Question about Whirlpool Duet GHW9150P Front Load Washer
My front loader washer is leaking at the door and it don't seem to get my clothes clean what do i do
  • 5,911 Answers
Inspect the door bellow (seal) for any rips or tears. It may be worn or loose and require replacement. This is a fairly simple repair that anyone can do with a little guidance. The following link explains step-by-step how to install a door bellow on a Whirlpool Duet front loader:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Although the bellow may not have any physical tears, they can also become mishapened over time due to normal wear and not seal properly. You should have a good tight seal all the way around the door.
Read through the link provided and let me know if you have any questions.
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time. Thanks to user DGBG for the helpful tip.
If you would like some helpful exploded view diagrams of your washer that you can reference, you can use any of these web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
Just use your model number to begin your search criteria.
If you have any questions, please let me know. I hope this helps you.
NOTE: These door seals do wear out and require replacement from time to time. However, overloading the washer to the point where items get caught in the door area can contribute to premature wear and tear.
Some additional items to look for that may cause leaks around the bellow:
1. Check the dispenser tubes that pentrate the door bellow. Sometimes they get pushed behind the rubber causing the water to trickle behind the bellow and leak. You will notice this on fill and rinse.
2. Check the rear bellow clamp that holds the seal to the front facing of the wash tub. The clamp can come loose, causing it not to seal properly.
Posted on Nov 15, 2009
Washer leaking from bottom
If this is a front loader, you can take the front panel off under the door and inspect the bottom of the machine, there is a drain and trap with a large plug and the pump. Both need to be inspected and the drain should be cleaned and the debris removed from the trap. Get ready for lots of water though if you take the cap off the drain.
Feb 17, 2014 | Haier Washing Machines
Ytek.netwe just moved into a house with a duet washing machine- a few years old. when we do a normal clean cycle, it doesnt appear there is that much water getting used. How much water should we see thru...
All front loaders use very little water as a opposed to a top loader that uses up to 45 gallons per load a front loader uses about 10,plus a front loader cleans clothes very well with that minimal water usage.
The major question is do the clothes seem to come out clean when you have used that washer?
Aug 20, 2011 | Whirlpool Washing Machines
LG front loading washing machine. SEVERE water leak from front door. Gasket has been checked and is OK. Seems there is quite a bit of 'play' (i.e. slack or free movement) in the front door since if you...
This is a very common problem with the LG front loaders, and some other front loaders for that manner. There was a few recalls on them and some parts that were supposed to fix the issue. Even if the gasket looks ok i would replace it, as they have updated the design of the gaskets to fix issues on models that were having issues leaking. Most of the time its just a bad gasket and you cant really do anything other then replace it. Front load washers are about the worst appliance made today in my opinion, the repair shops around here are always full of broken and leaking front loaders. I have fixed quite a few myself, some work ok after the repair, some fail again in a matter of months, its a real duck shoot on them. The biggest failure rate though is the gaskets! And most of the time they look ok but still leak like a screen door.
May 04, 2017 | LG WM-2077H Front Load Washer
Clothes smell mildewy after washing and drying
This is a common problem with front load washers. Mildew tends to grow in these washers due to it use of less water than top loaders, often leaves dirt and soap residue on the machine. To help prevent mildew, wipe the door gasket, leave door and detergent dispenser open after wash. Wash once a month empty, with hot water and vinegar to kill the mildew in the machine.
Jul 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The smell that comes from this machine is terrible. My clothes also smell bad. I wipe out the seals rubber around door and leave the door open for at least 30 min. After each wash. I also take clothes out...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
Jun 19, 2010 | Samsung WF337AA Front Load Washer
My machine smells at the door where the rubber seal is . what can i do to get it to stop smelling so bad?
Jun 18, 2010 | LG WM2688H Front Load Washer
Washer leaks when it isn't packed full of clothes.
check your door seal if leaking in the front if the back its probably one of the water lines leaking
Feb 24, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Leaking whirlpool duet washer front load
remove and clean any obstruction or deposits around the inner door seal use H.E. detergent over sudsing can cause that too.
Mar 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
TROMM ultra capacity washer water levels
these machines are mean on water and you can open the door after wash starts
use good quality soap powder that suits front loaders and always wash at 40 deg or above
the black stuff is body fat that is still in machine called scud to me
also if you use conditioner in rinse cycle stop using that
it can cause same problem
Jan 28, 2008 | LG WM-1832C Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
722 people viewed this question
Dan Webster
Dan Webster
Sal De
