Question about Dell Latitude D600 Notebook
Ihave changed my dell d600 power suppl and it works ,but the problem is how to configure in set up while it says press f1-x to set up ,but once you press it says that it is docked,you need to undock, so what to do to my laptop to get on working?
  • Dell Master
  • 4,924 Answers
Am I to understand that when you boot it is sending you in Bios to set time and date ...by pressing F1 ...the thing you can try is to press f 10 while in bios even if it says its docked...and than confirm ..this will make it believe that it is set ..and will reboot and enter windows...after that you will set the time and tah date in windows and when connect to the insternet you can sync it with windows server..
Posted on Nov 15, 2009
I've changed the CMOS battery of my GX260 series desktop as it was prompting an alert as "System battery voltage low" & after that Systems IDE configuration failed performing an automatic...
Press f2 to enter the BIOS while you see the Dell start up screen. Once in there you shoudl see an option to load BIOS defaults. Load defaults. This should take care of the issue. Are you sure that you replaced it with an approved CMOS batter, You cannot use a watch battery, even though they are the same size it won't work.
Aug 01, 2011 | Dell OptiPlex GX260 PC Desktop
My Laptop is Dell Latitude D600 (A16) Everytime I tried to power up, Splash screen appears with blue bar and when going into next screen this message appears " No bootable devices--strike F1 to retry...
Check your BIOS, by pressing F2 and see if the hard drive is recognized. It should indicate the MFR next to the hard drive listing. If it's not there, then you might have a bad hard drive. If it is there, try re-installing the operating system with the set-up disk. You can also go to the Dell website, enter you service tag number, and get technical support for your particular laptop. It might have a recovery partition in the hard drive to recover to factory settings.
Oct 26, 2010 | Dell Latitude D600 Notebook
When i power my computer up, its telling me to press f1 to continue or f2 to setup. I pressed f1 and it is asking me for a password. What is the password?
Ok this means that somebody has set a bios password on your computer, But we can fix this for you. I will try and explain this for you.
"The reason the computer is asking you to press F1 is because some settings in the Bios are not correct, such as memory size is incorrect or processor speed is not right, So what you need to do is un-plug the computer and once it is unplugged take open up the computer by removing the case or side to have access to the motherboard, once you see the motherboard locate the battery backup which will be similar to the picture below. Once you locate the battery, take it out, Now with the battery out press and hold the power button in for about 3-5 seconds to discharge the remaining power from the system. Once you have done this re-insert the battery and put the computer case back on and plug it back in and press the power button. You will then be prompted with the Press F1 to continue screen since we reset everything now, so you will want to press F2 to enter your bios in which should not have a password now, Once you are in the bios screen which should be a blue screen, look for the option to set to default usually its like F12 or some key like that but not sure on your system. Once you restore to default make sure to save changes and restart the computer and you should be all set and not have the F1 to continue screen any longer. I hope this helps.
Jun 25, 2010 | Dell Inspiron 530 Desktop Computer
I have an laptop Dell D600 ,its charging port was short circuited ,ihave repair it but now as iam pressing power button three lights are going ON for short and turn off ,nothing working ,display and other...
Hi, try taking out the battery and see what happens.
It may be that when the charge port was short circuited it may have damaged the PSU. Do you have another one to try or may be borrow one from a friend who has a similar Dell Laptop.
Give this a try and let me know.
Regards - Anthony
Feb 23, 2010 | Dell Latitude D600 Notebook
How do i enable the setup configuration in the
Hi:
as your Dell boots up, you need to start hitting the F1 key to enter setup, and once you are in, you can tab thru the various pages of settings. When you are done, hit F10 to save and exit.
Nov 06, 2009 | Dell Latitude D600 Notebook
Dell D600
Sounds like a driver might have gone AWOL. Can you go into safe mode? Usually by pressing F8 after the Dell logo you will be prompted to go into safe mode.
Go insto safe mode and once inside restart the computer. This will repair anything that may have shutdown improperly.
If you can, also change the resolution to the least available, normally 800x600. Once you get back into the "normal" session, you can set it to your liking.
See if this works for you.
May 18, 2009 | Dell Latitude D600 Notebook
Booting up my d600 laptop
This problem can be caused by two reasons:
1) The CMOS battery is damaged or displaced ( apart from the external battery, there is a small battery which is connected to the motherboard)
2) One of the RAM modules is displaced.
First make sure that the laptop displays the amount of RAM correctly. You do this by opening Control Panel -> System and noticing the amount of RAM.
If it is okay then press F2 when your computer starts of to enter bios. Make sure that the date and time displayed are okay, if not change them accordingly. Then Save the CMOS and exit.
If nothing changes then let me know
Nov 24, 2008 | Dell Latitude D600 Notebook
From the keyboard how can i adjust dell latitude D 600 brightness
Hold down the Fn key and press the up arrow several times until it tops out. By default, if you are running on battery power, it dims the display to conserve power.
Oct 23, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell latitude C610
From the Bios, load all the default settings and then check the bios SATA port settings. If it is set to AHCI, change it to IDE to boot from Hard Drive. This should solve the problem
Oct 01, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
64 people viewed this question
Alun Cox
