Question about Ecoquest Breeze AT Living Air Purifier
Plug it in and the light goes on but it does not operate
    President:
  • 670 Answers
Check the lint screen on the back of the machine and ensure that the safety switch activator clip depresses the safety switch.
Posted on Dec 24, 2009
My Eden pure model Gen 3 doesn't turn on ? The red light on front is lite and filter is clean Why not
Edenpure has a troubleshooting guide at this website: MY HEATER WILL NOT TURN ON.
  • Make sure the power source is good. Plug in a lamp to see if it works correctly.
  • Make sure the front power switch/button is set to the "ON" position.
  • Unplug the power for 30 minutes. Plug the power back in and try operating the heater again. This will reset the internal sensors.
  • Some heater models are designed to be operated in temperatures less than 75 degrees Fahrenheit. The heater will not operate when the temperature is too high. Test the heater in a room that is below 75 degrees Fahrenheit.
  • Bring the heater inside to warm up for at least one hour before operating if it has been stored in a freezing or near freezing environment.
  • Make sure the filter is clean.
  • Remember, it will take a few minutes for the heater to warm up. The fan will start to blow after the heater has warmed up.
Heaters FAQ
Dec 07, 2016 | Air Purifiers
Ecoquest freshair - inside wireing
Black = phase white = Neutral , Strip yellow/green =ground
Aug 11, 2008 | Ecoquest Flair Air Purifier
Device appears to have no power. Power cord looks good, it was working the day before then suddenly stopped working... no lights indication of any power making it to the device.
This unit will not operate if it is plugged into a power strip - it must be plugged directly into the wall outlet. An extension cord may be used.
Aug 16, 2011 | Honeywell (18155) Air Purifier
MIDI Ionic Breeze quit working
Unit seems to need reset...To do this simply, with unit still plugged in, set to off by selecting on button until there are no high, med, or low lights on. unplug unit from wall for about 15 seconds then plug back into wall socket and select your favorite setting high, med. or low. The order in which you perform this task must be as stated above and the unit must be clean and the door and cleaning rod must be in home position. Hope this helps, mines working fine now but took a couple tries to find right order to reset.
Sep 16, 2009 | Sharper Image Professional Plus Ionic...
AC2044-1
Unit likely had large partical like dog or cat hair cross over cell, Unlplug and remove pre-filter & cell.
The unit has a timer that knows when power has been removed & front grille has been taken off by 2 micro switches in back of front grille that is connected to the units control board.
While you are there remove pre-filter & Cell, if ok and no debris is found & theres no need to wash, wait 10 to 15 minutes replace all & plug back in.
You should see the LED display flashing Clean Cell & Cell button flashing, hold Cell button in at least 3 seconds this may take longer to reset. Unit should turn back on.
This condition has happened to my 2 units on occasion even though I had washed the cell only a week or two previously.
The unit will turn off if a cell overload is detected by way of large static discharge. If I know the cell is clean, I just unplug the unit & take the front grille off for 15 minutes then & replace it plug back in & reset & all goes back to normal operation.
Apr 22, 2008 | Kenmore AC2044-1 Air Purifier
Will not start up??
Same problem here. Opened it but everythng seemed intact. Red light flashes momentarily during initial plug in. Has power, oscillates but no fan rotation.
Nov 05, 2007 | Bionaire BAP1500-U Air Purifier
Honeywell 18155 Air Purifier
did you ever solve this issue? I just borrowed my mom's and it worked fine for two days and then suddenly won't turn on at all. I wonder if there is a fuse that might have blown during a power surge while we were out of town or something...
Any help would be appreciated.
Oct 27, 2007 | Honeywell (18155) Air Purifier
Ecoquest Breeze AT Living Air Purifier Logo
115 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
