Question about Canon PowerShot SD550 / IXUS 750 Digital Camera
My lens for my canon powershot SD550 is stuck open.when switching the camera power on E18 appears on the screen in the bottom left corner.
  • Canon Master
  • 4,738 Answers
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here are some things that you can do to try to correct it. They only seem to work for about 40% of lens errors, but if the camera is out of warranty they're worth a try.
Posted on Nov 15, 2009
My lens for my ixus 750 is stuck open. when
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 09, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
E18 error on canon digital camera s200 powershot dropped it and now the lens is stuck halfway out/in The lens will not open, it was not dropped. I get e18 error.
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
I am giving below a link which will help you with E18 problem.
http://www.e18error.com/repair.html
Hope this helps, let me know if you have a proble.
You can Try the following also;
Remove the batteries from the camera, wait a few minutes. Put a fully charged batteries back in and turn the camera on. if it doesnot work then,
2: Remove the batteries again, as also remove the memory card. Then install the newly charged batteries, when you turn it on it should come back to life.
3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful to overcome any grit or sand particles that may be jamming the lens.
4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Try the above and let me if its any help.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 07, 2009 | Canon PowerShot S200 / IXUS 178 Digital...
When I turn on my PowerShot A70, it comes on and immediately shuts itself off and the Error E18 appears on the screen.
Mar 04, 2009 | Canon PowerShot A70 Digital Camera
Camera won't function - "E18" (Canon PowerShot S230)
Try lightly tapping lens on a hard surface. This sometimes reseats the lens. If this does not work take to bits and reassemble.
Dec 13, 2008 | Canon PowerShot A75 Digital Camera
Have a powershot sd550
E18 is a lens error. My guess would be sand got into your lens (into the gears, etc.). These guys should be able to take care of you. http://www.darntoothysam.com/servlet/the-1730/Canon-Powershot-SD550-Camera/Detail
Feb 28, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
Lens trouble canon powershot sd 550
check here...http://www.fixya.com/support/t102982-e_18_problem
Oct 02, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Error 18 in right bottom corner
"e18" is a lens error, the lens is stuck and would not come out, camera displays error and shuts off. replace the lens assembly and it will fix the problem
Aug 20, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
PowerShot A70
This comes up when the lens sticks. Try removing the colar around the lens, then turn the camera on/off and give it a "little help" to open or close, it's probably just a little stuck
Dec 14, 2006 | Canon PowerShot A70 Digital Camera
Canon PowerShot SD550 / IXUS 750 Digital Camera Logo
233 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
