Question about Epson Stylus Photo R340 InkJet Printer
My yellow ink cartridge won't print only, I REALLY HAVE TRIED EVERYTHING
Hi I recently got a bulk ink system that was working fine until the yellow stopped printing. I followed the troubleshooting guide and did everything including: cleaning with a new set of cartridges, head cleaning, ink flushing, syringing out the ink for the cartridge etc. Both sets of cartridges the bulk system and the new ones don't print yellow meaning my yellow should be clogged or something in the printer. I don't know what to do how can I unclog the printer???!! Please Help!!
  • whatizadi Jan 17, 2008
    I guess I'll answer my own question since I finally figured it out. I emptied out one of my bulk flow containers (the yellow ink one) filled it with some bathroom cleaner, ran some head cleans and ink flushed once. Then I let it sit overnight. It got rid of the dried up ink in the printer, did another head clean and it was unclogged. Took out the bathroom cleaner and put my yellow ink back in. Now it works great!
  • dont12go Aug 19, 2008
    I am having the same problem that the yellow will not print. I have cleaned the heads many times and tried 3 other new cartridges. Still can not get it to work.
What kind of bathroom cleaner worked? exact name? Thanks
Posted on Aug 16, 2008
Cannon Pixma MG5520 printer
Remove all cartridges, clean the ink from where the cartridges make contact with cloth,(paper towels can leave trash in there) be sure all is clean then replace the cartridges and print something. Those streaks shouldn't be there any longer.
Sep 09, 2014 | Office Equipment & Supplies
The black ink on my Brother DCP-130C won't print and it's a brand new ink cartridge. I thought it was a defected cartridge so I bought another one, same thing. The other 3 colours print ok though....
I have the same problem. Everything on the printer is working just fine. It'll do a test page just fine, so everything's working right. The %$^ thing just won't print. It makes noise like it's printing when you give it a print job, but it spits out blank pages.
Sep 08, 2011 | Brother DCP-130C InkJet Printer
I have to print a word document in black. Because I have no yellow ink, the printer won't print anything. I have tried everything and just want to print a simple one page document and I have plenty of...
here's a solution i came across when dealing with the same problem. apparently the printer expects all of the cartridges to be full and has a sensor to make sure they are even when only printing black. hope this helps!
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
Jul 13, 2011 | Brother MFC 490cw Color Inkjet...
Hello! We have a Brother MFC-J615 printer & we have been having a problem recently with the Black ink. It just randomly started to not print any black ink, but the other colors are just fine. The ink...
It sounds like you're not using the correct ink for the printer.
Each printer requires a different formula and thickness of ink for it to work correctly.
Have you recently started using a new bottle or topped up with a different ink in the system?.
Jun 29, 2011 | Brother Office Equipment & Supplies
Recently replaced all cartridges in C88 with new recently purchased Epson cartridges. Only blue and black ink prints. No red or yellow. Tried cleaning printer heads. Still no red or yellow printing.
You have to go to the properties of the printer and in the maintainance tab do some nozel cleaning and head cleaning.
and check it should be fine
thanks
Dec 14, 2010 | Epson Stylus C88 InkJet Photo Printer
Yellow ink will not print
On the Brother MFC series printers it uses remote ink trays as you will know, instead of having print heads directly on the ink cartridge. Whilst this approach makes it cheaper to produce the ink, and easier to change the cartridge, it can make it difficult to clear clogs.
There are several things you can do which may help, but B. and C. are at your own risk. All steps assume you have a new yellow ink cartridge.
A. In paint or another program, create a full page yellow image and keep printing it out. See if it gets any better after each print. If it does, continue until it seems to be working fine.
B. If you can manage to get to the print head, you can get a cue tip, dip it in rubbing alcohol and gently clean the print head. Leave 20 minutes to dry, and then do step A. again.
C. (AS A VERY LAST RESORT AT YOUR OWN RISK. THIS IS GOING TO RUIN YOUR YELLOW INK CARTRIDGE SO USE AN OLD YELLOW ONE IF YOU CAN) If steps A. and B. fail, you can put a "little" rubbing alcohol in the Yellow Ink Cartridge, and keep trying step A. If Yellow starts printing again, swap to a yellow cartridge that does not have rubbing alcohol in it. You are now going to have to cycle through many pages to clear the rubbing alcohol from the ink lines.
Note that if you keep cleaning the cartridges, it is going to use a lot of ink, and may actually hinder solving your yellow ink problem.
Good uck
Apr 24, 2010 | Brother MFC 240C All-In-One InkJet Printer
Printer only won't print in black
My printer did that a few months ago. I tried everything to get it printing black but in the end I had to take the ink cartridge back and return a new one. Some ink cartridges dry out when they are being shipped if not stored in proper conditions.
Mar 14, 2010 | HP Officejet 6500 Wireless All-in-One...
Printing yellow for black
Hi Jan,
Can you confirm that you are using a CIS or non-HP cartridges with this printer?
It sounds a lot like the printhead has reached a clogging point where sediment has built up in the black portion and loosens enough to printer a few lines before it re-asserts itself again.
Based on my experience of this printer, if you're using a non-HP delivery system for ink then you should consider replacing the black ink with a dyebase alternative instead of pigment.. Replacing the Black/Yellow printhead and running a number of test prints to purge the pigment ink in the printhead should then result in a clean and more reliable printout in future.
One other vector for problems is the cleaning area and I've found that this can become soiled with excess ink causing cross contamination within the inks of one printhead. As yet I've not found a reliable solution to counter this sort of issue.
Hope this gives some clues and hopefully some ideas of a fix.
Martin
May 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
My printer won't print yellow even when I replace the cartridge.
Desperate measures!
I have a PIXMA MP 750 and months ago my yellow ink stopped printing. I was only able to use the printer for black and white printing. Every once in awhile I would try multiple deep cleans, new ink cartridges, etc. etc. I talked to the very unhelpful folks at Canon who suggested a new print head ($70), but they couldn't guarantee this would actually work. They really thought it would be best just to buy a new printer.
Although I was feeling bad about adding yet another cheap printer to the landfill I'd pretty much decided to get a new printer. As a last resort I decided to use a suggestion I came across (at pcuser.com) to run hot water through the print head. It was easy to remove the print head (check your manual). I propped the head up in my dish drainer and ran hot water straight from the tap first through the end with the little circular parts and then through the end with the metal strips. I eventually used boiling water from the kettle.
As I poured water through one end I started to see yellow ink coming though the other end so I figured the ink had dried in the head. I kept pouring water through (from both ends) until the water ran clear. I dried the print head, put it back in with the cartridges and VOILA! after MONTHS without yellow ink it's working beautifully again!
If you've tried everything else and feel desperate enough to buy a new printer you might want to try this and report back.
Jan 16, 2009 | Canon PIXMA IP5200 InkJet Photo Printer
Will not print
Try using the 'clean cartridge' setting with your printer, this usually forces the ink through the installed cartridges.
Dec 11, 2007 | Dell 922 All-In-One InkJet Printer
Epson Stylus Photo R340 InkJet Printer Logo
731 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
