem, bravo!
Feb 06, 2012 | Televison & Video
Phone display is very dim-can barely read
Well, first you will have to check your options, if you can read it enough to get in there.  You may have the backlight turned off.  If the backlight is not turned off, then you probably have a bad backlight and will have to take it to your provider to get it fixed.  Replacing a screen/backlight is not something I would attempt to do unless you are certain you know exactly what you are doing as you can render the phone completely useless.
May 28, 2009 | Motorola Mobility MOTO W755 Cellular Phone
I just replaced the lamp on my Mitsubishi WD-62327 picture is dim
TAKE THE FRONT SPEAKER PANEL OFF AND YOU WILL SEE TWO SCREWS ON THE LEFT AND RIGHT TOP CORNERS THAT HOLD THE TABS FOR THE SCREEN LOOSEN THEM THEN GO BEHIND THE TV AND REMOVE THE SCREWS AROUND THE PARIMETER OF THE BACK OF THE SCREEN 10 TOTAL THEN REMOVE THE FRONT CENTER PANEL 4 SCREWS AND UNPLUG THE SCREEN EASY TO SEE WHICH ONE THEN JUST LIFT THE SREEN STRAIT UP ONCED REMOVED YOU CAN CLEAN BOTH MIRRORS DONT USE CHEMICAL CLEANERS JUST A SOFT RAG HOPE THIS HELPS
Jan 23, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Backlight dim
you probably just need to turn up the brightness.
Nov 28, 2007 | HP Pavilion zd7000 zx5000 zv5000 presario...
Fuzzy screen
take off the front coner under that will be another cover it will require a screwdriver to remove now there will be a murata component with nobs on the front be careful only one nob controls focus the rest of which control the projectors
Oct 27, 2007 | Mitsubishi VS-45607 45" Rear Projection...
HCL4715W Rear projection "Red" color is dim
screen adjustment,remove front bottom cove and find the focus block the screens are also on the same block,if your not sure don't try.
Aug 28, 2007 | Samsung HCL4715W 47" Rear Projection...
Monitor dims for one account, not the other
I would first contact the GF administrator and ask them if they've heard of this before. Then I would contact Acer.
Jan 18, 2007 | Acer AL1916B 19" LCD Monitor
Casio G''zOne Type S Cellular Phone Logo
52 people viewed this question
Top Casio Cell Phones Experts
Oloyede Monsuru
ray gallant
Are you a Casio Cell Phone Expert? Answer questions, earn points and help others
