Question about LG Refrigeration 27 cu. ft. Space Plus Side by Side Refrigerator - LSC27950
My LG side refrigerator and freezer LG LSC27910TT was purchased over 1 year ago and just stopped working - all the sudden no power
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 161 Answers
You have a bad main board. Call LG customer service for your options.
Posted on Jan 24, 2010
My LG fridge has stopped working the lights are out and its not making any noise the fan has even stopped is this fixable? As its only 3 years old
Have you tried checking to see if anything else works in that outlet? It sounds as if you have lost power to the outlet.
May 15, 2015 | LG Refrigerators
My LG lsc27910tt ice maker arm is stuck in the up position and won't budge.
there is a good chance that some ice has jammed in there somehow. have you tried defrosting the machine... that would be the first thing to try.
Oct 11, 2014 | LG LSC27910TT (265 cu ft) Side by Side...
How to investigate the problem with the ice dispenser on my LG LSC27910TT?
what is it doing? is it making ice? is water getting to the tray? are ice cubes small? large?
Jun 05, 2014 | LG LSC27910TT (265 cu ft) Side by Side...
Samsung french droor fridge and freezer model # RFG298AARS model code RFG298AARS/XAA just stopped working has 119v ac from outlet. dispencer leds just keep flashing and that is it. I hooked power straight...
The problem with new appliances is often related to the computer controls and they don't tell you that you should install surge suppression on the on appliances. The fact that you have some indication that there is power from the board when the display flashes means that it is not a fuse on that board. IT may be related to bad components or surge.
Mar 04, 2018 | LG LSC27910TT (265 cu ft) Side by Side...
Side by side refrigerator freezer ......refrigerator works but freezer went off last night
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 26, 2011 | LG LSC27910TT (265 cu ft) Side by Side...
Hi, our LG LSC27910TT just lost complete power. Tried other outlets...nothing. It's only 3 years old and of course warrenty has expired. Any suggestions or if anyone else had this issue do you know...
More then likely you have a blowen fuse on motherboard. remove cover after you unplug the box. the cover might be on top or back of box. the fuse is on the board. It looks like old car fuse. you should be able to buy at sears. If this dont work you will have to change the board. hope this helps.
Aug 20, 2011 | LG LSC27910TT (265 cu ft) Side by Side...
Hey our refrigerator has stopped working completely. There is no power being accepted by the machine and it has completelly shut down and will not start up again. What should we do? It is an LG LSC27910TT
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 10, 2010 | LG LSC27910TT (265 cu ft) Side by Side...
My LG LSC27910TT refrigerator stopped working suddenly
Hi, It's either the start device on the compressor or you have a bad compressor. You'll have to pull it away from the wall and take the bottom back panel off to check the compressor. It will likely be real hot to the touch from what you described happening. If there is a little white colored box on the left side take that off and remove the wires, etc. and shake it... if it rattles and debris falls out then that's the problem. It's fairly common and they make a kit to replace it with a better designed part that's real easy to install yourself. If your compressor has a label on it with a blue indian head symbol, then you're out of luck as that brand pretty much sucks and is destroyed by heat. It would mean a new compressor and then you'd be lucky if the new one even worked from the factory. Avoid those Tecumseh compressors at all cost.
Jul 19, 2010 | LG LSC27910TT (265 cu ft) Side by Side...
I have an LG fridge top / freezer bottom which I purchased exactly 3 years ago. The fridge has stopped cooling, although the inside light stays on. Also, the freezer is still working perfectly. Firstly,...
Most LG fridges have a 1 year warranty with some components exteneded, such as the compressor or sealed system repair. Those are usually 5 years or long, depending on the model.
Can you tell me the temp. in your fridge please? I have a strong suspicion that it may just be the thermostat.
Feb 03, 2009 | Refrigerators
LG Refrigeration 27 cu. ft. Space Plus Side by Side Refrigerator - LSC27950 Logo
365 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
