Question about Rainbow E series Canister Wet/Dry Vacuum
E2 Rainbow vacuum motor protector
I have an E2 Rainbow vacuum system and the motor protector trips just after a few minutes of running. I have to let it cool down for a long time to be able to re-start it but, eventually, it will trip again.
  • 1,041 Answers
You need to take the Heppa Filter off and rinse it very good under running water in the sink. You will see the dirt roll out of it! I'm not sure on dry time though. You may want to check with the manufacturer.
This happened to a friend of mine but she wasn't so lucky. She burnt the motor up and she had to replace it.
Jim
Posted on Dec 02, 2009
    Problem Solver:
  • 14 Answers
Some possible ideas:
Make sure the cone shaped air impeller does not have hair/thread/fibers wrapped around it. This will cause the motor to work harder, and trip the protector.
Make sure you are not overfilling the vacuum with water. If the water is touching the impeller, that will also cause it to move slower, and trip the protector.
Other than that, i'd have to examine it.
Hope that helps!
Posted on Nov 15, 2009
Rainbow turns on for a second or two then quits and won't turn back on.
If you have the model Rainbow E-2 eSERIES then the Motor Rainbow 120v could be going bad. This will trip the auto reset until it cools down.
If you have an E2 Type 12 Rainbow, then the Controller Asm 120v e2 Silver Gold could be going bad.
Our technical support team is available if you need... Contact Us
RainVac
Mar 24, 2016 | Rainbow E series Canister Wet/Dry Vacuum
E series Canister Wet/Dry Vacuum: My tank foamed up into the motor and now the rainb...
Hi, there is no reset button on a Rainbow vacuum. There is a safety switch on all E series and E2 series Rainbow vacuums, that keep it from running without the water basin on it.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 17, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Have a rainbow e-2 that was running and quit.
Thank you,
Ralph
Apr 25, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Overflow .. HELP
Thank you,
Ralph
One other thing, water sucking through your vacuum should not hurt it. It is not good though, but will not make it not run.
Thank you again,
Ralph
Apr 21, 2010 | Rainbow E series Canister Wet/Dry Vacuum
No power
You must have a late model 2006 or newer E2 two speed Rainbow vacuum that has the white foam padding in the canister, to dampen the sound of the motor, and has a red light on the computer board.
I hate to tell you, but your computer is most likely the problem, and is out on your E2 two speed vacuum.
The only solution is to get a new computer for it.
It is realy not worth replacing it, because it may also be the motor. The E2 is a very high tec system, and is not like any other vacuum. When you turn it on, you are not turning on the vacuum. You are turning on the computer, which is controling everything.
I could supply you with another canister, if you are interested.
Thank you,
Ralph
Feb 20, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E2 2 speed vacuum motor whines at startup
I used to sell rainbow vacuums and this latest 2 speed model does whine when it is first turned on. So you definately have nothing to worry about. I believe this is due to the fact that this motor is much more powerful than in the previous 1 speed E series model. I finally just purchased a 2 speed model after many many years of wanting one. Good luck to ya and enjoy your clean house!
Feb 18, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow e2 2 speed vacuum shuts off after 5 minutes of vacuuming.
2 speed E2 models have a circuit board inside that controls the machine. It sounds like this controller board may be bad. The unfortunate part of this is that the board is not only very expensive, but it is only available from an authorized Rainbow service center.
Use caution if you decide to work on this yourself or if you take it to a service center that is not famliar with these models. The circuit board mentioned above is susceptible to damage from static eclectricity discharge. The static you generate from just walking across a carpet could make this board useless. So, if the original problem is not the board you could make the problem worse.
Jan 31, 2010 | Rainbow E series Canister Wet/Dry Vacuum
E2 gold series - makes loud noise on start up
That is normal. All E2 two speed Rainbows make that sound. It is because it has a brushless motor that the computer is controling, and the computer is controling everything. The motor rotor has no coils on it on the rotor, which is very small and light, and the computer gives it a small power boost when you first turn on, then increases the power until ir reaches full speed.
Thank you,
Ralph
Jan 02, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow e2 system. Will not power up
the water basin has a safety on it so the unit cannot run without it. if you look on the bottom of the rainbow you can see a small oval shaped space that you can depress just to test and see if it still runs it will only run with this depressed.
Oct 11, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
437 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
