Question about Gateway ADSL2+ 1875 Wireless Router (1875A1420)
Ip routing/ nt or router problem
I am having a problem connecting two locations via frame relay. The problem I am having is being able to see/ping the machines on the internal/nic 1 of the nt servers. Below is a diagram. Any help would be appreciated nt-metro                                            nt-hacky nic1- to hubs          nic1- to hubs nic2- to,                  nic2 - to, cisco2524- ---- f/r--- cisco2524 IP forwarding is enabled on both sides Using cisco ip unnumbered for serial/circuit rip is enabled on cisco and installed on the NTs From either side I can ping the nic2 card i.e.: from nt-metro I can ping all the way to     from nt-hacky I can ping all the way to  I can also map to each machines devices. Where do I set the routing to enable the 192.168.15.x machines to ping the 192.168.18.x and visa versa I CAN FIX THE NAT HERE GIVE SOLUTION ASAP THANKS
Posted on Dec 05, 2008
  • 310 Answers
Check to see if the range of ip addresses you have set are between the set have to set a begining and a end. it in the router set up
Posted on Jan 09, 2008
How to connect to internet in redhat enterprise linux manually
1) Open a command prompt (or terminal, under System Tools)
2) Verify your system default route (route -n)
a) Does route exist?
1) Does it have a gateway IP address similar to that of your cable company? If so, try 'ping'
2) Is the gateway IP address similar to 192.168.x.x? If so, you have a local router. Verify that you can 'ping'. If not, try to ping your router IP address.
3) If still unsuccessful, verify your IP address.
Jun 17, 2012 | Red Hat Enterprise Linux ES Basic Edition
Client can not surf or ping specific web address - Cisco router
I am not sure but I believe the IP address is not correct. The trace goes to the following address:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Tracing route to []
on my machine. This is only a service provider I believe and not an end website. Have you checked and verified the ip address with the contact organization? Just because you can run a trace route on an ip address does not make accessible.
The cisco could also be blocking the outbound connection at your end.
Hope this helps.
Feb 11, 2010 | Cisco 877 ADSL Security Router
I have two RVS 4000 routers with pulic IP's connected VPN to each other. The Ip's on each end are and No firewalls. I cannot see the ping request on other network ???? I can see...
non public ips mean the 192.168.x.x. addresses you are referring to ... since they form a virtual private network it is normal .. see if ping protocol is disabled ..the other router just discarding the ping packets... you may have to check the route a packet is taking without VPN can be complex without a network diagram.
Aug 06, 2009 | Linksys RVS4000 Router
I want to run a laptop via a zoom router off the same modem I use for my computer which is cable.I cannot get the laptop to recognise the router
pl set the ips , thn connect the ethernet, see if the net icon says ethernet connected,ping the ips including self ping,if unsuccessful chech ips , if successful, ping modem , if unsuccessful check router, ifsuccessful , connect to internet.
Nov 28, 2008 | Computers & Internet
Automatically ping and trace disabled after PBR
please add me on yahoo messenger or mail me , let me know when ur online , my id is and we will be able to resolve it sooner,,, mails takes time.
Feb 20, 2008 | Computers & Internet
Route-map policy block the ICMP
honestly, I dont think anyone here will know how to handle this problem. Try to show this problem to a trained professional.
Feb 18, 2008 | Computers & Internet
How remove blocked icmp automatically
type a "no" before the command of blocking command
e.g:if you want to cancel ip address10.10.10.10
you must type no ip address
ICMP blocked automatically
return, cut this configuration, but put route the her isp´s.
You can ping after this?
Can´t ping you has other problem.
Routing configuration
Contact an ISP for an IP address.
configure the computers in the 2 networks to have the IP address you got from your ISP as the default gateway..
Jan 09, 2008 | D-Link DI 514 Wireless Router (DI-514)
Cannot find print server at all
How this works: Restoring the PocketPrintServer to Factory Defaults In most cases, the best way to restore the PocketPrintServer to factory defaults is through "telnet". However, if you are unable to connect to the device because of a configuration error, use the following method which does not require a network connection. To restore the PocketPrintServer to factory defaults, complete the following steps: 1. Disconnect the PocketPrintServer from the network and power cycle it. When it powers up, the LED will rapidly blink orange for five seconds. 2. Power down the device during the rapid orange blink period. Power up the device and power it down during that orange blink period two more times. 3. Reconnect the network cable and power up the PocketPrintServer. It will have restored itself to factory defaults and will rapidly blink green as it searches for a RARP or BOOTP server to find an IP address. Gleaning If an IP address has not been permanently assigned when the PocketPrintServer is powered on or reset, it will look for a "ping" packet on the network. If the PocketPrintServer receives a "ping" packet within two minutes, it will accept the IP address in the "ping" packet as its own address. To use Gleaning, you must have super-user privileges on a UNIX system. Gleaning also works under Windows 95 and Windows NT. 1. Add an entry in the ARP table that assigns an IP address to the Ethernet address of the PocketPrintServer. To do this, use the "arp" command. arp -s temp Example: arp -s 00:02:16:00:00:01 temp 2. Start a continuous "ping" to the PocketPrintServer. ping Example: ping On some systems, this may require an additional parameter. Some implementations of "ping" only send out one "ping" packet which could get lost in transit. Check your system documentation for more information. 3. Connect power to the PocketPrintServer. The PocketPrintServer will "glean" its IP address from the "ping" packet. This IP address will remain in effect until the PocketPrintServer is power cycled or reset. Therefore, a permanent IP address should be assigned by running the ExtendView TCP/IP utility or via "telnet".
Jan 30, 2007 | Extended Systems Pocket Print Server
Gateway ADSL2+ 1875 Wireless Router (1875A1420) Logo
206 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
