Question about Canon PIXMA MP780 All-In-One InkJet Printer
Error - head alignment failed - Canon PIXMA MP780 All-In-One InkJet Printer
    Master:
  • Canon Master
  • 956 Answers
RUN YOUR FACILITIES MENU.
MAKE SURE PRINT CARRIAGES ARE LOCATED PROPERLY IN SOCKETS?
Posted on Nov 15, 2009
I have changed all ink cartridges on my canon pixma ip4200 printer and it now doesn't work, the green and amber lights flash for 11 times and the cartridge carrier doesn't move. Please can someone advice...
From Canon Help Files.
Automatic Print Head alignment failed
Possible causes are as follows:
6128_image_6.gif A4 or Letter-sized paper is not loaded on the Auto Sheet Feeder.
Press the RESUME/CANCEL button on the printer to clear the error, then load one sheet of A4 or Letter-sized paper in the Auto Sheet Feeder.
Automatic print head alignment cannot be performed using paper from the Cassette. For automatic print head alignment, always load paper in the Auto Sheet Feeder.
6128_image_6.gif Print Head nozzles are clogged.
Press the RESUME/CANCEL button on the printer to clear the error, and then print out the nozzle check pattern to examine the print head condition.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
6128_image_6.gif The Paper Output Slot has been exposed to a strong light source preventing correct Print Head alignment.
Press the RESUME/CANCEL button to clear the error and move the printer to a darker location.
After carrying out the above measures, if the problem continues after aligning the Print Head again, press the RESUME/CANCEL button to clear the error, and then perform manual print head alignment. For details on manual print head alignment, see "Manual Print Head Alignment."
Sep 10, 2014 | Canon PIXMA Office Equipment & Supplies
Error 19
Hi there-
Below are a list of the error codes for this model.
E16-E19 = Failed to scan head alignment sheet.
You can find this information at http://www.usa.canon.com/cusa/home
CANON MP140, MP145, MP150, MP160 RESET ERROR CODES
[Info140] pixel_trans.gif RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge
is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera
Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Nov 29, 2013 | Canon PIXMA MP150 All-In-One InkJet...
Alignment failed when run
If Printer heads health condition is not good, alignment wont completes..
Four individual cartridges & Two print heads, each print head prints two colors.. Black& Yellow, Cyan & Magenta.. Verify which color is not printing properly(Color missing Or white bands)..
Perform 2 or 3 times print head cleaning through printer menu..Try for alignment.. If success end.. if no, replace the print head which is not printing properly.. Before replacing the printer head ensure that cartridge ink should be above 30%...
Oct 07, 2012 | HP Officejet Pro L7680 All-In-One Printer
Changed the black printer cardtridge on a canon mp160 and getting errror code E19 when trying to align the heads...any idea why, and how to fix please? Thanks
This error idicates that the size of the document cannot be correctly detected or the document is too small when the Fit-to-Page copying is selected or the unit Failed to scan head alignment sheet correctly.
The remedy is
Make sure the document meets the requirements and correctly loaded on the Platen Glass. Then reload the document and press the Black or Color button.
Check that all necessary circles are filled in the Print Head Alignment Sheet, and that it is placed in the proper position and orientation on the Platen Glass. You can also perform print head alignment manually.
Sep 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Parity error issue with TF85 DSSI based on VAX4000 - 700
If cleaning the heads using the cleaning tape did not help, then there are 3 possibilities that I know of:
1) The heads are sufficiently dirty to require direct cleaning with a more powerful solution.
2) The heads are defective.
3) The heads are out of alignment.
Parity errors are not usually controller problems. If the head alignment has drifted enough, you may be missing a track when recording. An initialization includes writing format information at the beginning of the tape. This is "re-read" during the process to confirm correct writing. This is the part that is failing.
Keep me posted.
Dan
Feb 20, 2009 | Compaq DLT Tape Drive (TF85) DLT Tape...
Head align fail
Try cleaning the printhead with a cotton swab soaked in isopropyl alcohol.
Jan 14, 2009 | Canon PIXMA MP780 All-In-One InkJet...
E16
press stop reset button for few seconds and you can use your black cartridge for printing,but do remember to put use black only setting in ur printer cartridge settings.
Nov 09, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
154 people viewed this question
old marine
old marine
